Old 01-03-2013, 01:04 AM   #1
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Question on two things
So im planning on replacing the driver seat with a racing seat (http://www.tf-works.com/products/TF-...cket-Seat.html) My question is will I need a bracket to mount these seats or are they plug and play?
My second question is I plan on getting one of these two 5 point harness (http://www.tf-works.com/teamtech-mot...tandard-color/ or http://www.tf-works.com/teamtech-mot...ess-with-pads/) If someone can help me pick which one is better that would be great. Also I DO NOT plan on getting a roll/harness bar. I remember seeing someone saying they mounted their harness somewhere on the rear deck (think it was those child safety things) If someone could give me a lil info on where to mount all the points for the harness.
*edit* I just noticed that the second harness is only a 4 point, for some reason it says 5.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 01-03-2013, 01:16 AM   #2
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
I get the impression you have a deathwish. Those seats arent certified, and putting in a race seat into an otherwise stock car with airbag systems still in place can create a lethal scenario in a crash. Using non-certified seats and harnesses can also cause more damage to you in a crash.
That said, if that doesnt matter to you,
Then yes you will need brackets for those seats. You can put the seatbelt bolt into the stock locations in the back seats, but i must advise against it for safety reasons.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 01-03-2013, 01:20 AM   #3
WolfsFang
Scrape Master
WolfsFang's Avatar
Thanks for the info on the seats, looks like I shall get better ones. I plan on doing autox, and taking my car to the track when ever i get the chance to do so.
Old 01-03-2013, 01:30 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Watch this video , if you haven't already
http://allcarsnzvideo.blogspot.ca/20...round.html?m=1
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
whataboutbob (01-03-2013)
Old 01-03-2013, 01:31 AM   #5
Grishbok
Grishbok's Avatar
For autox and track days, you wont really need any harness, cage, or seats. If you are getting into some scca events etc, you will be required to have a cage at a minimum. The cage will strengthen the chassis and give a strong mounting point for the harness.
If you install race seats, make sure to disable and remove the airbags from the car.
Also, certified seats and belts have an expiration date. This is why we usually recomend that you wait until you are required to have it in order to compete.
Old 01-03-2013, 01:43 AM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Thanks for all the info, I know I need to disable airbags when I do this. Also planning to autox this spring. It's true that seats and a harness is not needed for autox and entry track racing but if I like it then I will go to more advanced races (plus the tracks in NJ are 100% ass and have little to no run off). Also the reason i dont really want a roll/harness bar is because I have seen them bend/snap from front/rear collision first hand.
Old 01-03-2013, 01:51 AM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
Lol , I guess you still haven't watched the video .
When it comes to safety , you get what you pay for .. All the ones that you saw break were most likely cheap ones. Look at video and tell me that's not a good cage .
Old 01-03-2013, 01:57 AM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
Iv seen that video before, and that roll cage is worth thousands of dollars, over engineered for something like that to happen, the seats alone are like 1.5k+ each. There is a big difference in a full roll cage vs just a harness/roll bar. I would never need a roll cage or seats like those no matter what I do.
Sometimes it's the little things :) Sony Engine, Exhaust, Transmission 6 12-21-2012 12:43 PM
A few things I didn't know about the car Neilus AUSTRALIA 14 06-22-2012 11:25 AM
10 things you need to know phenoyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-30-2012 11:02 PM
What little things you want to see Maxim Scion FR-S / Toyota 86 GT86 General Forum 310 10-12-2011 07:16 PM
FIVE THINGS TO NEVER DO TO YOUR CAR Raiden Other Vehicles & General Automotive Discussions 11 08-27-2010 08:55 AM
