Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
02-06-2023, 04:36 PM | #1 |
Injector service, what else should I tackle?
Looking for a little advice/insight.
2013 BRZ with ~75k miles, with JRSC for about 1.5 years ~10k. Looking do pull all the injectors and have them sent out for service this summer now that the car is 11 years old. Wow, she's gonna be a teenager soon... Anyways, in the name of preparedness while I've got the intake manifold off and the car down for a week or two, what else should be serviced/replaced? I've read several places from various car forums/articles the high pressure fuel lines should be replaced, they can be reused but its not recommended due to corrosion. What else would be a good preventive measure? Forward/both 02 sensor(s)? Fuel pump? Any particular hard-to-reach vacuum or coolant lines that tend to poo the bed by 100k miles? VVT oil control valves? Other stuff done recently- plugs, valve spring recall, and head/cam carrier gaskets (and coolant as well) were done at 60k in 2021. Last month I replaced the clutch due to a roached TOB, and checked oil pan pickup for stray silicone- there was some but it was minimal. Having the peace of mind was worth it after the valve spring recall but it appears they did a good job. The car has only ever had 91oct or better, (91 is our 93 at altitude). The only other problems I've run into have been a catch-can related vacuum leak throwing a code and replacing cyl 1 coil pack every few years. |
02-06-2023, 04:49 PM | #2 |
Rust bucket enthusiast
There shouldn't be anything worth worrying about on top of the engine really at any mileage. Your hoses and lines should be fine for at least another decade or two, if not longer with advancements made with automotive materials being used.
I redid all of my injector stuff and re-used old hard lines. There shouldn't be anything corroding your hard lines.. if there's anything on it, you can be that after a wire wheel touches it, it'll look like new. If nothing is leaking, no sense in fiddling with gaskets either if they're not already leaking. Same with your 02 sensors, just let them be. Replace your serpentine belt, make sure not to re-use any gaskets from things you've taken off- cleaning off the gunk from within the throttle body is a great idea too. Good luck!
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
02-06-2023, 05:58 PM | #3 |
Drives: Crapcan
The whole swap the hard lines thing is an issue with different cars, haven't heard of an issue with the twins. I know the older Duramax had issues with their hardlines, they were chrome lined and it would flake off and cause issues.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | wheelhaus (02-07-2023), x808drifter (02-09-2023) |
02-07-2023, 08:45 AM | #4 |
This is where you eyes come into play. Look everything over good. Replace anything that looks degraded or damaged.
The Following 2 Users Say Thank You to Grady For This Useful Post: | wheelhaus (02-07-2023), x808drifter (02-09-2023) |
02-07-2023, 04:43 PM | #5 | ||
I'm having the injector shop install new DI seals, but I wasn't expecting this many seals to need replacement, geez. Referring to the 3 seals/o-rings on the port injectors and 6 on the direct injectors. I imagine the clips might not be necessary but sometimes they don't spring back to shape properly. If its all recommended then of course I'll do it, but sheesh. Are some of these just spacers that can be reused? |
02-08-2023, 11:47 AM | #6 |
Well now, wheelhaus, I do believe in preventative maintenance, however, I also believe in that "iffen it ain't broke, don't fix it".
Unless any of the injectors are leaking or miss-squirting, I'd leave them alone. |
The Following 4 Users Say Thank You to humfrz For This Useful Post: |
02-08-2023, 02:32 PM | #7 | |
The Stig's African Cousin
Drives: 2014 wrb brz
I would replace the high pressure fuel lines shop manual calls to replace them. I replaced my lines when I replaced my injectors granted I was at 170k miles when I did it. But the extra piece of mind of not worrying about having a high pressure fuel line leak was worth the $70 it cost. Just make sure to triple check everything when putting it back together, the port injectors sometimes don't seat right on the seals so they can leak. Happened to me once. Caught while running the engine after I finished putting everything back together.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
The Following User Says Thank You to brandonblt2 For This Useful Post: | wheelhaus (03-21-2023) |
02-08-2023, 03:04 PM | #8 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Too often I use the alternative approach. Iffen bit ain’t broke I fix it til it is.
Slow is smooth, and smooth is fast
The Following 7 Users Say Thank You to Capt Spaulding For This Useful Post: | humfrz (02-08-2023), NoHaveMSG (02-08-2023), PikachuBRZ (02-16-2023), soundman98 (02-08-2023), Ultramaroon (02-10-2023), wheelhaus (03-21-2023), x808drifter (02-09-2023) |
02-09-2023, 03:27 AM | #9 |
LMGTFY
Drives: 13 FRS, 91 Miata
The Following 2 Users Say Thank You to x808drifter For This Useful Post: | soundman98 (02-09-2023), Ultramaroon (02-10-2023) |
02-18-2023, 03:40 PM | #10 |
Drives: 2016 Scion FRS Release Series 2#439
PCV.
Remove and clean or just replace.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
The Following User Says Thank You to Muskoka800 For This Useful Post: | wheelhaus (03-21-2023) |
03-21-2023, 02:49 PM | #11 | ||
Is there any other realistic way to check/diagnose flow issues/miss-squirting without pulling them for a bench service (aside from noticeably running rough/rich etc)? I figured this is a good way to ensure she's happy with boost for another 10 years. Quote:
Already on order. I've noticed some oil residue around it so its just getting replaced. I've had a few minor vacuum issues with the PCV side catch can, and the original PCV may have contributed. |
The Following User Says Thank You to wheelhaus For This Useful Post: | humfrz (03-21-2023) |
03-21-2023, 05:00 PM | #12 |
Drives: Nevermorange FRS
It's a 2013...
If the Intake Manifold is off, it's a GREAT time to update the wiring harness and coil packs to 2015+.
SCCA T4 - FRS
03-21-2023, 07:14 PM | #13 |
I have heard mention of the harness upgrade, but haven't done a deep dive into it yet. Repeated P0351 misfires, ultimately cyl 1 coil pack failures, have happened like clockwork every 2-2.5 years.
03-21-2023, 11:36 PM | #14 | |
Yep, life was simple, adjustments were made with two screws and if the float got stuck, ya jest rapped on the side of it with the handle of a screwdriver. |
Similar Threads | ||||
Fuel injector Service? | HeadBanger | CANADA | 7 | 02-03-2016 10:52 PM |
Best way to tackle the torque dip | Kuri | Engine, Exhaust, Transmission | 37 | 02-27-2014 07:52 AM |
