04-10-2023, 06:25 AM | #113 | |
Drives: 2013 WR blue sport tech BRZ
04-10-2023, 06:31 AM | #114 | |
Drives: brz 2017 hksv2
No you can t mod the tune from the dealer of course, you d need an ecutek tune for your gr86 |
04-10-2023, 06:32 AM | #115 | |
And they only have that bogging sound when trying to rev from resting low idle under 750rpm yours is doing that all the time and sound more like a pop |
The Following User Says Thank You to tomm.brz For This Useful Post: | Ultramaroon (04-10-2023) |
04-10-2023, 06:35 AM | #116 |
From what I heard it's nearly Identical, happens at the same spot and everything. Mine does sound a bit more aggressive but that could be due to the amount of throttle applied or other factors. I can try to find someone to record the engine bay today but no promises.
The Following User Says Thank You to Nfsundrgrnd For This Useful Post: | Clipdat (04-10-2023) |
04-10-2023, 06:36 AM | #117 |
I've only heard that sound while blipping at Idle though, nowhere else. Logs might say otherwise but audibly it's the same.
04-10-2023, 06:37 AM | #118 | |
Here a V4 stage1 tune for you , with advance multiplier at 1 and timings for 91oct also raised idle and revised some few things at low rpm, the bogging should be away Stg1_B01C_V4_91oct_Clipdat |
The Following User Says Thank You to tomm.brz For This Useful Post: | Clipdat (04-10-2023) |
04-10-2023, 06:53 AM | #119 | |
but a bit less timing Stg1 A00C V4 91oct Nfsundrgrnd |
The Following User Says Thank You to tomm.brz For This Useful Post: | Nfsundrgrnd (04-10-2023) |
04-10-2023, 07:55 AM | #120 |
Mebmer
Drives: Sienna, GR86, FL5
Yeah to my ears your car did the exact same thing.
04-10-2023, 08:21 AM | #121 |
Hearing now with some studio headphone and amplifier, it is similar yes
still his sounds more poppy to me hope he can get a better video too |
04-10-2023, 08:40 AM | #122 | |
The difference between the 2 videos might be the amount of time the throttle is pressed. I would just Jab and release real quick but the gr86 video sounds more like when I keep applying throttle after the blip. |
04-10-2023, 09:04 AM | #123 |
better so.. try the v4 i did for u too
04-10-2023, 10:42 AM | #124 |
04-10-2023, 11:38 AM | #125 | ||
Proud of BOXER
Drives: Subaru Boxer
After just driving to work today (~5 miles), I checked OFT and STFT now at -1.56% (was 1.56% yesterday after flashing), and LTFT at 0.78% (was 4.68% yesterday). Throttle position still seems like it's learning and feels a bit awkward.
04-10-2023, 11:55 AM | #126 |
don t look too much at stft, it can vary between -20 and +20 or more and be totally ok, ltft gives a wider look at the trend since ltft is basically the average of stft through time
Similar Threads | ||||
Rough idle leads to stall, runs well under load, no engine response on throttle blip | gensch | Issues | Warranty | Recalls / TSB | 8 | 09-01-2021 08:26 AM |
Abnormal noise when throttle blip or WOT shifting | evo4g63 | Issues | Warranty | Recalls / TSB | 48 | 10-16-2014 08:42 AM |
Throttle Blip Hiss | Wepeel | Issues | Warranty | Recalls / TSB | 29 | 05-30-2014 11:56 PM |
Metal Grind Sound when throttle blip | JDM-dono | Issues | Warranty | Recalls / TSB | 0 | 11-17-2013 04:37 AM |
Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) -- General Topics | 39 | 03-07-2012 10:52 AM |
