Old 03-12-2013, 09:40 AM   #71
runny_yolk
Drives: minivan
Originally Posted by Mo707 View Post
does it matter which one is the + and witch one is the -?
And where did you put the ground wire?
I don't know if + and - matter since it's just a bulb, but why not take time to get it "right"? As far as ground, practically anywhere on the metal body would be fine but there is actually a factory ground anchor/bolt located in the trunk. See this post (which has a pretty helpful video of disassembly of various panels. You'll show you how to tap into the factory ground.
http://www.ft86club.com/forums/showp...36&postcount=2
runny_yolk is offline   Reply With Quote
The Following User Says Thank You to runny_yolk For This Useful Post:
Mo707 (03-31-2013)
Old 04-09-2013, 11:29 AM   #72
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
Just wanted to post a big thanks to this thread for helping me complete this mod!
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Old 04-25-2013, 09:48 PM   #73
dawnst3ar
Drives: 2013 MT FR-S Asphalt
Ok, stupid question - when using the LEDs, did you use two separate bulbs, or just one with three wires? I can't seem to find anything that matches this configuration, but I am hesitant to use two sets of bulbs because I want it to act like a dual-filament light and to just put one hole in the housing. Has anyone done this?
@kask2_6.0
dawnst3ar is offline   Reply With Quote
Old 04-26-2013, 08:08 PM   #74
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
@kask2_6.0
You can use a single, dual intensity LED. Here are a few: http://www.superbrightleds.com/searc...,Red,136,4639:
This is the one I'm using: http://www.superbrightleds.com/morei...sher/925/2276/
kask2_6.0 is offline   Reply With Quote
Old 04-27-2013, 05:00 AM   #75
dawnst3ar
Went ahead and did it with two, gotta say, it was a bit harder than expected. Finding the OEM ground means taking out your back passenger seat and the moulding on that side. Thanks for the help!
Old 05-15-2013, 03:04 AM   #76
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Great DIY! I'll be also doing this but can't decide if I want one or two leds. Thanks.
TRD_07 is offline   Reply With Quote
Old 05-24-2013, 01:21 PM   #77
2_slo
2_slo's Avatar
Drives: 2013 Crystal Black BRZ Limited
I just did mine with dual filament red led bulb (1157) from Autostoners....the twin pack led bulbs and socket were like 16 bucks out the door I think... Turned out awesome.
2_slo is offline   Reply With Quote
Old 05-24-2013, 05:08 PM   #78
Gunman
Drives: 2019 Mazda Miata RF
There is a ground on the rear wall, ie inside the trunk, opposite the license plate.
The Following User Says Thank You to Gunman For This Useful Post:
Trap63 (07-31-2013)
Old 06-04-2013, 04:28 PM   #79
dawnst3ar
you're kidding me, right?
Old 06-04-2013, 09:35 PM   #80
Gunman
Well, there is on the BRZ, that's where I grounded mine.
Not my pic, but this shows it.
Trap63 (07-31-2013)
Old 07-08-2013, 12:33 PM   #81
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Originally Posted by ZILLA View Post
Here ya go =)
Dorman/Brake Lamp Socket
Part Number: 85814
http://www.autozone.com/autozone/par...er=600643_0_0_
Thanks for the awesome DIY. I was able to do this yesterday. One question though. Are you able to twist the socket to lock it in or is the grey plastic housing that you drilled through too thick? I just happened to get the same socket as you but I'm having issue with twisting the socket to get it to lock.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 07-24-2013, 10:59 PM   #82
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Just did this yesterday. For 8 sockets and bulbs left over. All work lol it was cheaper to buy 10 of each Dom my source then 1 of each on eBay lmao.
Brakeing illuminates my second bulb, first bulb illuminates with driving lights. I also cleaned it up like Zola with the plastic cover over the wires and ran tem through the Oem rubber plug. Amazing write up!
Only difficult thing for me was removing the damn light assembly with out removing muffler or rear bumper. I'm over 6 feet tall..so I got big hands lol.
FRSfan111 is offline   Reply With Quote
Old 07-29-2013, 12:13 AM   #83
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I want to use the dual filament/bright LED, but what is the housing part number you used for it. Thanks
DrDuquette is offline   Reply With Quote
Old 09-06-2013, 11:16 PM   #84
DrDuquette
DrDuquette's Avatar
Yes yes
Originally Posted by Fenrir View Post
Just FYI:
It's technically illegal to have the rear fog light (or really ANY fog lights) on during fair weather conditions. I doubt you'll find a cop in the US who will ticket you for it, though. The lights are aimed in such a way that they can be distracting to drivers, especially rear fog lights. Rear fogs are aimed directly at driver eye-level so as to increase visibility in foggy conditions (as you would expect, given their name).
Also, it's doubly illegal to have a fog light used as both a fog AND a rear brake light. There are strict regulations on this. Again, I highly doubt you're going to find anyone of any official capacity who will cite you on it, but there it is.
On the flip-side of the coin, many European cars DO have the rear fog light retrofitted into a brake light on the USDM models. They usually have the reflectors changed and are aimed differently, though.
Just be aware that modifying the lighting on your car shouldn't be taken lightly. There are a ton of regulations on brightness, light aiming, position on the vehicle, etc. Modifying the lighting (which is safety equipment) on a vehicle can be dangerous to yourself and others around you.
Hope that doesn't count as random crap
To add. Tinting your tail lights is asking for trouble. If someone rear ends you, it my end up being your fault. They could say in court that they didn't see your brake lights because they were not bright enough/legal.
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) -- General Topics 21 11-23-2015 03:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) -- General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
