Old 07-14-2012, 12:39 AM   #15
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by chulooz View Post
This is just plain old misinformation.
YOU can run -20 at the track and hard on the streets in the summer but dont tell others that the higher wear resistance of a -30 or -40 is mythical.
Never said anything about wear resistance.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-14-2012, 01:14 AM   #16
ahausheer
Re-member
Its not all about viscosity. Oil acts like hydraulic fluid for the variable cam timing. To be fair though, Toyota did do a running change in oil weights without changing the engines in any way and some engines require different oil weights depending on which continent they are on. So I say follow what the manufacturer says but there is some wiggle room. That's right, I'm ending my discussion in this thread with the term wiggle room.
Old 08-03-2012, 06:12 AM   #17
Froylavin
Drives: GT86
So back to 0w20 on the next change would be ideal?
Froylavin is offline   Reply With Quote
Old 08-03-2012, 01:21 PM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Good point.
It's also important to note that The Manual itself recommends a higher weight oil.
Originally Posted by The Manual
An Oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds or under extreme load conditions.
Old 08-05-2012, 01:22 AM   #19
Mitch
form follows function
Drives: RIP '13 BRZ
I've seen 5w30 going around as the higher viscosity to run if you're tracking regularly, but I don't think you will hurt sticking with 0w20. Get your oil tested for metals next change and see if it's hurting.
Mitch is offline   Reply With Quote
Old 08-13-2012, 11:26 PM   #20
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
I think for daily driving 0W20 will do the job. Start up and warm up time remains the same.
if you do track the car, I think 5W40 will make more sense. It can handle high temperatures so the engine oil will not break down as quickly as 0W20.
AJ PwR is offline   Reply With Quote
Old 09-11-2012, 01:20 PM   #21
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
What about this suff: Mobil1 0w 40?
http://www.gulf-sport.com/store/mobi...40-engine-oil/
I live in a hot climate and want an oil that'll protect well and stand up to high heat, even under AutoX/HPDE conditions (above 100 Farenheit ambient most days).
we get really crappy oil selection here in Dubai, although the guys at the link I posted do sell Redline oils too.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-11-2012, 01:26 PM   #22
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
^^^ a lot of GTR's use that weight. I suggest you turbo it and change to 0w40 post haste !
NeedsmoreCowbell is offline   Reply With Quote
Old 09-11-2012, 02:01 PM   #23
gmookher
this is not he correct oil
I'm in AZ and the 0w-20 works fine at 115F
you just get more evap
the correct oil will offer more protection that one that is too thick at startup or moreso too thick during use, which is the case of the 5w-40
it appears there is subaru in lebanon
http://www.bazerji.com/subaru/sgws/home.html
do not return to the shop you took your car to, they have no clue what they are doing
the OP needs to get to toyota or subaru
10 second search shows as follows
Old 09-11-2012, 11:07 PM   #24
jpit
Drives: Subaru BRZ
There is alot of misinformation being given out in this thread. This article really helps explain what oil you should be using.
http://www.bobistheoilguy.com/motor-oil-101/
jpit is offline   Reply With Quote
The Following 2 Users Say Thank You to jpit For This Useful Post:
Neziah (09-12-2012), ultra (09-12-2012)
Old 09-12-2012, 01:03 AM   #25
midenginebias
Drives: 2001 Mr2 Spyder
smh.
1. Do not compare weight and viscosity to other different engines. Apples and oranges.
2. 0w-20 can even be used on a track application. Really, has anyone tested it under hard use? I don't think so, but it's not like synthetic 0w-20 can't handle higher temps and provide less breakdown over time as well.
3. 5w-40 MAY be better under hard use, but that is not guaranteed. The properties of the oil MAY be different by additives, brand, etc.
4. Buy your own oil and oil filter and just pay for the labor. That way you get what you want for your given application.
Member of Heya Project for Fr-S/BrZ.
Tire choice, Dash, Options list, Engine, Chassis, Suggestions; My fault
Owned N/A '93 Mr2, N/A '91 Mr2, '98 Corolla, Mazdaspeed Mx-5, '07 Legacy Wagon, E90 328i well maintained and lit up on fire while driving on the freeway in traffic.
midenginebias is offline   Reply With Quote
Old 09-12-2012, 01:07 AM   #26
serialk11r
Drives: '06 AM V8V Coupe
I thought higher oil weight for track use was at best a bandaid for the problem of having oil that's too hot in the first place...
Old 09-12-2012, 12:17 PM   #27
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Seriously, go read this article.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 09-12-2012, 12:56 PM   #28
Kiwi
Drives: Volkswagen Golf GTI
Just a little food for thought.
If STI sells 5W40 oil for the BRZ, I would trust them that it's totally fine.
http://www.sti.jp/parts/catalogue/br...8050ST060.html
Kiwi is offline   Reply With Quote
The Following User Says Thank You to Kiwi For This Useful Post:
botbs (08-04-2020)
