Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-22-2013, 10:59 PM | #29 |
Drives: 13' BRZ, 05' 325xi, 02' RAV4
Yeah but i feel as if i go catless my sound will be very similar to what was shown in the video as opposed to going catted the sound may differ because in this video the pipe was a invidia catless downpipe so i figure the nameless catless will have a similar sound as opposed to nameless catted... any thoughts???
05-23-2013, 08:13 AM | #30 | |
I Love custom Turbo kits
Drives: Limited BRZ
05-23-2013, 11:26 PM | #31 |
One more question man, appreciate the help though! What does it mean when it says exhaust bushings??? So if i purchase the "no mufflers" that is loudest out of the 4" or 5"? Thanks again
05-24-2013, 07:49 AM | #32 |
Drives: Limited BRZ
I forgot about that part of your question. The bushings are rubber or compound hangers that hold your exhaust in place. Do you plan to race your car at all? If yes, you should get at least two for the farthest back ones. IF you plan on racing a lot, get the 5 and replace them all.
05-24-2013, 10:24 AM | #33 | |
@brzadmir, the point of the poly bushings is presumably to help better stabilize the exhaust over the stock rubber bushings. If your exhaust is bouncing around and hitting anything, you need more. How many you need up front is anyone's guess. My guess is zero, but I'm planning on 2, and I will be racing my car "kind of a lot." On the WRX the point of poly hangers is that they're longer than stock, in case your exhaust doesn't fit quite right. But I haven't seen anything that indicates these are longer, and in any case, after 6 different exhausts on the WRX I never found one that needed longer hangers.
05-24-2013, 10:30 AM | #34 | |
Drives: Limited BRZ
If you race "a lot" it means you regularly do track, are an experienced driver and will be pushing the car to the max. Hence, changing the 5 bushings is highly recommended.
05-24-2013, 10:40 AM | #35 | |
If anyone is going to bang a ***** on the bottom side of the **** it's me. Seriously though, you put more in until the exhaust doesn't hit anything. Since you're ordering, guess how many you'll need and hope it's enough. My opinion without any evidence to back it up is get at least 2 and you'll be fine.
05-24-2013, 10:42 AM | #36 |
Drives: Limited BRZ
Every rule has an exception In any case, I agree, as a general rule two should be fine.
05-24-2013, 01:23 PM | #37 | |
Drives: '13 BRZ Ltd WRB
I had both long and standard on my 05 WRX (Invidia N1 catback). The short ones made the exhaust bump the underside of the car, but the XLs made it look horrible. I ended up just banging a dent in the pipe and using the standard length hangers. No more knockin! Don't be caught with a floppy pipe! I'm all for replacing 4. That 5th one was a PITA to get installed on the WRX so I have no intention of bothering with this car. They're so cheap anyway, why just buy two?
The Following User Says Thank You to 2point0 For This Useful Post: | Sportsguy83 (05-24-2013) |
05-24-2013, 03:53 PM | #38 |
Drives: Limited BRZ
Very well written. Wanted to point out the 5th is fairly easy on our cars.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | 2point0 (05-24-2013) |
09-20-2014, 06:39 PM | #39 |
I wanna go fast
Drives: 2013 FR-S 6MT
OK OK... so how many pieces are there between the exhaust ports and the exhaust tips?
headers - over pipe - down pipe - mid pipe - axle back ?? |
09-20-2014, 09:12 PM | #40 |
Because compromise ®
Drives: Red Herring
Depends on whether you count clamps, nuts, bolts and gaskets.
The Following User Says Thank You to Captain Snooze For This Useful Post: | 2much (09-20-2014) |
Similar Threads | ||||
Torque App - What does your layout look like? | DriftEightSix | Electronics | Audio | NAV | Infotainment | 27 | 05-01-2016 08:52 PM |
TRD Dual or Quad Exhaust? Confused? | sharkasport | AUSTRALIA | 16 | 12-10-2012 09:07 PM |
New forum layout | ahausheer | Off-Topic Lounge [WARNING: NO POLITICS] | 85 | 04-17-2012 02:56 PM |
RHD Engine bay layout from: CarTop (Japanese magazine). VLN car. | sirus | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 11-22-2011 12:09 PM |
FT-86 vote for you engine layout 2.0L NA vs 2.0L Turbo vs 6 banger | Allch Chcar | Scion FR-S / Toyota 86 GT86 General Forum | 87 | 08-17-2011 02:31 AM |
