09-29-2012, 02:52 AM | #29 |
Drives: 86
As Nafe said that size would fit without much issue. there wont be much concave style tho as most wheels require 9" to have concave style. Unfortunately we are not familiar with SA road rules so you will have to check yourself.
09-29-2012, 03:35 AM | #30 |
Drives: RX8 S1
I am not familiar with those wheels to tell you of you will get dish from them. Each wheel design is different in dish/concave vs offset and whether or not it changes with said offset
09-29-2012, 03:42 AM | #31 |
86DESU
Drives: 86 GTS, S13, CB9
I would personally recommend getting a handle on the car before you modify suspension and tyre setup. I'd also really, really second the recommendation that you look at some stuff on how it'll affect your handling/etc., remember that overtyring this car will make it slower (C&D in the US did a special, in fact, where wider tyres on larger rims slowed it down over better tyres in the stock size).
And yeah, doublecheck with your local RTA. The setup I'm running appears legal externally but I live in a fairly small town so I'll get away with it. The 86? that'll be getting legal wheels and tyres, 17x8" wheels and 225s, not sure on brand yet. If you're looking for dish/lip (increased distance between hub and edge of wheel), just be careful. |
The Following User Says Thank You to Nezz For This Useful Post: | yomchi1989 (09-29-2012) |
09-29-2012, 04:54 AM | #32 |
Drives: RX8 S1
Sorry for thread jack, but has anyone powder coated/plasti dipped the stockos black, white, red or any other uniform colour?
I think the stock wheels in black would look awesome, ESP if they have a polished lip (I'm a fan of mat black mulity spokes with polished lips lol)
09-30-2012, 01:00 AM | #33 | |
Drives: 86 GTS
http://www.ft86club.com/forums/showt...t=13097&page=2 Page 1 shows them silver, this page shows em black. |
The Following User Says Thank You to Panman For This Useful Post: | 70NYD (09-30-2012) |
09-30-2012, 03:48 AM | #34 | |
Drives: RX8 S1
looks heaps better. this is what i would do, 1st thing probably
10-01-2012, 06:39 AM | #35 | |
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
JDM concept offer these wheels in 18x8.5+30. If I am not mistaken, will these concave in more than +38's? (without going to a wide tyre in 9.5). Cheers |
10-01-2012, 06:40 AM | #36 | |
n00b
10-01-2012, 06:40 AM | #37 |
n00b
10-01-2012, 07:04 AM | #38 |
Drives: Mt Fuji Red 86 GT
Yes, they will concave more than a +38, but it won't be by much.
I might consider 8.5 +30 as well |
The Following User Says Thank You to Nafe For This Useful Post: | yomchi1989 (10-01-2012) |
10-01-2012, 07:06 AM | #39 |
Drives: 86
Hey, u dont need to quote 3 times. When ppl see this thread they will reply.
Anyway what model work wheels you are referring to? If its CR Kiwami then to have the concave of 9.5" u must run 9.5". The face is the same regardless of offset for each width. But for some wheels, offset may change the face of the wheel. |
10-01-2012, 07:28 AM | #40 | |
n00b
So, what would you suggest changes with the +30 and +38? Not much? |
10-01-2012, 07:29 AM | #41 |
n00b
I am under the impression that 9.5's will run more tyre, and as a result, will throw off the speedo by like 1km/hour. Also, will make the car more sluggish. Is this true?
10-01-2012, 07:43 AM | #42 |
Well tyre size will affect speedo, yes. How much it is affected will depend on what size you use.
The 9.5s will increase unsprung weight more than 8.5s, and going to 18's can affect how "responsive" or how quickly it accelerates. In most cases you won't really notice it though. |
Tags |
wheels |
Similar Threads | ||||
Work Vs. Drag wheels | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 68 | 05-30-2013 11:29 AM |
help me decide which work wheels to order??!!! | Saibot | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-29-2012 09:42 AM |
Are 17" wheels too big? Might work 16's work a little better? | rogerdalien | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 46 | 05-10-2012 10:09 PM |
