11-09-2017, 04:49 PM | #15 |
Drives: 2017 WR BLUE BRZ
ATI SUPER DAMPER #ATI917266 for CTSV to go along with a CTSV accessory drive kit due in today or tomorrow
Some assembly required lol |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | DustinS (11-09-2017) |
11-09-2017, 04:49 PM | #16 | |
The Following User Says Thank You to mkivsoopra For This Useful Post: | ILLSMOQ (11-09-2017) |
11-10-2017, 08:46 PM | #17 |
Accessory drive system arrived today.
Chevrolet performance ctsv accessory drive system # 19155066 https://www.summitracing.com/parts/n...5066/overview/ This kit comes with everything, accessories, mounting brackets and bolts. I couldn’t find it without the power steering parts so just left them out and @DustinS pointed me to the correct, shorter belt (dacco # 5060560 56” belt) and ribbed pulley (dacco #49021 https://www.summitracing.com/parts/n...5066/overview/ ) needed to delete the power steering components. Swapped in the ribbed pulley, has to take the sleeve from the smooth pulley, grind it down and shim the ribbed pulley out with a couple washers to get it lined up correctly too. Last edited by ILLSMOQ; 11-11-2017 at 10:30 AM. |
11-11-2017, 12:55 PM | #18 |
Drives: Moped
Super excited to see and hopefully hear the finished product!
The Following User Says Thank You to Lonewolf For This Useful Post: | ILLSMOQ (11-11-2017) |
11-11-2017, 01:54 PM | #19 |
11-13-2017, 10:45 AM | #20 |
Drives: RAVEN
I also found that there are very few driving videos of these swaps. Looking for some in-car narration!
The Following User Says Thank You to NOHOME For This Useful Post: | ILLSMOQ (11-16-2017) |
11-13-2017, 11:01 AM | #21 | |
Drives: 2013 Ultramarine FR-S
I am excited to see some videos of ILLSMOQ's car. Should be amazing.
The Following User Says Thank You to DustinS For This Useful Post: | ILLSMOQ (11-13-2017) |
11-13-2017, 02:44 PM | #22 |
BoostedBRZ
Drives: Turbo BRZ
wow. this is awesome. can't wait for this to be finished. thank you for documenting!
The Following User Says Thank You to pgranberg11 For This Useful Post: | ILLSMOQ (11-13-2017) |
11-13-2017, 07:05 PM | #23 |
11-14-2017, 07:03 PM | #24 |
Did a lot of clearanceing today
Pounded in the driver side firewall Also moved the brass brake line splitter up and away from where the exhaust will go. You can see where the lines where in the pictures above. Opened up the shifter hole too Pulled all the radiator stuff and I started planning the air intake. I want the air to come from the front....I think I can work with the available room. Yanked the foam bumper pad from inbetween the bumper and the crash bar Thanks again to @DustinS for all the tips |
11-15-2017, 01:08 PM | #25 |
pessimistic skeptic
Your attention to detail is impressive (well ... budget too). I can't wait to see your car running.
The Following User Says Thank You to mrg666 For This Useful Post: | ILLSMOQ (11-16-2017) |
11-15-2017, 09:10 PM | #26 |
had to see how it all fits so today I did the mounts.
Loosely put the motor mounts in Then the motor Shot of the back of the motor Even though I beat the tunnel pretty good the transmission still didn’t fit...had to beat it some more Actually beat it in all the way to the top for the reverse lock out solenoid Passenger side Looks like enough room behind the intake Hood closes, but it’s close Moving quick! I’m gonna get stalled out waiting for those headers though. Pretty happy with the engine and transmission mount kit. Fit really well and clean with good clearance for the AC and heater lines. Good job Vorshlag! |
11-16-2017, 06:59 PM | #27 |
Took the transmission out to clearance a bit more and seal up some holes.
There was some tension on the bolts for the transmission mount. With all the side bracket bolts tight, the mount pulled the tunnel together a bit and when the bolts came out it opened back up throwing off the bolt hole alignment. I couldn’t get the bolts that hold mount bracket together back in. Took some turnbuckles and pulled the tunnel together some and got the holes close, then slotted the holes on the bracket 1/8” on either side which was enough to be able to easily install the bolts Currently, I’m able to get the transmission in and out with the engine in place...however I do not have the clutch installed. Once the clutch is in and attached to the engine I’m pretty sure installing the transmission is going to be impossible. It’s looking like the engine will have to be lifted and moved forward from the engine mounts to allow enough room to mate the transmission to it. Clutch should be here soon and we can find out. |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | mkivsoopra (11-16-2017) |
11-16-2017, 08:20 PM | #28 |
Drives: 2014 Subaru Forester
Lots to love in this thread, can't wait to see it all finished.
What are your plans for the exhaust? |
The Following User Says Thank You to tehShirt For This Useful Post: | ILLSMOQ (11-16-2017) |
Similar Threads | ||||
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 12:07 PM |
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 11:32 AM |
Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 02:07 PM |
