#4845 |
Drives: brz 2017 hksv2
i ve retuned many edelbrock, even after they tuned firsr with delicious
not a single one has idle problems delicious tunes are like that. it s a sd 100% based tune and fuel trims are always too erratic and the idle stability strategy isn t well set it s also quite erratic during open loop Last edited by tomm.brz; 05-18-2023 at 05:39 AM. |
#4846 | |
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
The best thing about the future is that it comes one day (and curve) at a time.
#4847 | |
Drives: 2020 Subaru BRZ (Edelbrock SC)
Not to mention boost pressure feels weak compared to when I upload a new tune or reconnect the battery. Car feels very powerful at the beginning but as the ECU adjusts, I feel like I lost most of that power I had at the beginning. Still convinced its a vacuum leak... On an unrelated note, can a completely worn out clutch confuse the ECU? I am at a stage where I just replaced my clutch but did not get the chance to drive it. Wondering if slippage limits some of the power that the SC can output. I upgraded from OEM to OS Giken Single. |
#4848 | |
haven t you reached out zach at csg to check on your logs? DO you have logs then ? |
#4849 | |
Unfortunately, I am on the other side of the US so I have to do some mechanical checks on my end and now I'm having a shop specialized in this platform looking at it. Hopefully they find something. |
The Following User Says Thank You to GPhilly For This Useful Post: | tomm.brz (05-19-2023) |
#4850 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
My car threw a P0171 code the other day, checked my OBD2 and found a 24% LTFT. Turns out the Delicious D-Box DESS module quit sending its signal to the ECU but was still reading the percentage over bluetooth just fine. ECUTEK logs showed a 0% in fuel corrections and ethanol percentage. Has anyone else seen failures on these modules?
#4851 | ||
Drives: 86
#4852 | |
Drives: 86 (FR-S)
#4853 | |
Drives: 86
Edit: I'll also mention it's not all doom and gloom. Other than the bypass valve my edlebrock kit has functioned flawlessly for nearly ten years with regular track days. Car is driven hard and doesn't skip a beat. |
The Following User Says Thank You to Colin86 For This Useful Post: | Jeff86 (05-23-2023) |
#4854 | |
Drives: 86 (FR-S)
#4855 |
How many mounting bolts does it have? I seem to remember the original had 3 and the new has 2. I replaced mine with the newer version about 3/4 years ago and haven't change it since. 20k driven since then.
The Following User Says Thank You to B T For This Useful Post: | Jeff86 (05-23-2023) |
#4856 |
Drives: 2016 Scion FRS Release Series 2#439
I bought a used unit. The seller provided an uninstalled updated bypass. I removed the original 3 bolt bypass and installed & calibrated the updated 2 bolt version. It has been flawless. Mind you, it is fed vacuum from a remote MAP sensor set-up. Not directly from the manifold.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4857 |
Mine pulls from the brake booster line.
#4858 |
Drives: 86 (FR-S)
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
