Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-04-2019, 05:06 PM | #15 | |
08-04-2019, 05:29 PM | #16 |
Drives: 2014 GT86
While newbies can overuse brakes even without really going that fast, AFAIK for best laptimes one is always either accelerating or braking (with exception of course balancing throttle at curves or some specific track bits to not loose traction/stability), thus if one is not braking hard enough, one needs to brake earlier, less time left to accelerate, lower average speed. And if different drivers net similar lap times with different brake extent, i'd guess they all simply are not going at full car capability, just in different ways, with different mistakes. One is braking properly but loosing time one something else, other is underbraking, too easy, too early, but wins back elsewhere. Rest being same, with other variables eliminated, one that brakes properly using all tire grip, should be faster. And learning right brake points, treshold braking, brake release points, brake use for mass/grip transfer, braking using full tire grip and so on imho are among most important bits for driving fast. Not that other bits like throttle mastery, racing lines, car setup and so on doesn't matter, but despite it sounding a bit counterintuitive, one must master braking to go fast. Hence why brake setups that one can rely upon and which enhance braking control finese show it's real value in competitive field.
08-04-2019, 07:00 PM | #17 | |
Drives: 17 BRZ Series.Yellow
@CSGDavid I'll give you guys a call tomorrow. Sent from my Pixel 3 using Tapatalk |
08-05-2019, 03:35 PM | #18 | |
08-06-2019, 10:42 AM | #19 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | i8ur911 (08-06-2019) |
Similar Threads | ||||
Recommendations for track pads better than PMU HC800+? | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 32 | 03-10-2016 03:21 PM |
Track-Only HPDE Brake Pad recommendations. Stock platform/calipers/rotors | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-20-2014 12:03 PM |
Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-26-2014 11:47 PM |
Track pad setup recommendations | orthojoe | Tracking / Autocross / HPDE / Drifting | 15 | 02-25-2013 07:18 PM |
Need Tire recommendations please, non track use | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 01-03-2013 04:15 PM |
