01-21-2013, 06:00 PM | #1023 |
That Guy
Drives: 2013 asphalt FRS MT
Me to, but I've seen plenty with it off as well. Honestly what I'm thinking is that everything fits, but when the engine is under heavy load it might be making contact. I have nothing to go on for that so please don't ask for proof. It's just that at least half of the pics have the bar off and I can't think of any other reason for this.
01-21-2013, 06:48 PM | #1024 | |
I Love custom Turbo kits
Drives: Limited BRZ
You know how our stock ECU is sensitive to intake changes?... Well, when you go FI it is even more sensitive.
01-21-2013, 07:09 PM | #1025 |
Drives: truck and old car
Question for those who have experience; I am really interested in this stage 1 sc as it seems it will be safe and easier to maintain than other FI, and also reasonably priced. My main concern is engine saftey. I don't want a lot more power, just a little more.
So to add an intercooler to the stage 1 would be about $1300. 1. I don't live in a super hot or freezing area, 2. I would only plan to take this to a track once in a while (most, once a month) 3. I'm only looking for a little more power, 4. Miles would be be less than 10k year Am I still risking it if I don't have an intercooler.?? Thank you... |
01-21-2013, 07:15 PM | #1026 | |
Drives: Whiteout FR-S
01-21-2013, 07:58 PM | #1027 | |
Drives: 86 (FR-S)
A twin screw has a naturally cooler air charge than a roots blower, so I'm not sure I'd ever need the cooling... and for a street car with light track time, you're probably good. It's great you can add it if you need it. I do think I'll add an oil cooler since this motor does not have one. |
01-21-2013, 08:18 PM | #1028 | |
Add lightness!
Drives: 17' WRX
01-21-2013, 08:51 PM | #1029 | |
Drives: subatoy
01-21-2013, 09:38 PM | #1030 |
Drives: Scion FR-S (Raven)
Really? An N/A motor that already runs hot, and you don't think track use should use an IC? That's nuts. You must be a very gentle driver.
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
01-21-2013, 09:41 PM | #1031 | |
Drives: '13 Ultramarine
As stated above, twin screws create less heat. That combined with lower PSI, makes it a non-issue in my mind. Frequent track users may still want to opt for the intercooler though.
01-21-2013, 09:49 PM | #1032 |
The cost differential between intercooled and non is pretty small. If you're going to do it, you might as well do it right IMO.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
The Following User Says Thank You to swift996 For This Useful Post: | OjiGeorge (01-21-2013) |
01-21-2013, 09:52 PM | #1033 | |
Drives: Attitude
01-21-2013, 10:14 PM | #1034 |
Drives: 86 (FR-S)
Not to be rude, but a K20 is a high compression 4 cylinder. I never had any issues with knock. Most people actually experience knock on their tune during winter due to dense air charge, not heat. Warmer air just makes you slower. Just trying to bring first hand experience to the discussion.
01-21-2013, 10:17 PM | #1035 | |
Drives: Argento 6spd FR-S
Its more likely that Innovate is going to properly tune it for the measly 5 psi and there isn't gonna be any knock issues come up. |
01-21-2013, 10:56 PM | #1036 |
Drives: Attitude
This engine is higher compression, no?
In any case I did say assume, so I don't see why we must point out that I MUST be assuming. |
Similar Threads | ||||
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** | Touge Factory | Interior Parts (Incl. Lighting) | 9 | 11-29-2012 02:13 PM |
lost screw for sensor intake | Mr.Jay | Engine, Exhaust, Transmission | 5 | 10-21-2012 09:26 PM |
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More | Rev Works | Audio/Visual, Electronics, Infotainment, NAV | 28 | 10-09-2012 05:04 PM |
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
Missing rubber piece for intake screw | ngabdala | Engine, Exhaust, Transmission | 1 | 08-31-2012 06:10 AM |
