Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-25-2014, 06:27 PM | #15 |
Drives: 2013 FR-S, 2012 MCS
Damn that seems like a steal!
03-25-2014, 06:41 PM | #16 | |
Site Moderator
Drives: Stuff
So no bias shift at all that I've noticed. I run equal pads front and rear, all aids off/etc. I can beat on it for 45-60 minutes during Chin's happy hours and with the right pads (Currenly using some CL pads, RC6 specifically) and the brakes are consistent from the first lap to the last lap. Going to be trying Project Mu 999 pads all around on April 6th at Sebring and I expect to like those as well. The best part is that the pads are cheaper than the same pad in the OEM size up front and are thicker, last longer (due to heat removal and the thicker puck) and the rotors last longer. A BBK isn't likely to be an economical choice for those who rarely track their cars (it won't be really) but for those that do it will pay itself off over a few seasons... plus the confidence I have in the brakes compared to the stock setup almost makes it worth it by itself. Now the Essex stuff isn't the best street car brakes around. They don't have anti rattle provisions and they tend to squeal like a pig with every pad I've used but that doesn't matter much to me anyways.. none of my cars have street pads (never know which I'll decide to track) so they all make some noise. :shrug:
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
03-25-2014, 09:39 PM | #17 |
Drives: Nevermorange FRS
"Find a need, Fill a need"
I like this for the occasional track day person, even a dedicated track day person. I like the OEM'ness of it and the price of it. I think it's great for the person who doesn't want to drop major coin on BBK and likes the OEM feel/look of the car. I think a brake pad that is a "compromise pad" (street & track) will work better with this setup vs OEM due to a larger heat sink. Even if you used it with the OEM pads, I bet they'd last a few more laps because the of greater cooling capacity (so maybe 5 laps instead of 3). The other thing I like is that by bringing the heat sink further away from the hub it transfers less braking heat into the wheel bearing and this makes bearings happy. Finally, it fills up the wheel space a bit more so the aesthetics are improved while still appearing it came from the factory that way. The only CON I see is the price. It's simply a bracket and a rotor. But hey, until there's 5-10 others doing the same thing why lower the price?
SCCA T4 - FRS
03-25-2014, 09:39 PM | #18 |
Off Topic
03-25-2014, 09:59 PM | #19 |
Site Moderator
Drives: Stuff
Piston area and line pressure determine that. The OEM calipers actually produce more torque per given line pressure than the WRX 4 pot fixed calipers, unless they changed the piston sizes. I honestly never measure the OEM ones but that was true with the WRX a few years ago.
-Dave
03-25-2014, 10:01 PM | #20 | |
Site Moderator
Drives: Stuff
I say that having never actually held the legacy bits in my hands though.. I just went to Essex instead.
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | rice_classic (03-25-2014) |
03-25-2014, 10:09 PM | #21 |
That's a common misconception, but you have to measure the surface area of pistons on only one side. It has to do with how pressure is applied and measured. Look at it this way... With a four piston caliper, each piston is matched by it's opposing piston, so the fluid pressure of the system is the same on each side, it is matched and equalized, not added. With a one-sided caliper, the piston(s) push against a bracket, which has to push back with equal force.
03-25-2014, 10:21 PM | #22 | |
Site Moderator
Drives: Stuff
-Dave
03-25-2014, 11:26 PM | #23 | |
Drives: 2015 Series.Blue
Yeah, ABS is going to cover up any balance issues (if you're doing the pedal dance I think it turns all the aides off). All four should lock at the same time, but it's theoretically impossible because of weight transfer. Personally I've been curious if the bolt on WRX setup is worse as the force at the pads is less but it's a larger rotor... I'll admit I like the look of the brembos vs the sliding caliper. |
03-25-2014, 11:28 PM | #24 |
Site Moderator
Drives: Stuff
Remove abs fuse
And a car brakes worse in abs so to keep it at the edge with more front bias means the rears are doing less. ABS on the track isn't really a goal.
-Dave
03-27-2014, 09:09 AM | #25 | |
Drives: 2013 Toyota 86 GTS
A day in the hills driving with a bunch of supercars and trying to pull it up from 100+mph multiple times all i got was fade. Bigger brakes with more thermal area might not make you stop any faster in a single stop, but it will on the 2nd and more, which is what happens on the street every weekend. |
03-27-2014, 09:28 AM | #26 | |
Site Moderator
Drives: Stuff
As for your driving maybe stop driving like an idiot? 100+mph on the street every weekend is just asking for it.
-Dave
The Following 5 Users Say Thank You to Dave-ROR For This Useful Post: | AyJay (05-15-2014), Calum (05-13-2014), DAEMANO (03-27-2014), SportInjected (03-27-2014), wparsons (03-27-2014) |
03-27-2014, 09:52 AM | #27 | |
Anyways, it is neither the fluid boiling or the pads. The aftermarket pads are at the thermal limits as are the stock rotors. The OEM brakes even with upgraded pads and lines are just not upto spirited street driving and are defiantly not upto track work. Does the average person need a 6 piston 350mm Brembo kit? Of course not. Do i even need that? Probably not. But something in between would be nice. |
03-27-2014, 10:02 AM | #28 | |
Drives: Attitude
Similar Threads | ||||
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
