Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-15-2023, 11:58 AM | #1 |
[jay-kuh-meh-low]
Drives: 2016 FRS RS2.0 #293
I accidentally pushed the piston out of my rear brake caliper
Any pro tips for getting it back in? Can I grease the piston with permatex brake lube or is that ill-advised?
IG: @appamatic
05-15-2023, 12:02 PM | #2 |
Drives: Crapcan
Should be able to just push it back in. I've always just lubed with brake fluid.
05-15-2023, 12:42 PM | #3 |
[jay-kuh-meh-low]
It was sticking and I didn't want to crack the cylinder. I might just line it up best I can, and push it back in with a caliper spreader, and hope it doesn't explode.
IG: @appamatic
05-15-2023, 12:43 PM | #4 |
Drives: Crapcan
If it's sticking, you need to address that. Is the piston sticking or the slider? How does the seal look?
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (05-15-2023) |
05-15-2023, 01:22 PM | #5 |
[jay-kuh-meh-low]
The piston was sticking and didn't want to go back in. The seal looks completely fine.
IG: @appamatic
05-15-2023, 02:41 PM | #6 |
chicken tonight
The cylinder bore and piston should be spotless. The piston must be perfectly lined up with the bore when inserted. Any misalignment will cause it to jam/bind. Don't force it!
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (05-15-2023) |
05-15-2023, 08:02 PM | #7 |
Drives: 2013 frs base
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
05-17-2023, 12:12 AM | #8 |
Wheels for Brains
Crack the bleeder valve while you push it back in. That way you aren't fighting air or brake fluid
If it's aligned properly and in good working order, you should be able to push it with just your hands |
The Following 4 Users Say Thank You to EndlessAzure For This Useful Post: | blsfrs (05-17-2023), NoHaveMSG (05-17-2023), Racecomp Engineering (05-17-2023), Ultramaroon (05-17-2023) |
Similar Threads | ||||
Brembo Gran Turismo 2 Piston Rear (GT) brake system | gtpvette | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-12-2020 05:47 PM |
OEM Brake Caliper Piston Size | Butterballz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 08-12-2019 10:07 PM |
Rear brake caliper banjo bolt size? | ChrisD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-22-2016 06:51 PM |
Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
