Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-06-2013, 11:33 PM | #15 |
Senior Addict
Drives: 86 GT
02-07-2013, 12:00 AM | #16 |
Drives: 2013 Subaru BR-Z Limited
Running Eibach sportlines on stock struts and they handle amazing. Its all in the install. These struts work well a little deeper in the stroke.
02-07-2013, 12:11 AM | #17 |
AutoX-10/10ths every run
RCEs on stock struts, no problem here. Didn't use an impact at any point of the dis-assembly or assembly process. I ended up using a t-handle allen and a spark plug tool with a open ended wrench that fit the spark plug tool.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
02-07-2013, 12:55 AM | #18 |
Site Moderator
Drives: Stuff
Basically all lowering springs are designed for OEM dampers.
Sure, OEM dampers with 80k may not like the increased rates, but new dampers (all of these cars currently) will be just fine.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
02-07-2013, 02:45 AM | #19 |
Drives: 1994 NA8
02-07-2013, 07:48 AM | #20 |
I've seen it before and typically on springs like the Sportlines that lower a car a large amount.
As for using and impact for installation, as long as the shaft is held there should be no issues. Tony |
02-07-2013, 08:46 AM | #21 |
Site Moderator
Drives: Stuff
I'd agree with that but that's like saying don't track your car because wheel bearings won't last as long.
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | Jackson (02-07-2013) |
02-07-2013, 08:48 AM | #22 | |
Site Moderator
Drives: Stuff
I ran the sportlines for thousands of miles and my dampers are still just fine. I'd have no problem running them for tens of thousands if only Sebring's Turn 1 and 17 were smoother.. need higher rates to lower the car at all to avoid bumpstops
-Dave
02-13-2013, 07:24 PM | #23 |
Drives: SWP Subaru BRZ Sport-Tech 6AT
Brought it to the garage last night and the other strut was leaking.. so both my rears are done and need to be replaced.. going back to stock height in the meantime until I get coilovers..
Hopefully my front ones don't go before putting the stock springs back on.. |
02-14-2013, 12:54 PM | #24 | |
Drives: E46 M3 (daily) / EG Civic (track)
If you used an impact gun during the installation I'm 99.9% sure the internals of the shock came disassembled. There are quite a few people this has happened to. |
02-14-2013, 02:09 PM | #25 |
Most shock manufacturers suggest replacing them around every 50k miles (80k km's), they'll easily last that long on sane lowering springs (ie not a 3" drop with stupidly high rates). Might not last as long as stock, but that's the same as stickier tires, oil, gas, etc when driving a car hard.
Similar Threads | ||||
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ | Kevin@RAD | Announcements, Contests, Giveaways | 48 | 06-07-2013 02:19 PM |
Debating between Sportlines or STANCE coils.. | wWaldo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 01-23-2013 11:14 AM |
eibach sportlines clunking.. | frsguy707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 10-24-2012 11:42 AM |
Eibach Sportlines Finally Available! | PRO Import Tuners | Brakes, Suspension, Chassis | 1 | 08-22-2012 07:42 PM |
