Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-22-2019, 01:22 AM | #15 | |
Drives: 2017 toyota 86
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | Irace86.2.0 (06-22-2019), kev0 (06-22-2019) |
06-22-2019, 01:26 AM | #16 |
In fact this car actually hates to be under 3k rpm. Especially boosted. IAM has never dropped when I知 over 3k rpm but I can稚 go more then 5mins in the 2-3k range with IAM dropping to about .88 it値l climb back pretty quick once I rev it a little. Tuner tried various things. Not much that could be done.
06-22-2019, 01:40 AM | #17 |
Rust bucket enthusiast
I also reside in Camp Flog. My car has been driven very hard, and the oil analysis shows that it's in peak condition (from a perspective of engine wear anyway).
If you want a car that demands being babied and driven conservatively, get a Triumph. |
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
06-22-2019, 02:22 AM | #18 |
Drives: 2017 Subaru BRZ Limited
I'm just jumping in to say that this car was designed with an engine that revs past 7k for a reason. It wants the revs. I make sure to bring it fully to temp and redline it at least once on every trip, and my accumulated knowledge over the years indicates that's actually a good way to keep things in tip-top shape. Redlining and engine for short bursts is a good thing, and colloquially is known around these parts as "italian tuning". As long as you aren't constantly bouncing off the rev limiter under no load in a parking lot the engine will be fine.
The Following User Says Thank You to Tristor For This Useful Post: | kev0 (06-22-2019) |
06-22-2019, 02:26 AM | #19 | |
Drives: Halo 86, '19
You might think you'd get terrible gas mileage but mileage is more about CONSISTENCY in power usage, rather than what RPM you use. You can cruise at 4K RPM and get 25-30 MPG depending on the gear, but that's because you *maintain* that RPM. You probably shouldn't but it's doable. While I have a lot of mechanical sympathy for my car it's 100% knowing when it's safe and acceptable for your engine to do its thing. Since it seems like you haven't actually ever wrung out this car, do this to get a feel for it. After giving the car a solid 15 minutes to warm up (that is, regular light driving in regular AT mode, non sport), put it to MT mode. Cruise at around 2.1-3K RPM at the appropriate gear at the appropriate speeds. If you want to accelerate harder, downshift and keep the RPMs above 3K when you go wide open throttle (not in 5th and 6th though, they're both far taller than the MT's 6th gear which means more strain on the engine; when in doubt, downshift). Keep throttle light to moderate in the 2-3K range. And I should stress this, to NOT shift like regular AT mode where it's literally always 1-2K. Because of a lot of complex hydraulic systems, they can run at much lower RPM than one would an MT car. While it seems obvious, I've seen a few people go to MT cars and try and shift quite literally as soon as possible and keep their RPMs ridiculously low to the point they lug the engine because their only experience with engines is that of an AT. |
The Following 2 Users Say Thank You to OwlDance For This Useful Post: | kev0 (06-22-2019), soundman98 (06-22-2019) |
06-22-2019, 02:57 AM | #20 | |
Drives: 2013 Scion FR-S Raven 6MT
A great deal of my around town driving is done in 3rd. Gotta keep it in the fun range. Sent from my moto g(6) using Tapatalk
Stay squatchy, my friends
06-22-2019, 03:55 AM | #21 | |
My car too was broken in straight from the dealers, paid cash, got the key, checked the fluids and drove it till the temps came up, maybe 5 minutes, and then..............gradually brought up the RPM in stages till 7k rpm, with a heap of engine braking, did that for a 30 minute session, then home for a full oil change, and whalla, engine, drivetrain and brakes broken in. Hard break ins to get a good ring to bore seal, and Italian tune ups are sorely overlooked. Sound engineering principles are forsaken on the recommendation of manufacturers. Imagine the liability claims if the manufacturers gave the hard break in procedures in the manual. "I'm sorry officer, but my manual said going full throttle through the gears is good for my ring to bore seal".
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
06-22-2019, 10:16 AM | #22 | |
ProCrastinationConsultant
The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
06-22-2019, 10:34 AM | #23 |
I am bone stock. The oem power level keeps me out of jail. Give me a hellcat, and watch for the police chase!
06-22-2019, 11:41 AM | #24 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Throwing a blower into steady 2k rpm is good money down a black hole.
Use the revs and you won't need FI. There were a young lad from Cork what got limericks and haiku confused.
"I gotta rock." -- Charley Brown |
06-22-2019, 12:37 PM | #25 |
Lol I知 just talking shit. That痴 actually impressive. I was 27mpg bone stock about 24mpg full bolt ons 22mpg with 4.56 Fd swap. And now about 17mpg with a sprintex. Although with each mod the car sees a lot more WOT redline pulls then before and to higher speeds, which is probably the main factor for the drop in mpg and not as much the mod itself.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | soundman98 (06-22-2019) |
06-22-2019, 02:01 PM | #26 |
Drives: 2013 FR-S Series 10
Cruising on a flat highway takes very little power, your car isn't being stressed at all. On a flat road with the manual you can get into 5th at 35mph and not stress it at all, providing you are not doing something dumb like flooring it at that gear.
06-22-2019, 02:04 PM | #27 |
Drives: 2013 frs red
Hard to believe op hasn't been run over from behind.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | radroach (06-22-2019) |
06-22-2019, 03:58 PM | #28 |
Drives: car
@kev0 this engine actually is fine cruising 2500 - 4500 rpm. This engine was made to breathe just fine in the upper midrange, and if you're driving around at 2000 RPM then you're practically lugging it, realize placing load on an engine that is barely above lugging at 2000 rpm probably puts more stress on your crank, bearings and pistons. At low rpm and high load, you can also risk low speed preignition, and you're compounding the issue by trying to throw boost at it.
At 3000-5000 rpm this car makes plenty of oil pressure to supply the bearings. It has optimal fuel swirl when its breathing properly, you probably get better combustion properties here. Cruising at 4000 rpm I can still easily get 25-30 mpg, which is what its rated for on the sticker. Seriously if you haven't tried driving the car around at higher rpms, I suggest trying it! Just change your oil regularly so it operates smoothly. |
Similar Threads | ||||
New to Health Insurance | LOLS2K | Off-Topic Lounge [WARNING: NO POLITICS] | 30 | 12-18-2015 09:21 PM |
frs for energy and health | charged86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 08-30-2013 12:49 PM |
Owner's manual slight confusion about engine break in period... | davey90 | AUSTRALIA | 48 | 09-05-2012 09:51 PM |
