Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-09-2023, 06:28 PM | #29 | |
I've never been able to get my transmission to downshift into first really, except _maybe_ from 3-4mph, like right around where the car would lug in 2nd if I let it.
Instagram: @spike.brz
The Following 2 Users Say Thank You to spike021 For This Useful Post: | Dzmitry (06-13-2023), Ultramaroon (06-09-2023) |
06-09-2023, 07:49 PM | #30 |
Custom Switch Panels!
Drives: 2015 Subaru BRZ Series.Blue
It's super weird that there's apparently such a wide variation, and so common. I'm also glad mine don't have that issue, lol.
The Following 2 Users Say Thank You to RACECAR go brrr! For This Useful Post: | soundman98 (06-10-2023), spike021 (06-10-2023) |
06-09-2023, 08:37 PM | #31 | |
Drives: Crapcan
I saw this and all those, "what is this ball stuck to my drain plug?" threads made more sense.
https://www.jackstransmissions.com/t...ervice-brz-frs Quote:
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (06-09-2023) |
06-09-2023, 11:57 PM | #32 | |
chicken tonight
06-10-2023, 12:02 AM | #33 | ||
chicken tonight
edit: To clear up any doubt, here's a page from the service manual with the relevant IPB. Scroll to the bottom. It's called the "1st shift restrict ball."
The Following User Says Thank You to Ultramaroon For This Useful Post: | spike021 (06-10-2023) |
06-10-2023, 09:22 AM | #34 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The location of that ball reinforces the importance of the oil.
On this transmission the 1/2 shift hub is on the layshaft, submerged when the car is parked, and very likely soaking wet with it's toes in the oil bath even when running and flinging oil around the case. If you've that OEM fill GL-3 goop in there that's a lot of jelly that little ball, and that shift ring and synchros have to push out, and a lot of warming up to do before it gets as smooth as a more high tech oil. |
The Following 3 Users Say Thank You to RZNT4R For This Useful Post: |
06-10-2023, 06:17 PM | #35 |
chicken tonight
Not specifically that ball, but yes. It's also the reason timing is especially critical for the cold 1-2 shift. That jelly quickly drags down the speed of the whole gear set anytime the trans is in neutral with the clutch disengaged.
Pro tip; shift with a quick gentle open-fingered flick from first to second without pausing in neutral. With good technique, even stone cold, it just falls into gear.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | Dzmitry (06-13-2023), humfrz (06-10-2023), NoHaveMSG (06-11-2023), soundman98 (06-10-2023), spike021 (06-11-2023) |
06-10-2023, 08:55 PM | #36 | |
The Following 4 Users Say Thank You to humfrz For This Useful Post: |
06-10-2023, 11:13 PM | #37 | |
ProCrastinationConsultant
my car definitely has a 1st gear lockout, as it won't fall in unless the revs are first matched or over-reved before the shift. but i've never double clutched. normally when i'm going 2-1 at anything other than a stop sign, it's at the upper limit of 1st, and i intend to rotate the rear around the corner(not always sideways, or skidding, many times just enough to roll the tires over). it's almost automatic at this point, but i'll rev-match 4-3-2, line up for the corner, then clutch-in, drop out of 2nd, rev up while holding towards 1st until it drops in, and then release the clutch(not pop) as it's falling into 1st... both of my early '14's operated the same. though as long as i'm under-reved for 1st, it will refuse to go in. i do wonder if it's my/your technique that's working around the mechanical 1st gear lockout, or there's enough clutch dragging to keep the input shaft spinning to follow the rpm jump. personal technique would make more sense, as we're both a sample size of 2 different transmissions operating the same way, and the odds of mass manufacturing skew against us. of note, i never down shift for the first mile-ish of use, the fluid is too cold, and nothing wants to work.
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | humfrz (06-11-2023), Ultramaroon (06-11-2023) |
06-11-2023, 12:51 AM | #38 | |
chicken tonight
I've driven a couple which were super easy to downshift into first, even without doing anything special to spin up the input side.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (06-11-2023), soundman98 (06-11-2023) |
06-11-2023, 01:59 AM | #39 | |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
06-11-2023, 03:02 AM | #40 |
chicken tonight
lol
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (06-11-2023) |
06-21-2023, 12:57 AM | #41 |
redvee
Drives: 2012 Sonic Blue 86 GTS AT
I find that if I get the revs up to just over 4k after a cold start and shift 1st to 2nd it is a smooth shift. Generally lower rpms will make a crunching noise.
The difficulty shifting 3rd to 2nd after cold start is frustrating! |
06-21-2023, 12:59 AM | #42 |
redvee
So is there a consensus on the best oil to use for the transmission?
Similar Threads | ||||
Do I need to be extra careful when shifting 1-2 in cold? | lapsio | BRZ First-Gen (2012+) -- General Topics | 49 | 11-22-2021 10:27 AM |
2018 cold shifting | konahic | BRZ First-Gen (2012+) -- General Topics | 29 | 02-28-2020 05:09 PM |
Transmission shifting when cold? | jpilone | Engine, Exhaust, Transmission | 112 | 02-22-2018 03:48 AM |
Down shifting into 2nd gear when cold | Flame9020 | Issues | Warranty | Recalls / TSB | 27 | 12-22-2016 04:24 PM |
Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 35 | 06-24-2012 02:22 PM |
