Old 05-17-2024, 01:12 AM   #15
Stevedave
Drives: 2013 Scion Frs
I have the same device working with a tablet as old as the car. It's good software and a good tool.
Do not throw parts at it. Read the manuals. Learn to diagnose properly.
Perfect. Thanks!
Stevedave is offline   Reply With Quote
Old 05-17-2024, 01:28 AM   #16
Stevedave
Originally Posted by FR-S2GT86 View Post
The MX+ is also iPhone compatible. However, I like to use my cheap 10" DVD player/tablet running Android 10 because of the large screen and its ability to sit at any angle I want it to.
Edit: By the way, that crack in the pipe is just on the inlet to the sound generator tubing leading to the firewall. It won't make a difference at all to the operation of the fuel system since it's before both the air filter and MAF sensor.
Perfect. This gives me options. The more the better.
Thanks for the info on the cracked pipe. I see some people get rid of it and plug it at the firewall and at the air filter. I might re-glue it just for peace of mind.
Old 05-17-2024, 01:53 AM   #17
Stevedave
Device ordered. I like the smart on/off feature. It’ll be nice to see live coolant and engine oil temps especially with summer approaching.
Old 05-17-2024, 02:45 PM   #18
chicken tonight
Thanks,...Tcoat.
Old 05-18-2024, 03:33 PM   #19
Stevedave
The MX+ has arrived! I’m going to get it paired up. Any suggestions for apps or data logging that might be beneficial to the issue I’m experiencing?
Old 05-19-2024, 12:00 AM   #20
Stevedave
Got the device paired. It disconnects after running for a minute or two. Has a hard time reconnecting. Tried an IOS device and then an android. Managed to snap a couple screenshot.
Old 05-23-2024, 08:19 PM   #21
Stevedave
. He needs to pick up a good scanning tool to create logs that we can help him interpret. I would recommend the OBD LINK MX+ in his case and a good android tablet with the app to go with it.
https://www.obdlink.com/products/obdlink-mxp/
MX+ is working after doing a factory reset and pairing it up to iPhone. Customer service recommended pairing it with iPhon. Not sure why.
What live data would be beneficial to post on here?
It appears the car is running a tad on the cool side and I’m not getting a reading from O2 Sensor 1.
Old 05-23-2024, 09:01 PM   #22
Stevedave
It appears something got under the hood and chewed up the hood insulation? I went to check the oil and was greeted by this - see pics.
After inspecting under the hood, there doesn’t seem to be any nesting or signs of mice. The hole sits right above the alternator. This is frustrating. The car has been well cared for all its life.
Should I remove the hood insolation? What purpose does it serve?
Old 05-24-2024, 06:25 PM   #23
tomm.brz
Drives: brz 2017 hksv2
sound deadening and some thermal insulation i guess
Stevedave (06-01-2024)
Old 06-01-2024, 03:02 PM   #24
Stevedave
Any suggestions for data logging?
Thoughts on no readings on O2 Sensor 1?
Car Stalls at Idle Stevedave Engine, Exhaust, Transmission 0 05-13-2024 08:36 PM
OFT Stalls on Cold Start scsftballnum45 Software Tuning 15 02-17-2019 03:13 PM
BRZ down... Stalls right after start bravedeer Issues | Warranty | Recalls / TSB 12 09-12-2018 06:39 AM
HELP! BRZ 2017 stalls when switching to OL Muchikori Software Tuning 5 05-27-2018 11:16 AM
FR-S - AT nearly stalls when stopping WryGuy Issues | Warranty | Recalls / TSB 12 05-27-2016 03:04 PM
