09-16-2013, 11:57 AM | #1681 |
NW Region Moderator
Drives: FR-S No More
Automatically turn off your traction control...
http://www.ft86club.com/forums/showthread.php?t=10621
09-16-2013, 12:18 PM | #1682 | |
Grip>Slip
edit: doh, somehow missed your huge text at the top of the post. |
09-16-2013, 12:28 PM | #1683 |
NW Region Moderator
I am still using my original method without any issues since day one. Works perfectly.
The new method is simpler and should work better, so I would try that first.
09-16-2013, 12:40 PM | #1684 |
WUB WUB
Drives: 2013 Firestorm
I did the FA20club kit that came with injectors and pump. I'm still running the stock pump, and I need to get the time to do some logging.
09-16-2013, 04:58 PM | #1685 | |
Drives: 2013 Black FR-S
This ecu or motor doesn't like boost and timing advance in this rpm zone. I believe I read that cylinder pressures are extremely high here. It is up to your tuner to get the timing right so that the ecu isn't pulling timing. Keeping an eye on the advance multiplier also can tell you if your motor is often pulling timing due to knock. Ideally you want the advance multiplier at 1. The map I am running now has the AM pegged at 1 all the time which is great.
09-16-2013, 05:05 PM | #1686 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
What are your afr while the happens? Part throttle or full?
09-16-2013, 05:13 PM | #1687 |
WUB WUB
Its more pronounced at part throttle.
The Following User Says Thank You to wrxgoose For This Useful Post: | tech4pdx (09-16-2013) |
09-16-2013, 05:14 PM | #1688 |
In Test:Oil Fed SC
09-16-2013, 06:14 PM | #1689 |
Make love
Drives: H8R.. Not really
I too have experienced this part throttle hesitation from 2k-3k. My tuner can smooth it out though. BrzEdit is the tool.
I think the FA20 motor in general is pretty anemic below 3k, fi or not. You gotta drive it hard. |
09-16-2013, 07:04 PM | #1690 |
Drives: 2013 Asphalt FR-S
I don't know. After coming from several Hondas, this thing pulls pretty hard below 3k for an N/A 2.0. The tune helped quite a bit though...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
09-16-2013, 07:13 PM | #1691 |
Make love
@Opposed.. You may be right. I don't claim to be an expert on small displacement high strung motors. I am used to having massive amounts of torque available at low to midrange rpms. There is a reason why the phrase "no replacement for displacement" was coined. Granted, turbos can change that notion to a degree. I do enjoy this car in FI form nonetheless, especially past 4k rpm.
The Following User Says Thank You to tech4pdx For This Useful Post: | 448hpsti (09-16-2013) |
09-16-2013, 07:35 PM | #1692 |
Yes this is where I noticed it too.
09-16-2013, 07:50 PM | #1693 |
WUB WUB
unfortunately no. not yet.
I really need to get @JuniorAWD to check it out. Once i get a new clutch, going to do more logging.
09-16-2013, 08:09 PM | #1694 | |
In Test:Oil Fed SC
I use the innovate mtx and like it, go get one on your car NOW best price I saw was on amazon... |
The Following User Says Thank You to 448hpsti For This Useful Post: | Sportsguy83 (09-17-2013) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
