BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
01-31-2023, 12:23 PM | #15 |
Drives: 2013 frs base
Easiest solution might be to use the 2017 short block and with your 2013 heads.
01-31-2023, 12:38 PM | #16 |
Not a word about crankshafts in the propaganda... I mean dealer literature. Since they go into great detail when speaking to the rocker arm pivot changes I would think it would be mentioned.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (01-31-2023), soundman98 (02-01-2023) |
01-31-2023, 12:44 PM | #17 |
Drives: Crapcan
I looked earlier. All part numbers supersede to the same one. So 13' reluctor should fit and index correctly.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
01-31-2023, 01:16 PM | #18 | |
JHerbert Racing
Drives: 2013 Scion FRS
Not everyone cares to spend the money and time on a higher HP or insta-famous swap. This is interesting to me bc for a few grand I can be back at the track with a slightly upgraded engine in a weekend without the hassle of custom parts, swap kits, standalone, tunes, ect. Most people probably just want to get their car running again and found a 2017+ engine and want to know if it can work. Swapping to a K engine is MUCH more trouble that a 2017+ engine replacement.
The Following 5 Users Say Thank You to Takumi788 For This Useful Post: | NoHaveMSG (01-31-2023), soundman98 (02-01-2023), Tcoat (01-31-2023), Teseo (02-01-2023), x808drifter (02-01-2023) |
01-31-2023, 01:40 PM | #19 | |
Although not a plug and play the Facelift upgrade makes a pile more sense. Oh and it has not been mentioned but anybody changing a FA20D for a FA20D needs to understand there are things that need to be done if the engine is from an AT or MT regardless of year.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
Similar Threads | ||||
2017 fa20 engine into 2013 car? | ROADRACER | Engine, Exhaust, Transmission | 91 | 12-28-2021 11:52 PM |
Performing FA20 swap with new FA20 | Ctoner2653 | Engine Swaps | 8 | 09-24-2021 08:40 AM |
Timing CELs after 2017 engine swap into 2016 | mauly | Issues | Warranty | Recalls / TSB | 4 | 08-06-2020 06:54 PM |
Blown 2016 FA20 swap 2017 FA20 | HRLQN | Engine Swaps | 11 | 10-15-2019 07:17 AM |
4UGSE/FA20 engine or swap? | jordydiaz | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-04-2012 06:00 PM |
