04-19-2023, 11:31 PM | #1667 | |
Drives: 16' WWB
and thanks man it's pretty exciting!!!... well I mean my wife isn't excited about all the money I spent on this, which is partially the fault of this thread - but I know once she drives it she'll be less pissed off at me.. hopefully. |
The Following User Says Thank You to funkjaw For This Useful Post: | RedReplicant (04-20-2023) |
04-20-2023, 08:02 AM | #1668 |
Drives: 13 White MT FR-S
anyone need some 1000cc DW injectors hit me up.
The Following 2 Users Say Thank You to ML For This Useful Post: | funkjaw (04-20-2023), RedReplicant (04-20-2023) |
04-20-2023, 09:52 AM | #1669 | |
At the track
Drives: '14 FRS - Former e92 M3
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
The Following 2 Users Say Thank You to Kelse92 For This Useful Post: | funkjaw (04-20-2023), RedReplicant (04-20-2023) |
04-20-2023, 03:08 PM | #1670 | ||
Drives: Fr-s
The Following User Says Thank You to redlined600 For This Useful Post: | funkjaw (04-21-2023) |
04-21-2023, 06:12 PM | #1671 |
Drives: 16' WWB
What front sway bars ya'll runnin without any clearance issues? I have a Hotchkis 25.4mm hollow sway bar and it definitely touches and causes vibrations against the transmission adapter.
04-21-2023, 10:06 PM | #1672 |
Drives: None
I've got the Perrin 22mm in mine, fair bit of room there
The Following User Says Thank You to RedReplicant For This Useful Post: | funkjaw (04-22-2023) |
04-22-2023, 02:55 PM | #1673 |
Drives: Q5 + BRZ + M796
I have Eibach, and it seems to clear fine.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | funkjaw (04-22-2023) |
04-22-2023, 10:09 PM | #1674 |
Drives: 16' WWB
As promised here is an acceleration video of my car with the new 4piston head and toda A3 cam setup. It picked up .3 seconds in the 20mph-60mph vs the stock head on E85 in a previous video I posted. This probably translates to 4 or 5 tenths faster in the quarter mile I suppose? Definitely nothing to shake a stick at that's for sure.
The Following 2 Users Say Thank You to funkjaw For This Useful Post: | Jdmjunkie (04-22-2023), RedReplicant (04-23-2023) |
04-23-2023, 09:23 PM | #1675 |
Drives: 2013 frs
Well that sucks, finally got my kit and am working on getting all together and that's the same sway bar I've got
The Following User Says Thank You to Adamf220 For This Useful Post: | funkjaw (04-23-2023) |
04-23-2023, 09:44 PM | #1676 |
Drives: 16' WWB
04-24-2023, 11:35 AM | #1677 |
At the track
Ohh I didn't even think about swaybars being an issue... I bought another Karcepts one recently... hope it works. Guess I'll keep my Perrin 19mm one a little longer as a backup.
The Following User Says Thank You to Kelse92 For This Useful Post: | funkjaw (04-25-2023) |
06-02-2023, 02:52 PM | #1678 |
Hey fellas,
I've reached out to OS Giken, Competition Clutch, Clutch Masters, Exedy, Tilton, XClutch with inquiries about whether their twin clutches would work. Clutch Masters, for instance, makes a K24 to Subaru transmission adapter and flywheel that work with their twin discs, but this is for the EJs (see below). Several have gotten back to me with a "No" and some have asked for measurements and some said they could if I sent in my flywheel or provided accurate measurements. https://clutchmasters.com/i-30508045...-flywheel.html Does anyone know these dimensions who has their parts readily available? I have a spare transmission in my garage, so I could probably get the thickness of the adapter plate, the distances to the TOB and input shaft from the transmission, but I don't have the engine out to be able to measure the flywheel and engine side. If someone is feeling so kind then I would appreciate any measurements they could contribute. My goal is to get a twin disc that is organic, sprung and with a steel flywheel for the most steetable clutch setup possible, but I don't know if I will be able to get everything I want. I've read and watched videos that the Clutch Masters is nice because the spring tensioners on the plates make them not rattle, so it doesn't sound like a Ducati dry clutch.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RedReplicant (06-02-2023) |
06-02-2023, 03:36 PM | #1679 |
Drives: Scion FR-S 10 Series
I hope OS Giken responds positively. They make some of the best clutches I have every used. And they only make noise when you push in the clutch because of the floating pressure plate. Also it would me I could buy their sequential transmission if I ever win the lottery.
The Following 2 Users Say Thank You to Jdmjunkie For This Useful Post: | Irace86.2.0 (06-02-2023), RedReplicant (06-02-2023) |
06-02-2023, 04:14 PM | #1680 | |
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Jdmjunkie (06-02-2023), RedReplicant (06-02-2023) |
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
