DIY (Do-It-Yourself) Guides For all DIYs. |
04-21-2017, 09:55 PM | #127 |
Just swapped out my cabin filter today and realized I had the previous one oriented the WRONG way for the last 30K miles!
If you're using the FRAM filter, make sure the arrow is pointing DOWN! (Air flow goes downward) |
04-23-2017, 10:50 PM | #128 |
Drives: red
Thanks a TON for the heads-up!
06-20-2017, 06:52 PM | #129 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Just took out my Wix. Had on for 8k miles or so and it looks like it started melting!!! Well not literally. It's worn pretty well like if it had been rubbed on cement. Bought a MicroGard which is $15 cheaper. We shall see how it does in 8k miles. I recommend a carbon one if you live in big city. Otherwise, any cheap one above $10 works well and serves it's purpose!
06-22-2017, 10:30 AM | #130 |
Drives: BRZ Club blanc perle
I buy a Mann 3 layer anti pollution filter. Not cheap 45€, but it filter bad smell from smoky cars behind you, great buy !
Envoyé de mon T6pro en utilisant Tapatalk
Collecteur et frontpipe Supersprint full décat - Catback Remus Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons |
12-26-2018, 10:17 PM | #131 |
Drives: 1995 Ford Probe
Couldn’t you just make your own DIY in-cabin filter with a home HVAC filter like Filtrete and just just it to size especially since they have different levels of filtration?
12-26-2018, 10:33 PM | #132 | |
Drives: Car
03-06-2020, 11:53 PM | #133 |
Drives: 2014 MY15 86 GTS
My spring/gas hook on the side of glovebox fell off its pivot when removing....
Its has two holes I can see one of them clips onto in plain view, where is the other clip onto? Last edited by Halo_2; 03-07-2020 at 05:58 PM. |
05-08-2020, 07:34 AM | #134 |
Anyone, also the K&N air filter make sure arrow points down with direction of flow.
The Following User Says Thank You to Halo_2 For This Useful Post: | ddevl_86 (05-19-2023) |
08-11-2023, 01:39 PM | #135 |
Where is the actual intake for the fresh air to enter before the filter? I changed my filter but it still smells musty like there is some debris in the actual fresh air intake.
08-11-2023, 04:02 PM | #136 |
Wheels for Brains
The Following User Says Thank You to EndlessAzure For This Useful Post: | Mr_Brian (08-11-2023) |
08-12-2023, 06:32 PM | #137 |
Drives: GR Corolla
The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Mr_Brian (08-12-2023) |
Tags |
air filter, cabin air filter, diy |
Similar Threads | ||||
Safety Inspection Sticker Mount | Philz0r | Hawaii | 13 | 06-12-2015 02:29 PM |
brake pad inspection | sickmint79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-05-2013 09:22 PM |
inspection sticker question | wallace03 | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 12-02-2012 04:48 PM |
PIC 10K TRD Air Filter Inspection | Yruyur | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 10-07-2012 01:53 AM |
Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
