11-01-2022, 04:17 PM | #99 |
Drives: None
So, funny story...
I put Whiteline bumpsteer correction balljoints and tie rod ends into the car a couple of weeks ago so I also threw in SuperPro caster correction and flca rear bushings into the arms since they were out. I lowered the car to roughly SuperMiata/949 recommended height but ended up putting the front way lower than I meant to because my pinch welds up front were smashed higher than I realized at the time. Front: Fender to ground: 24 3/4" Pinch to ground: 5" / 127mm (this is clearly wrong based on fender to ground delta) Rear: Fender to ground: 25 7/16" Pinch to ground: 5 3/16" / 132mm I also had the car aligned to -3.75* / -2.75* and 0 toe all around. For whatever reason the car did not cut EPS the entire weekend. I have no explanation. Car would not put down power in 2nd gear exit corners and was super loose after going on throttle mid corner in 3rd/4th gear corners, but I attribute that to the way higher than intended rake and the turd-ass AR1s. Either way, interesting. We will see if it holds through the bowl at Chuckwalla in two weeks.
11-02-2022, 12:46 PM | #100 |
Drives: None
I talked to the guy that makes these today: https://www.nmstec.ca/product/psc/
He said the issue is power delivery and that he was able to replicate the cut out on his bench. Apparently, the unit demands a bunch of assist at first movement then drops down, which causes a big demand draw up front and leads to the cut out. He says that his unit doesn't create the initial demand spike, which prevents the issue from happening.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | gt5759 (11-03-2022), whataboutbob (01-04-2023) |
11-02-2022, 02:08 PM | #101 | |
Drives: Frankenstein of parts
The Following 7 Users Say Thank You to Nmstec For This Useful Post: | bcj (11-02-2022), DarkSunrise (11-03-2022), DocWalt (11-04-2022), gt5759 (11-03-2022), ML (11-03-2022), RedReplicant (11-02-2022), whataboutbob (01-04-2023) |
11-03-2022, 12:50 PM | #102 |
Drives: 2017 BRZ
Here is what we have been using on several builds, I figured all this stuff was a little more known but I guess not! https://www.brunosteering.com/produc...ller-kit-epas/
They also have fancier versions with gps speed control or you can operate it with a haltech or any other stand alone engine management. |
11-03-2022, 01:18 PM | #103 | |
Drives: 2013 BRZ HKS Turbo
11-03-2022, 05:01 PM | #104 |
Drives: 2017 BRZ
11-03-2022, 05:33 PM | #105 |
Drives: 2015 FRS
Glad to hear there is a cheaper option that works. Thanks for sharing.
11-14-2022, 12:24 PM | #106 |
Drives: None
Update on my issue disappearing with the stock EPS / stock controller, it was there at Chuckwalla. Cut in a handful of corners every lap, the bowl was terrible.
11-14-2022, 12:31 PM | #107 | |
11-14-2022, 01:12 PM | #108 |
Drives: 2017 BRZ
Yeah, we use the Haltech via analog voltage for control and remove the switch he sends. For most the rotary switch he sends should be adequate, the other way is just fancier and don't have an external knob. All I know is it works great for a race car application as we don't have steering cut.
11-14-2022, 04:22 PM | #109 |
Hey while I'm here, may as well compare my **** size with brunos lol.
Here's demo UI for my controllers in case someone needs slightly more features: psc-demo.nmstec.ca/ |
The Following User Says Thank You to Nmstec For This Useful Post: | DocWalt (11-15-2022) |
01-03-2023, 11:15 PM | #110 |
Drives: 2013 BRZ sprintex SC
01-03-2023, 11:36 PM | #111 | |
Is there an option\map that mimic the oem steering wheel ,without the peak current at initial turn? |
01-04-2023, 12:19 AM | #112 | |
Control can be done in whatever method you like, potentiometer, canbus control, canbus VSS map, anything you can think of. The peak current is not done by my controller, it is done directly with the OEM steering system when you do a fast input (high torque, high assist). You can simply dial down the assist with my controller, that in turn will also produce a lower current peak during fast inputs. |
The Following User Says Thank You to Nmstec For This Useful Post: | whataboutbob (01-04-2023) |
Similar Threads | ||||
rattling when braking | Latiii | Issues | Warranty | Recalls / TSB | 14 | 08-07-2014 12:16 PM |
Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-20-2013 11:45 PM |
Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 04:52 PM |
Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 01:19 AM |
Braking Issue In Mid Drift | imravenit | Tracking / Autocross / HPDE / Drifting | 12 | 02-12-2013 03:16 AM |
