SpeedRacer
Old 11-01-2012, 05:50 AM   #1
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
DIY: Hardwiring your radar detector
This is pretty straightforward and fast thing to do.
**This was done on a BRZ with an auto dimming rear view mirror**
I am NOT responsible for any modification you do to your own car! I am just showing how I modified mine
First off you need to order a product called 'Invisicord' - http://www.invisicord.com/order.html (Check the installation page to see if your radar detector is supported). I ordered a 12" cable without fuse which I thought would be long enough but it barely was. I would highly recommend ordering at least a 16" cable.
Here is what it looks like (Picture credit - Invisicord)
1 - Start off by removing the dome light fixture
2 - Unplug cord running to dome light
3 - View of what stock wiring to auto dimming mirror looks like
4 - View of stock harness for auto dimming mirror above dome light (I already have the Invisicord wired in photos)
5 - This is the connector you are looking for (front view)
6 - Plugin the prongs from the Invisicord as pictured (RED wire bottom right, GREEN wire bottom center) Look how I am holding the piece so you don't do the inverse of my directions -
7 - Simply plug everything back in and tuck the harness the furthest away from the windshield and on the driver side -
8 - Reconnect the dome light wiring and put it back in position -
9 - DONE!!
If done properly your radar detector should now turn on when the vehicle is started and power down when you turn your car off. Best of luck!
speedracer38 is offline   Reply With Quote
The Following 27 Users Say Thank You to speedracer38 For This Useful Post:
2013GTRNate (01-05-2016), bestwheelbase (12-16-2013), Busybee (03-22-2019), Chimera (02-07-2014), codesplice (04-18-2014), DHitHim (06-12-2016), eljefe (01-15-2013), EvilBeaverFace (02-24-2013), fistfulofbrz (02-23-2014), FRSpdDmn (12-26-2012), Got3n (11-01-2012), GT86_PRAGUE (01-07-2016), GTB/ZR-1 (12-22-2012), idanvan (04-18-2014), kykiee (11-01-2012), Lonewolf (03-20-2015), Namuna (10-07-2014), omegared19 (01-14-2013), Ornelas66 (03-19-2015), ProjectD (11-06-2012), rice_classic (11-01-2012), Scooby South (05-02-2013), Spartan65 (04-15-2013), speedy racer (10-01-2013), Sportsguy83 (03-25-2013), Steve201brz (12-16-2013), Thedishdoc (09-20-2017)
Old 11-01-2012, 12:10 PM   #2
gmookher
thanks
The Following User Says Thank You to gmookher For This Useful Post:
chris's fr-s (02-08-2014)
Old 11-01-2012, 12:44 PM   #3
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
Awesome DIY. I didn't know Invisicord existed. This is quite nice, since you don't have to solder/strip/tap into the wires.
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 11-01-2012, 01:11 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
For those of us that don't have the BRZ, you can probably get the non-coiled CLA plug for your detectors and just run it along the ceiling trim, down the a-pillar and into the CLA outlet behind the glovebox. No cutting and splicing needed.
However, this DIY is terrific for BRZ owners, thank you for sharing!
Old 11-01-2012, 01:15 PM   #5
gmookher
so where youre tapping thats 5v?
Old 11-01-2012, 01:15 PM   #6
gmookher
this is how I am wired at present
FRS dont get a glove box 12v plug?
Old 11-01-2012, 01:16 PM   #7
ayau
Drives: Some rust bucket
here's alternative way of installing a radar detector without splicing/soldering. it uses the aux 12v outlet in the glovebox.
[ame="http://www.youtube.com/watch?v=9i2bEoTbjpA"]Brz radar detector install - YouTube[/ame]
The Following 9 Users Say Thank You to ayau For This Useful Post:
Aozora.BRZ (10-25-2014), Busybee (04-15-2019), calis5nest (05-17-2013), IgamaS (11-03-2015), JohnBgon (09-30-2016), kidgogeta (06-11-2013), sikest (02-08-2013), SoCal909 (12-16-2013), tbertran (12-10-2013)
Old 11-01-2012, 02:03 PM   #8
rice_classic
Yes they do but instead of me saying 12v I used the term CLA. Cigarette Lighter Adapter.
Sorry, I used to manage a Sprint store many years ago and as habit I always refer to those 12v plugs as CLAs.
Old 11-01-2012, 07:44 PM   #9
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Yeah but for those prices? Just take a silver satin phone cord that I'm sure everyone has laying around somewhere, and tin the damn ends, or shove a good amount of bare wire in the back of the connector and put some hot glue on it to hold it. Cost = 0.
These "custom" cables everyone buys are a friggin joke for the price.
Edit: If that's not a true RJ-11, do a bit of dremel work on it, the plug itself appears the same size so you might only have to pull the tab off. Oh and hot glue it, better than duct tape!
michaelahess is offline   Reply With Quote
Old 11-01-2012, 08:04 PM   #10
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
So this DIY is basically to get 12v power with minimal wires exposed?
I'm gonna put a dash cam infornt of the auto dimmed mirror.
just making sure I got the "purpose" of this thread right.
looks good btw.
Zardoman is offline   Reply With Quote
Old 11-01-2012, 08:35 PM   #11
Jayde
Jayde's Avatar
Ohhhhh, no splicing!! I might look into a radar detector/dash cam now! Thanks!
Jayde is offline   Reply With Quote
Old 11-01-2012, 09:00 PM   #12
kykiee
kykiee's Avatar
True. The prices are pretty ridiculous.
Anyone know where I can buy the connector tips just like the Invisicord?
Old 11-01-2012, 09:16 PM   #13
kykiee
kykiee's Avatar
I gotta check out radio shack and see if they have the crimp d-sub connectors. I'm gonna make my own. Now, I just need to find my damn soldering iron.
Old 11-01-2012, 10:04 PM   #14
adaa
Drives: 2007 Ford
Looking good.
Few things are impossible in themselves; and it is often for want of will, rather than of means, that man fails to succeed.FM Car Transmitter
adaa is offline   Reply With Quote
diy, radar detector, speedracer38
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
