Old 02-14-2013, 09:08 PM   #1
Frsexxxy
Drives: White Virgin frs
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter
Dry preferably. I want to swap it out every 6 months. And did anybody else see the increase in price on the srt frs exhaust? The prices went up on that. Good thing I got ordered mine while it was still cheap. I was having trouble choosing between that and injen exhaust.
Frsexxxy is offline   Reply With Quote
Old 02-14-2013, 11:38 PM   #2
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
It uses an Ea-nano dry filter(Dont know how many inch). But why wont you just buy a cleaning kit for it instead?
LeeMaster is offline   Reply With Quote
Old 02-15-2013, 12:23 AM   #3
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
^^^ +1
Why would you buy a new one when the filter can be cleaned and reused....seems like a waste of money to me.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
31katys (02-16-2013)
Old 02-15-2013, 01:59 AM   #4
Frsexxxy
Because you can't really trust those cleaning kits. It messed up my tundra one time. Because supposedly it didn't dry properly!? Had it drying for 3 days. The car just completely died within a couple weeks. Brand new maybe only 1k miles on it! . I guess I could buy just one and have the old one left drying for a whopping 6 months until I swap it out again and do the same to the new one.
Old 02-15-2013, 02:37 AM   #5
LeeMaster
Red wine
Explain the method you used for drying, because I have cleaned a few intakes/drop in filters and all my cars are still running fine. Which brand/filter were you using on your Tundra?
Old 02-15-2013, 07:23 PM   #6
Frsexxxy
I was using a K&n intake and K&n cleanser. I swear buddy. My car just shut down in the middle of the road, in the dark. Not a single light could turn on, and it was all black! I left it in my garage for 3 days with the bottom end opening facing upwards.
Made me want to barf
Old 02-15-2013, 08:24 PM   #7
NicoSuave84
Executive Dips of Memphis
Drives: '13 Scion FR-S - 2 tone Asphalt/WRB
Yes, it is a dry filter. I don't know what kind of cleaning kit you would use on it. I'm pretty sure that's only for oiled filters like K&N. You just blow air out from the inside of the filter or vacuum it from the outside with a brush attachment.
NicoSuave84 is offline   Reply With Quote
Old 02-15-2013, 08:30 PM   #8
NicoSuave84
The model of the filter is x-1021.
Old 02-16-2013, 11:42 AM   #9
LeeMaster
Red wine
So did you leave it in the garage for 3 days without turning it around? You should be turning it around and letting the water work its way through the middle back down. If you dont, there is a chance that water was still on the filter. Which brings me to the next question, how much oil did you spray?
Old 02-16-2013, 01:27 PM   #10
Sony
Sony's Avatar
If all the lights in your car wouldn't turn on...that doesn't sound like an air filter problem to me. Sounds electrical...you sure it was the filter that caused it? Just wondering because those symptoms do not sound like an air filter/clogged MAF problem.
Old 02-17-2013, 07:01 PM   #11
Frsexxxy
It was a few. Shut off right after installing it
Old 02-17-2013, 07:02 PM   #12
Frsexxxy
We took it off ASAP and took it back to the dealer so it wouldn't void warrenty. They didn't knew what it was but it happened after I installed it, and my detector, and my led lights. Maybe it confused the ecu with all those changes at once so your probally right... Who knows.
Old 02-17-2013, 07:03 PM   #13
Frsexxxy
Thanks a lot!
Old 02-19-2013, 10:04 AM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You over oiled your filter. It will never dry if this happens, and the extra oil will coat the hot wire on your MAF sensor, and it will give false readings. You really want to get the aerosol K&N kit and spray on the lightest coating you can. The filter should be white from proper cleaning prior to spraying it with oil so you can easily tell when you have coated it enough.
Frsexxxy (02-21-2013)
injen, injen filter, injen intake, srt
FS: K&N air filter for BRZ/FR-S... Vracer111 Engine, Exhaust, Bolt-Ons 12 05-05-2013 10:03 AM
K@N Filter Junaid P AFRICA 34 01-15-2013 01:00 PM
Which Air Filter Will You Use? GhostofAkina Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 11-16-2012 09:29 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
