05-24-2013, 12:41 PM | #211 |
I drive at ~80mph regularly, which sits me at about 3500rpm+. So, I figure with this final drive, it should just encourage me to drive a little slower, lol.
Can't do this mod for a while but I'm planning on it |
05-25-2013, 11:01 AM | #212 |
Drives: Toyota 86 TRD Version AT
Car is going in on tuesday for the install. Will update as soon as its finished.
05-28-2013, 02:50 AM | #213 |
Update: Car is at the shop now. Differential is out and dissassembled as I am typing this. Install is a pretty straightforward affair. Only difficulty is pressing the bearing into the new pinion gear. Changing the ring gear is pretty easy, just reverse the dissasembly method. Will post pics later after the install.
The Following 3 Users Say Thank You to Tye300 For This Useful Post: |
05-28-2013, 02:59 AM | #214 |
Drives: 2013 FR-S, 2016 Miata Club
Let us know what shims they use. I know all builds will be different. But I'm just curious. Thanks.
05-28-2013, 03:29 AM | #215 | |
Drives: Toyota 86/VW Golf GT
05-28-2013, 07:22 AM | #216 |
Drives: the girls crazy
@Tye300 yeah please come back with more details about everything, I'm doing that mod very soon, just waiting @Silverdub to be ready. Did you keep the original bearing or bought new one? How did they put back the bearing on the new pinion? ect the more the better haha.
thanks
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
05-28-2013, 02:01 PM | #217 | |||
Well the install with pics and vids are on my build page. You can find it here:
http://www.ft86club.com/forums/showt...711#post964711 Quote:
The Following 4 Users Say Thank You to Tye300 For This Useful Post: | Lonewolf (05-28-2013), makesdrivingfunagain (08-10-2016), whataboutbob (07-23-2014), zohare (04-25-2014) |
05-28-2013, 08:32 PM | #218 |
Nice review. This mod is on my "to do" list now.
The Following User Says Thank You to Captain Insano For This Useful Post: | Tye300 (05-28-2013) |
05-28-2013, 08:58 PM | #219 | |
Grip>Slip
05-28-2013, 09:06 PM | #220 |
Drives: FRS
That is correct. Racecomp only used one shim I believe. Not sure how you determine the number necessary.... But apparently his diff is working.
05-28-2013, 11:47 PM | #221 | ||||
Your welcome bro. Forgot to comment on that. I actually was expecting something to go wrong with the new ratios. Apparently not, the car seems to shift normally during normal AT mode. It just shifts at the same shift points if you just drive normally. The gear indicator seems fine and reads the correct gear, so the ecu doesn't seem to mind the new final drive. During SPORT mode, the revs climb out to redline like stock but is much faster because of the final drive, the same as the video in manual paddle shift mode. |
05-29-2013, 12:50 AM | #222 |
Drives: Moped
The 4.55 rears paired with a cf driveshaft would probably make the car feel like driving a stick of well-balanced butter....
The Following User Says Thank You to Lonewolf For This Useful Post: | TouchMyHonda (07-22-2013) |
05-29-2013, 01:20 AM | #223 |
Seņor Member
How did you determin if you had the correct endplay for the bearings?
1974 TA22 Celica
2013 86 GT |
05-29-2013, 08:23 AM | #224 |
We took measurements of both ring gears. Both had 41 teeth, the stock one was a little bit thinner than the new one. The stock pinion gear had 10 teeth while the new one had 9. 41/9=4.556. The kit basically come with a pinion gear, ring gear, new screws and shims. We just used the new ones and it all bolted up fine. There was a hiccup with the pinion gear though. During the first reassembly, we used the new pinion sleeve that came with the kit, the pinion gear had a little play if you tug on it. We dissasembled the differential again and tried the old one. Apparently the two sleeves have different lenghts, we tried using the old one and there was no play anymore. Maybe we just got lucky with the bearing?
The Following User Says Thank You to Tye300 For This Useful Post: | itdansharpe (06-04-2013) |
Tags |
cusco final drive |
Similar Threads | ||||
PST Carbon Fiber Drive Shaft Installed | msile | Engine, Exhaust, Transmission | 155 | 08-28-2018 07:53 PM |
Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 12:17 PM |
Is my Cusco catch can correctly installed? | wbradley | Engine, Exhaust, Transmission | 9 | 02-24-2014 09:49 PM |
Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 06:54 PM |
