04-13-2015, 03:21 AM | #183 |
Drives: GT86
I do the above at first, improvement for sure but only seems to work the first time from flash. Then when the engine is on temp, switch off engine, put on ignition fully but do not start and press the throttle fully and release 20 times (in like 15s) and start engine. Throttle becomes lightning like half the time, not sure why not always, but a great feeling 10min after a reflesh. Even if it was successful , it dumbs down again in the next drives, if I notice it being lazy again to the degree it annoys me, I just pull over (or at the lights when I know I've got the time) and do the throttle thing (just waiting 20s x2 doesn't seem to work then), it usually works but not always. Must be doing something differently or it's related to another parameter (ECT?)?
YMMV Would really love to hear the definitive 'recipe' |
04-13-2015, 03:28 AM | #184 |
Drives: 2014 Argento FRS
Btw, the steps I posted above^ are from Steve99's post at the beginning of this thread. Don't want to take credit away from the guy.
04-13-2015, 06:47 AM | #185 | |
SLO NO MO
Should only take about 30 mins of driving in my experience. Are you sure you didn't hit the throttle while the engine started right after flashing? You typically have to give it a minute to idle or you mess up the throttle response. Otherwise, reflash the tune you want (no need to go stock first) then turn on ignition (no start) hit gas 20 times in quick succession, turn off ignition, turn on again (no start), hit gas 20 times again, then start ignition. |
04-13-2015, 06:57 AM | #186 |
04-13-2015, 07:26 AM | #187 | |
Drives: Subaru BRZ Limited
04-15-2015, 12:41 AM | #189 |
Drives: '13 SSM BRZ Limited 6MT
I thought i was imagining things but now i'm fairly certain my logs are missing some data. I drove around for a good hour to three different locations and did a WOT along the way, but that WOT is not showing up at all. All my files are updated, template is on 7.1.
http://datazap.me/u/tracerit/drive-a...0&data=2-10-13 I left the log recording from when i left home and back. I stopped at three locations, but according to the dip in oil temp right in the middle of the log, it only logged one stop. |
04-15-2015, 01:44 AM | #190 | |
The Following User Says Thank You to steve99 For This Useful Post: | tracerit (04-15-2015) |
04-15-2015, 01:47 AM | #191 |
ah, that's right. so it seems the recording may actually stop after 20 minutes, but there is no indication that it has stopped as the blinking disk icon keeps on blinking.
04-15-2015, 03:13 AM | #192 |
Drives: '18 STi
Can someone make a video of how to adjust the Cold Start quieter? I've done extensive research on the forums about this already and have an idea what to do, but am afraid that if I screw something up... my car would be [insert something terrible/ "bricked ecu"].
04-15-2015, 05:43 AM | #193 | |
have a read of links below , tune tweaks , romraider tips you will be fine |
04-16-2015, 08:30 PM | #194 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Anybody know the difference between the 2.063 and the 1.59 OTS tunes? Like aggressive timing etc? I'm aware the 2.063 is specifically for NA, which is why i'm running that currently. Just curious if anybody has compared them in romraider
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
04-16-2015, 10:33 PM | #195 |
1.x or 2.x tunes are same the ie not more agressive , just more updates revions and more refined. Best to run the latest revision ie 2.06x, the 2.06x tunes are also based on the later revision factory roms , just make sure you use the matching definition files if your editing tunes .
The Following 2 Users Say Thank You to steve99 For This Useful Post: | CosmicKnight (04-16-2015), flippy (04-17-2015) |
04-17-2015, 12:45 AM | #196 |
Drives: 2013 Firestorm Scion FRS
Why does the website give me an old version?
i tried the control+refresh didnt work how do i get it to work? ive been using an old ass template from last year fml haha im using google chrome btw |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
