Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-16-2024, 10:01 AM | #1 |
Drives: 2018 BRZ
Cheapest way to get easy toe adjustability in the rear?
I've been fiddling with DIY alignment on my BRZ and am pretty happy with it so far. The biggest pain is adjusting rear toe - the OEM eccentric washer is horrible to adjust. It changes toe by a lot with the tiniest turn, and it's almost impossible to tighten the nut without affecting the toe.
What's the cheapest way of getting easy adjustments? I'm looking for a threaded toe arm like in the front, ideally with a fixed washer to lock the OEM adjustable slot. Is the RockAuto MOOG arm at $70 a piece the cheapest way? |
04-16-2024, 12:40 PM | #2 |
Drives: None
Yep, RockAuto Moogs (same thing as SPC) with some lockout plates. GKTech had the cheapest lockout plates I could find without resorting to cutting metal myself when I was last looking.
Only annoying part about the Moog/SPC is that you pretty much need to cut down a 22mm wrench to easily adjust them.
The Following User Says Thank You to RedReplicant For This Useful Post: | Ohio Enthusiast (04-16-2024) |
04-16-2024, 03:16 PM | #3 |
Drives: 2018 BRZ
04-16-2024, 04:15 PM | #4 |
Drives: None
Nah, as in a full size 22mm wrench is too long to adjust without being frustratingly slow. I cut mine down to be like fist length so I can more or less do a half turn at once instead of like a sixteenth of a turn before having to reposition the wrench due to hitting other links/ground/etc.
04-17-2024, 11:12 AM | #5 |
Drives: 17 Asphalt 86
MOOG/SPC LCA
SPC toe arms for additional range of adjustment. |
Similar Threads | ||||
Top hat/camber plate adjustability limit? | Plumbus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 12-29-2020 02:22 AM |
Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style | Dake | DIY (Do-It-Yourself) Guides | 24 | 10-07-2020 11:56 AM |
Cheapest Rear chrome frs badge?? | Norinradd | Exterior Parts (Aero, Lighting, Etc.) | 7 | 06-09-2016 05:50 PM |
Solution for easy changes to rear camber and toe (street and track use) | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-11-2014 05:28 PM |
Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 04:36 PM |
