10-29-2012, 03:56 PM | #71 | ||
Drives: 2006 Evo IX SE
It's for that reason why Toyota's 2ZZ-GE engine from the Celica GT-S worked for the Lotus Elise and also why Toyota's 2GR-FE engine from the Toyota Camry worked for the Lotus Evora. Didn't you ever wonder why they used the 276 hp Camry V-6 instead of the 306 hp 2GR-FSE in the IS350? It's that same reason... the more powerful version was set up for an FR layout and wouldn't fit right. Quote:
But none really deserve to be in the engine bay of the FR-S/BRZ. MAYBE the 2ZZ, but that engine is getting phased out and certainly doesn't have good enough torque for it, as it's already a good 300 pounds heavier than the Celica GT-S was. |
10-29-2012, 04:52 PM | #72 | |
Drives: anyone seen my steering wheel?
The only "weird" thing about the 2AR-FE is how the engine mounts, which could easily be overcome by using a front and mid plate mounting (which is basically what it uses in the FWD application). Other than the inherent packaging the boxer has (mainly lower COG), there really isn't any other reason an I-4 (or even V-6) could not be used. In fact the I-4 could be placed so as to give a better F/R weight balance. I don't know what you mean by an engine deserving to be in the car. There are plenty of simple changes that could easily be made to any number of Toyota engines that aside from the COG of the engine itself, that would make them meet or exceed the performance on the boxer it has now. Those Changes would also be cheaper to implement than designing a whole new engine, which is what Subaru and Toyota did for this car. |
10-29-2012, 05:43 PM | #73 | ||||
Toyota definitely has the know-how to make a good engine, but they just haven't had one for this purpose. The LFA motor rocks but doesn't have technology that will trickle down into a mass-production four-cylinder that easily, and even their 2ZZ-GE was still co-developed by Yamaha. Subaru, on the other hand, has been really competitive in the four-cylinder performance market, as seen with the WRX and STI. |
10-29-2012, 05:49 PM | #74 |
Drives: 2013 FR-S Ultramarine
From what I've heard they still called in Yamaha for the head work. The FA20 does not share all that much with the FB20.
10-29-2012, 05:59 PM | #75 |
Does it? I don't remember reading that (about Yamaha being invovled with the FA), but I could be wrong.
10-29-2012, 06:28 PM | #76 |
Drives: '84 MA61 Supra, '88 Mercedes 500SEC
look up engine balance/firing order through the first, second, third and fourth harmonics.
then look up the porsche flat 6.
- 1988 Mercedes-Benz 500SEC - 200kW Euro Luxury
- 1984 7MA61 Supra - 300kW/600Nm - 1983 JZA61 Supra - 2JZ screamer - Sold :'( - 2012 ZN6 86 GTS - Hopefully coming in 2012... |
10-29-2012, 08:07 PM | #77 | |
10-29-2012, 08:43 PM | #78 | |
Whatever. |
10-29-2012, 09:00 PM | #79 | |
X2 about the pros and cons. Utilizing those to their fullest is what makes vehicle design and improvement so much darn fun. |
10-29-2012, 09:16 PM | #80 | |
Drives: SSM LT MT BRZ
nope can't say i noticed that...but i try not to rev my motor to redline in neutral so... why were you doing this exactly? my motor see's redline (even now at 8k) often enough, and im not scared of it by anymeans...but why would you do that in neutral??? please don't do it again |
The Following User Says Thank You to SkullWorks For This Useful Post: | immortal_suby (11-01-2012) |
10-29-2012, 09:21 PM | #81 |
Drives: Attitude
Which is a large part of why we don't have a wishbone type front setup. The other being cost. A LOT of sacrifices were made to get the car where it is...
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | ZakD (10-30-2012) |
10-29-2012, 09:25 PM | #82 | |
10-29-2012, 09:53 PM | #83 | ||
Drives: Celica 04
10-29-2012, 09:56 PM | #84 |
Also the 86 would lose a little bit of structural rigidity. It'll still handle well but remember that it's not a car that was designed as a convertible (or with that being a distinct possibility without question) from day one.
Similar Threads | ||||
What happens on a Boxer engine when there's too much Oil? | @Art_Mighty | Engine, Exhaust, Transmission | 29 | 06-15-2014 04:36 PM |
What makes Weds AMF Series so special? | vividracing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-21-2012 05:47 PM |
total noob with boxer engine | NickDude84 | Engine, Exhaust, Transmission | 35 | 04-27-2012 08:51 PM |
Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
