Old 06-28-2014, 05:25 PM   #1457
BadBRZ
Drives: Subaru
who was the guy that got screwed by toni here real recently about the ecutek license?
BadBRZ is offline   Reply With Quote
Old 06-28-2014, 06:49 PM   #1458
johnnyb305mia
Drives: 14 BRZ Limited
Yes on E85
johnnyb305mia is offline   Reply With Quote
Old 06-30-2014, 02:26 PM   #1459
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@Ryan P
http://www.ft86club.com/forums/showthread.php?t=65430
Old 06-30-2014, 09:30 PM   #1460
Ryan P
Bug both ecutek and toni at the same time. You will get your license
Ryan P is offline   Reply With Quote
Old 07-07-2014, 02:19 PM   #1461
johnnyb305mia
So going to be doing the exhaust prob in 2 weeks and then hitting the dyno again to retune for that mod and she should all be done for now as far as boost and all of that goes i will post results accordingly lets see most likely going to go with 2.5" due to yeilding a slightly higher back pressure to deliver more torque as opposed to the 3" which im sure will make slightly more power but less torque so lets see what happens and once the lotlr is buklt than a full 3" set up will be done
Old 07-07-2014, 02:31 PM   #1462
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
that doesn't make any sense. Backpressure doesn't make torque. Improperly sized exhausts whether too small OR too large cause poor flow. A smaller but still properly sized exhaust will lead to more gains where the engine produces a slower timed and lower volume exhaust pulse. Exhaust size is based on hp goal, displacement, firing order, rpm.....etc.
Old 07-07-2014, 02:38 PM   #1463
Dipstik-sportech
Dipstik-sportech's Avatar
Back pressure increases torque??!! I'm gonna drop mine down to a 1.5" system then I'll be in diesel territory for sure.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Hawaiian (07-09-2014)
Old 07-07-2014, 02:42 PM   #1464
King Tut
NASA SpecE30 Racer
King Tut's Avatar
IN for more backpressure and torque. Will that fix the dip?
Old 07-07-2014, 02:44 PM   #1465
Reaper
Reaper's Avatar
Drives: violent
im actually going to run my ducati engines exhaust INTO my tailpipe to really up the pressure. More heat and pressure means more powa right?
The Following User Says Thank You to Reaper For This Useful Post:
nelsmar (07-07-2014)
Old 07-07-2014, 02:45 PM   #1466
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Don't stop there, go metric and get down to 1cm. But you'll loose power.
I know, run 1 bank on a tiny exhaust and the other with a dustbin sized exhaust, massive power and torque.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
Dipstik-sportech (07-07-2014)
Old 07-07-2014, 02:46 PM   #1467
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I needs more power on my Ducati. I didn't realize how few horses it has.
Old 07-07-2014, 03:30 PM   #1468
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Started my stage 1.5 install over the weekend. So far the only issue I've found is that the vband flange for the wastegate is warped, a little sanding and RBT and we're on our way. Getting ready to start up the engine this week.
Everything else was test fitted and appears to line up.
What does everyone think the limit of 770CC injectors and E85 would be?
crazyfrenchbiker is offline   Reply With Quote
Old 07-07-2014, 03:37 PM   #1469
lp87
Drives: 2013 swp brz
is any modification of the car needed for the base kit, if I buy the pre-welded oil pan? Any tips on the kit install?
lp87 is offline   Reply With Quote
Old 07-07-2014, 03:39 PM   #1470
nelsmar
Depends on turbo, tuning strategy, exhaust, tuner, how aggressive of a tune, etc.
I am at 20-22PSI @ ~80% IDC on 540CC w/ a DW65c pump on a stock midpipe with a GTX3071 (NOT an FA20club kit). Every tuner handles injection differently. I run pretty heavy on the DI injection on my own car.
What are your power goals? 770 you could possibly hit the wall of a pump if your tuner is heavier on port injection and start maxing out in the high 400's but it may hold up 500+. Running heavy on the DI 500-600+ should be achievable as it has its own fuel pump. It is however more than most people are wanting to put down either way so it all depends on your goals!
My flickr - Canibeat
Local magazine scout
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
