Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
04-17-2023, 10:14 AM | #29 | |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
04-17-2023, 12:19 PM | #30 |
Drives: 2014 Subaru BRZ DGM Limited
Bought the car with Konig Hypergram shoes on. 18x8.5+38 I believe. Light and strong, no complaints so far, which prevents me from buying the SSR GTX03 for 3 years now.
The Following User Says Thank You to fryfun For This Useful Post: | mike_ekim1024 (04-17-2023) |
04-17-2023, 03:57 PM | #31 |
Drives: Argento Scion FR-S
So instead of a spreadsheet, which can get out of hand fairly quickly, I started writing a web app. My day job is working with React, so why not
https://wheels.ft86partpicker.com Only a few wheels to get the design thought out. I'll add more over time. The www site is a much older, but maybe still relevant with a list of basic parts. Mike
04-19-2023, 05:50 PM | #32 |
Doing more research, WORK Emotion ZR10 is listed as "1 Piece / WORK Flowforming Technology (WFT)". I don't see any other Emotion products listed with WFT, but I feel there could be?
https://www.workwheelsusa.com/product/emotion-zr10 It's difficult to find weight information for this wheel other than it is "lightweight"
04-20-2023, 02:20 AM | #33 |
Another flow-formed wheel, but I’m not familiar with the brand:
https://neuspeedrswheels.com/product...31935766528113 At $380 / wheel (18x8.5), they’re in the mid-range of flow-formed wheels.
04-20-2023, 09:10 AM | #34 |
BRAID Fullrace A. Made to order, essentially any size and offset. Not super light, priority is strength but they're commonly used in motorsport. I use them and like them.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | mike_ekim1024 (04-20-2023) |
04-20-2023, 09:25 AM | #35 | |
Spelling Impaired
The Following User Says Thank You to Desertnate For This Useful Post: | mike_ekim1024 (04-20-2023) |
04-20-2023, 10:07 AM | #36 | |
Drives: 2020 BRZ Sport Tech RS
EDIT: I guess since back in the day when I was a VW guy, Neuspeed has added products for BMW, Fiat, Mini and Porsche as well.
The Following User Says Thank You to Tatsu333 For This Useful Post: | mike_ekim1024 (04-20-2023) |
04-20-2023, 12:54 PM | #37 | |
https://www.ft86club.com/forums/show...57&postcount=7 I do see Neuspeed wheels in the wheel directory: https://www.ft86club.com/forums/showthread.php?t=18732
04-20-2023, 03:32 PM | #38 | |
I'd say it's near-zero possibility that you can get 0.5mm thick hubcentric rings to bridge the 1mm difference in center bore, so you'd be chancing slight mis-centering with these wheels every time you fit them. That said, if the bolt holes are tapered, then the lug nuts will do their own bit of centering, so it *could* be just fine...
04-20-2023, 03:46 PM | #39 | |
Drives: Crapcan
04-20-2023, 11:56 PM | #40 | |
"These wheels are manufactured using the very latest in full flowcast technology which allows a more uniform arrangement of the alloy structure and granularity greatly increasing the wheel's final characteristics. The result is a lighter and stiffer wheel with much improved strength both in terms of bending and cracking." A little pricey, but they sound like super tough wheels and the weight is not bad at 20.3 lbs for 18x8, in line with the other flow-formed wheel brands. One thing that is hard to convey is strength. Well, without buying some and running some torture tests
04-21-2023, 06:46 PM | #41 |
Added load rating to the specs on https://wheels.ft86partpicker.com, as well as a few more wheels. With some wheels, it's difficult to find the rating, even with brands such as WedsSport (found the TC105X but not the SA-75R).
In general, 1500 lbs seems to be the high end with these collection of wheels, with some lower such as 1190 lbs for the Konig Rennform. I wonder if load rating include sideways forces such as when hard cornering? https://www.ft86club.com/forums/showthread.php?t=32942
04-21-2023, 07:50 PM | #42 | |
Drives: GR Corolla
18x9.5, ET38 for the set I got. |
The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | mike_ekim1024 (04-21-2023) |
Similar Threads | ||||
FS 18x8.5 Forgestar CF5 Gunmetal Rotary Forged Wheels FRS BRZ | RWDRIFT | Wheels and Tires | 9 | 10-10-2013 08:44 PM |
MTechnica multipiece rotary forged line-up | eight08customs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-16-2012 11:56 PM |
** New TSW Panorama rotary forged wheels | speed depot | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 10-02-2012 11:20 AM |
TSW Nurburgring Rotary Forged Wheels | Eric@GetYourWheels | Wheels and Tires | 6 | 08-01-2012 12:19 PM |
TSW Interlagos Rotary Forged Wheels | Eric@GetYourWheels | Wheels and Tires | 9 | 08-01-2012 12:15 PM |
