Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-27-2013, 01:58 PM | #1 |
Drives: Scion FR-S Black
Exhaust and turbo comparable ?
So this is either going to be a good question or a really stupid question!
Do you need to have a special mid pipe or over pipe in an exhaust system when you plan to have a turbo? |
03-27-2013, 02:14 PM | #2 |
Depending on the placement of the turbo, it could radically change the position and flow of the exhaust.
If you buy a kit, most will come with flanges that replace the stock part in the exhaust that the turbo will be inserted to. Custom setups may require you to do some modifications to get the turbo in there. simple answer: yes :P the car wasn't designed with a turbo in it, so the exhaust does not have the hookups for it to be installed. |
03-27-2013, 04:58 PM | #3 |
I thought so that is where the dump pipe is for, right? If I buy borla exhaust what kinda modifications am I going to have to do?
03-27-2013, 05:24 PM | #4 |
Drives: 2003 Subaru Outback
The BRZ/FRS exhaust is as follows:
When going turbo, a majority of kits will replace the header with a turbo manifold AKA a header that's reworked to connected to the turbo. Directly off the turbo is the downpipe(most commonly known as) that is I believe every case thus far connects to the factory front pipe. "Header-back" exhaust kits will bolt up to pretty much every turbo kit, your only real decision you have to make is if you want single exit, duel exit etc. You mentioned Borla exhaust, what components do you have? |
03-27-2013, 09:52 PM | #6 |
Drives: Scion FRS
Just a thought. I think T1R dual exhaust will do the job ! I used to have it on my s2k with Greddy turbo kit and it works very well !
03-27-2013, 09:56 PM | #7 |
Catback will be directly compatible with every kit, minus a rear mounted turbo, which I only know of one kit like that anyway.
04-09-2013, 04:19 AM | #9 |
Drives: Subaru BRZ
This thread (and OP question) were incredibly helpful to me! as i have an amazing catback invidia exhaust, and I'm considering getting the other header back components.
Similar Threads | ||||
Treadstone FR-S/BRZ Turbo Kit Exhaust Pictures | David2.0@Treadstone | Engine, Exhaust, Transmission | 21 | 03-28-2013 05:46 PM |
Coilover make and setting comparable to stock | VENOM~ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 03-03-2013 03:13 AM |
Best Exhaust for turbo application | Jamifra | Engine, Exhaust, Transmission | 23 | 09-19-2012 06:57 PM |
Comparable test drives? | ucmecheng | FR-S / BRZ vs.... | 18 | 04-26-2012 05:38 PM |
FT-86 may be comparable to... a Saturn Sky? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 122 | 06-14-2011 02:45 AM |
