Old 04-16-2024, 08:20 AM   #323
Opie
Opie's Avatar
Drives: '13 BRZ TLM Spec
Originally Posted by gnarjunkie View Post
Question for you from alllll the way back to the first page...
I stuffed my BRZ into a tire wall at the track this last weekend and bent this exact part. The part above the headlight and where the front of the fender attaches to specifically are pretty not-straight anymore. I remembered this thread somehow and thought you might be able to help.
Do you remember if this whole fender support part bolts in? Or does it need to be welded in? My initial thought was it might all need to be cut out and replacements welded in, but looking at these photos, it looks like maybe the replacement piece is just a lot bigger than I was originally thinking.
It all depends on which part(s) are bent (picture would help). But the parts are all available from Subaru seperately, most aftermarket units come as a complete core support which very rarely is needed. Depending on which parts are needed, some are bolted, some are welded and bolted and some are just welded.
In the first picture below, the T-Brace #53010A is bolted in. P/N: 53029CA0209P
The passenger (right) headlight surround #53010B is bolted and welded. (2 bolts, 3 plug welds). P/N: 53029CA0709P
The driver (left) headlight surround #53010C is also bolted and welded. (2 bolts, 3 plug welds). P/N: 53029CA0809P
In the second picture it is possible that the apron reinforcements are also bent.
The passenger (right) side #51233H is bolted and welded. (2 bolts, 3 plug welds). P/N: 51639CA0109P
The driver (left) side #51233I is also bolted and welded. (2 bolts, 3 plug welds). P/N: 51639CA0209P
If you have access to a welder and are somewhat mechanically proficient the repairs are pretty easy, the hardest part in making sure everything is square before welding. The measurements to ensure everything is lined up are found in the Subaru BRZ Body Repair Manual.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
Opie is online now   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Ultramaroon (04-16-2024)
Old 04-16-2024, 08:28 AM   #324
Opie
Opie's Avatar
Old 04-16-2024, 01:01 PM   #325
gnarjunkie
Drives: '23 GR86, '17 BRZ
Thank you!!
The passenger side headlight surround and apron reinforcements are the parts that are bent.
I've never done anything with spot welds before... but it looks like they almost play the same role as bolts. Like the parts show up with holes in it where you place the spot weld to seal it up to the car.
Am I correct in that?
If so, that seems like just a matter of drilling out the old weld and replacing the part. Feels like it might even be fairly straightforward to line it all up correctly as you'd have 2-3 different points (between the bolts and spot welds) to line up before actually welding.
Does that sound about right? Totally guessing here... I'm fairly confident in mechanical work but I've never had to replace something of this nature before.
gnarjunkie is offline   Reply With Quote
Old 04-16-2024, 01:18 PM   #326
Opie
Opie's Avatar
Thank you!!
There are no holes in the parts where they need to be spot welded. The sections that bolt up will help get it close. I used this to drill out the old spot welds, use a punch to mark the center and drill just enough to free the panel without going all the way through. Then use the part you took off as a template to drill holes in new part, the "stumps" left from the old part should fit in the holes you drilled, then bolt & clamp the new panel in place, measure multiple times to ensure everything is lined up, then weld.
I posted the 2013-2016 Body Repair Manual here for you.
Radiator Support Repair Instructions start on Page 62, Pages 220 & 221 show the measuring points and measurements.
The Following 2 Users Say Thank You to Opie For This Useful Post:
IsaiahW (04-16-2024), Ultramaroon (04-16-2024)
Old 04-16-2024, 03:28 PM   #327
gnarjunkie
That makes sense. Really appreciate it! Looks like it's a bit more involved than I was anticipating originally but still looks pretty doable.
The Following User Says Thank You to gnarjunkie For This Useful Post:
Opie (04-17-2024)
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 08:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 08:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 01:16 AM
