01-12-2024, 08:55 PM | #19853 |
Drives: 2014 FR-S
01-13-2024, 09:59 AM | #19854 |
Drives: 2018 BRZ
My guess is that @dpfarr was referring to other cars that have the parking brake as part of the regular caliper (unlike the Twins that have a separate drum brake for the parking brake). In that case compressing the rear caliper requires a twisting motion, typically done with needle nose pliers (although there are dedicated tools for that as well).
01-13-2024, 10:38 AM | #19855 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
You only need needle/long nosed pliers on a ts with good Brembo calipers. Calipers remain bolted on the car. 2 clips and 2 pins each brake caliper. Oh and a good squeeze with fingers on the pistons.
Wait until my Flex capacitor hits 88
01-13-2024, 10:42 AM | #19856 |
Drives: 22 BRZ limited
Or Brembo style that come out the top after removing the clip and pin.
01-14-2024, 12:15 AM | #19857 |
Drives: BRZ ts
Yea, the process for brembos is new to me. 30k miles and about 3mm of pad left. Very reasonable to be able to swap track pads in while switching wheels.
01-17-2024, 08:41 PM | #19858 | |
Drives: 2017 BRZ PP, 2004 WRX
Depending on thickness differences between the two sets of pads, you do have to move the pistons back in and the fronts take a decent amount of force. You can do it with a pad and wiggle it back and forth, but it takes some effort... especially going from a thin pad to a full one. Pins take some effort in the front too. Best to pull them out from the rear rather than tapping from the front as you can scratch the caliper this way. The rears being much smaller are simple all around. ... so when you think about traditional sliding calipers, there isn't a ton of advantages actually. It's just about the same effort removing one bolt, swinging the caliper away, swapping pads and/or moving only two pistons vs four, and you're good. I've had both. They're not hard by any means, but not like half the time or anything.
The Following 2 Users Say Thank You to cmiovino For This Useful Post: | NoHaveMSG (01-18-2024), Ohio Enthusiast (01-17-2024) |
01-18-2024, 10:34 PM | #19859 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (01-18-2024) |
01-18-2024, 10:48 PM | #19860 |
chicken tonight
If it needs to be faster than a c-clamp, I need to examine my priorities.
01-20-2024, 01:02 AM | #19861 |
Drives: BRZ ts
I had a Jetta that needed a tool that simultaneously spread and rotated the piston.
The Following User Says Thank You to dpfarr For This Useful Post: | blsfrs (01-20-2024) |
01-20-2024, 09:57 AM | #19862 |
Drives: 2013 frs base
I had a Passat with the same type calipers. I spent an hour trying to push and screw the piston in (the video said it would be easy) then got the loaner tool and finished each one in 3 minutes.
01-20-2024, 05:44 PM | #19863 |
Drives: Crapcan
My favorite tool for it is actually a clutch basket holder for a motorcycle.
01-20-2024, 07:04 PM | #19864 | |
chicken tonight
I've been doing it wrong all these years.
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (01-20-2024) |
01-21-2024, 10:16 AM | #19865 |
01-21-2024, 05:05 PM | #19866 |
Drives: Crapcan
Like this. Tons of leverage, quick to adjust.
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
