Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-09-2023, 11:40 PM | #1 |
How many 2013 FRS still running without doing valve spring recall
Just wondering how many 2013 FRS are out there still running without doing the valve spring recall? I bought my 2013 brand new and have held off on doing the recall since I only have 25,000km on it, but wondering if I should just have it done.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
The Following User Says Thank You to Eazy-V For This Useful Post: | humfrz (04-13-2023) |
04-10-2023, 01:45 AM | #2 | |
Proud of BOXER
Drives: Subaru Boxer
Don't do it.
04-10-2023, 10:48 PM | #3 |
ProCrastinationConsultant
the recall was specifically because subaru's metal supplier was caught rubber-stamping entire batches of metal as compliant with subaru's specifications. so subaru really has no idea if the metal is correct or not. but they erred on the side of caution and issued the recall to protect themselves from the fallout of the potential that the incorrect metal was used to make the valve springs, which could lead to fracturing springs.
my personal inclination is that most of the metal was likely close to the correct formulation, with a strong possibility that it might not have met subaru's specified standard, but well within what most other automakers would use for the same components. i guess the question is "what makes you feel luckier?" ****ing around in a factory-sealed motor that relies on a human tech laying down multiple specific-size beads of caulk to properly seal it, all the while risking damage from taking it apart and putting it back together again, or leaving it and hoping the metallurgy of the springs is correct?
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (04-13-2023) |
04-10-2023, 10:52 PM | #4 | |
Proud of BOXER
Hoping that the metallurgy is correct because I'd make the argument that if they were going to fail, they would've failed by now.
04-11-2023, 09:55 PM | #5 | |
could've just as easily gotten the new guy that over-specs everything. who knows, maybe even the 'inferior' version is just what gets sold day-in/day-out to kia.
The Following User Says Thank You to soundman98 For This Useful Post: | Clipdat (04-11-2023) |
04-11-2023, 10:08 PM | #6 |
Drives: '13 Whiteout
If you don’t need to do it for registration then don’t do it. It’s a Russian Roulette recall.
04-11-2023, 10:12 PM | #7 |
helmholtz resonator
Drives: '15 ultramarine
Exactly 3. Thanks again Mr. Owl. |
The Following User Says Thank You to Sapphireho For This Useful Post: | soundman98 (04-11-2023) |
04-12-2023, 10:47 AM | #8 |
Drives: '13 BRZ TLM Spec
Never done it....if a valve spring fails in the future, it'll still be covered...
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | Tcoat (04-13-2023) |
04-12-2023, 11:41 AM | #9 |
Drives: Crapcan
Mines still alive. If it was going to break a valve spring it would have done it a long time ago.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | humfrz (04-13-2023), soundman98 (04-12-2023), Tcoat (04-13-2023), Teseo (04-13-2023), tomm.brz (04-12-2023) |
04-12-2023, 06:58 PM | #10 |
Thanks for the replies and I agree, it doesn't seem worth doing it now. Also since my FRS is modded, I think dealers will either charge me extra due to the mods or will only accept my car once I remove the mods (ie turbo etc).
I'm curious if the dealer will actually give you the recall bag of parts, so you can have it for yourself if you ever need parts down the road ie rebuilding engine etc? I doubt it lol, but wonder if they'd do it if you sign some waiver.
04-13-2023, 02:20 AM | #11 | |
However, I have decided not to have it done. It has about 35,000 miles on it, it's not modded and I drive it easy. My take is that iffen it ain't broke by now - don't break it. |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
04-13-2023, 11:24 AM | #12 | |
Drives: Crapcan
https://www.ft86club.com/forums/showthread.php?t=152946 They won't just give you the parts, they need to complete the recall repair. Or "repair" in this case. For S&G I asked my local dealer what if my car has aftermarket valve springs and they just looked at me like I asked them solve 4564534.4567/5456143.4567 without a calculator.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (04-13-2023) |
04-13-2023, 01:52 PM | #13 | |
The dealer is not able to give you the recall parts, however, you may be able to purchase them.
04-13-2023, 03:32 PM | #14 |
Drives: 2013 Scion FR-S Raven 6MT
Mine, 94k miles
Sent from my motorola one 5G ace using Tapatalk
Stay squatchy, my friends
Similar Threads | ||||
2013 Turbo FR-S Valve Spring Recall | uDasBoot | Issues | Warranty | Recalls / TSB | 26 | 02-21-2022 08:42 AM |
2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
2013 Scion FR-S Valve Spring Replacement Recall | Aussie | Northern California | 29 | 06-22-2020 01:51 AM |
Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
*California* 2013 Valve Spring Recall | Ankleguy | Issues | Warranty | Recalls / TSB | 14 | 09-30-2019 11:55 AM |
