05-07-2024, 05:32 PM | #85 |
Drives: BRZ 2023
With 2 bolts I had 6-7mm clearance between tire and spring. For these wheels, offset is 38, so it will add 10mm and subtract 5mm(?) for tires. So I think it should be good, I have 3mm spacers that I will keep in car for just in case.
05-07-2024, 05:37 PM | #86 | |
Drives: BRZ 2023
https://www. gr86 . org/threads/folks-who-have-done-coilovers-did-you-install-them-or-have-a-shop-do-it.11582/?post_id=195720#post-195720 |
05-07-2024, 09:09 PM | #87 |
Drives: 01 911 Turbo, 03 G500
I run 225/45/17 RE71RS on 17x9 ARC8 ET42 with 2 Camber Bolts. But I needed 3mm spacer in front to clear. I have 2.7 degrees. YMMV but this setup works fine and in the time trial series I run there is a penalty for camber plates as opposed to camber bolts.
05-08-2024, 12:00 AM | #88 |
Drives: BRZ 2023
Thanks, I didn't clarify, I am thinking about camber plates due to risk of bottom bolt breaking. Offset of my wheels is 4mm less, so wheels are 4mm out, so I would have more clearance than you (2.7 degree > 2.4 degree and 4mm > 3mm), that wasn't my worry.
05-08-2024, 12:39 AM | #89 |
-2.8 upfront with PP Sach's TRD springs here. From what I've read the Sach's a marginally thicker than the base set up.
Pedders top hats, SPC lower bolts, and OEM lower bolts on the top position. Pretty much maxed out clearance wise. 17x9 +35 Apex ARC8's on 225/45/17 RT615k+'s. The added caster + clearance makes the Pedders top hats a no brainier unless you're going full camber/caster plates. |
05-09-2024, 09:03 PM | #90 |
I have never heard of the bottom bolt breaking. I go out every other weekend and hit every piece of curbing at the track. I've heard of them coming loose and I've had one come loose myself (although I question if the shop had tightened things down properly). Now I keep mine torqud to spec (125 in top 100 in bottom) and marked with paint so that I can look quickly and tell if they have moved. No movement yet after 2 weekends of abuse.
The Following 2 Users Say Thank You to smoltz For This Useful Post: | ruturaj001 (05-14-2024), strat61caster (05-10-2024) |
05-13-2024, 07:52 PM | #91 |
I have used The Peddlers great budget top to get some camber. Add 1 set of bolts and you should see close to -3 up front. Rear just need LCAs to dial it in. Cheap SPC ones work just fine.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | 2.2Lude (05-13-2024) |
05-13-2024, 11:09 PM | #92 |
Drives: 17 Asphalt 86
I managed -3° both sides with pedders, SPC lower, crash bolt upper on yellows with B6 dampers. With a 18x8 +35 215/40 PS4.
05-14-2024, 01:56 AM | #93 | |
Drives: BRZ 2023
I am planning to keep rear stock for now, so -1.4. |
05-14-2024, 10:56 AM | #94 |
Drives: '22 BRZ
Cheap Moog camber bolts work just fine in the rear too, I was able to get +/- about 0.3 degrees with them.
05-14-2024, 11:36 AM | #95 |
I believe its the same OEM as the cheap SPCs ones on rock auto but cheaper.
The Following User Says Thank You to jflogerzi For This Useful Post: | DocWalt (05-14-2024) |
05-16-2024, 03:46 PM | #96 |
Drives: BRZ 2023
Got wheels and tires installed yesterday
Edit: details, 17x8 konig ultragrams and 225 sx2 |
The Following 4 Users Say Thank You to ruturaj001 For This Useful Post: |
05-16-2024, 06:54 PM | #97 |
Drives: Toyota GT86
Looks great! I went with the same wheel and tire size as well. Nice happy medium
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following User Says Thank You to autoracer86 For This Useful Post: | ruturaj001 (05-16-2024) |
05-16-2024, 08:20 PM | #98 |
Sx2s fit wide. I wish they were not so expensive in Canada. I priced them and ended up being more expensive than RS4s
Similar Threads | ||||
Wheels setup advice to learn drifting | ShadowTS | Tracking / Autocross / HPDE / Drifting | 2 | 03-22-2016 03:26 PM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
How does the ECU learn? | boredom.is.me | Software Tuning | 19 | 10-10-2013 08:29 PM |
