Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-05-2023, 07:38 PM | #15 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Good deal. I have STI engine mounts, a Whiteline trans mount cradle, and a set of shifter linkage bushings in my to-do inventory. Maybe one these days they’ll graduate to the been-done inventory. Just need to show them a few YouTube videos so they can install themselves.
Slow is smooth, and smooth is fast
04-06-2023, 09:49 AM | #16 |
Drives: Toyota GT86
Did you guys use loctite when reinstalling the subframe bolts ? If so... blue or red
Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-06-2023, 10:47 AM | #17 | |
Drives: Crapcan
No. If anything, I recommend neverseize.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | autoracer86 (04-06-2023), Capt Spaulding (04-06-2023) |
04-06-2023, 01:01 PM | #18 |
Persona Non Grata
I’m squarely with NHM. I recommend antiseize.
The Following User Says Thank You to Capt Spaulding For This Useful Post: | NoHaveMSG (04-06-2023) |
04-06-2023, 02:06 PM | #19 |
Drives: Toyota GT86
Oh what is NHM
04-06-2023, 04:02 PM | #20 |
Drives: Crapcan
04-06-2023, 04:48 PM | #21 |
Drives: Toyota GT86
06-21-2023, 03:16 PM | #22 |
Drives: 2013 FRS
Thanks for making this thread.
My whiteline subframe bushings are coming in today. I'm also having the PBM diff riser bushings installed... fingers crossed for no headaches...
06-22-2023, 10:17 AM | #23 |
Drives: 2014 MT Asphalt FR-S
My subframe + diff bushing combo definitely increased NVH. Although not terrible, it is noticeable. I have a distinct "hum" around the 3k rpm range, however, the driving benefits outweigh the noise increase.
The Following User Says Thank You to Grivo For This Useful Post: | strat61caster (06-22-2023) |
06-22-2023, 02:20 PM | #24 |
I have the Whiteline subframe inserts and diff inserts.
Doing some exprimenting, I just removed the front lower diff inserts and made a large reduction in noise for my car. - Andrew Last edited by Racecomp Engineering; 06-22-2023 at 04:12 PM. |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Thefalls (06-22-2023) |
06-22-2023, 03:05 PM | #25 |
Drives: Corolla GT
I went with the Whiteline subframe inserts and did not really like them. Then changed them to the STI stoppers, I did only the uppers and changed all the subframe bolts to STI ones
(they are longer). And never looked back ever since. |
06-22-2023, 03:22 PM | #26 | |
- Andrew |
06-22-2023, 04:10 PM | #27 | |
Drives: '22 BRZ
Same for me. The front bushings on the diff are brutal. I pulled both upper and lower, but the lowers seemed to be the majority of the noise.
The Following User Says Thank You to DocWalt For This Useful Post: | Racecomp Engineering (06-22-2023) |
06-22-2023, 04:48 PM | #28 |
Drives: 2013 BRZ HKS Turbo
I'll add my experience...
I installed only the Parts Shop Max solid diff risers, and went from breaking an axle every drift event to not breaking one in 10 events and 5000+ miles. Minimal NVH increase.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
Similar Threads | ||||
Subframe Bushings and Alignment (Toe) | gonzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-16-2018 11:06 PM |
FS: SuperPro subframe inserts & LCA inner bushings | xn7485 | Brakes, Suspension, Chassis | 1 | 09-13-2017 03:23 AM |
Whos running PBM subframe bushings? | ft86xtc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-03-2016 12:31 PM |
rear subframe bushings? | Roadcone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-09-2014 09:25 PM |
Whiteline subframe bushings | Proof | Brakes, Suspension, Chassis | 1 | 03-18-2014 12:14 PM |
