12-20-2022, 01:02 AM | #211 |
Drives: Toyota 86
FA20DIT bore is 86 mm. How can they be used in 94 mm bore cylinders? Or did you mean FA24F, the turbo version of FA24?
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
The Following User Says Thank You to makinen For This Useful Post: | Opie (12-20-2022) |
12-20-2022, 07:57 AM | #212 |
Drives: '13 BRZ TLM Spec
My bad, you are correct. FA20DIT pistons would be a little loose....FA24 Turbo pistons. (Ascent, Outback XT, Legacy XT, WRX)
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
12-20-2022, 04:44 PM | #213 | ||
Drives: 2020 BRZ Sport Tech RS
I'd be surprised if they swapped the pistons out, since they'd probably have to machine the heads either way. Also considering the claimed HP, I'd think it would be hard to hit that NA with the reduced compression of the turbo pistons (though again, I don't put a whole lot of stock in those dyno sheets).
12-20-2022, 07:41 PM | #214 |
IIRC one of the 2 engines uses a domed (sp) piston, so it protrudes out of the block and into the cylinder head, and the other does not...this causes a clearance issue when trying to use the FA24 block with FA20 heads...so pistons likely need to be changed out.
12-20-2022, 08:16 PM | #215 | ||
Drives: Crapcan
Speculating super hard of course
12-21-2022, 02:26 PM | #216 |
chicken tonight
Careful! Don't pull a muscle.
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (12-21-2022) |
12-21-2022, 02:28 PM | #217 |
Drives: Crapcan
More likely just a repetitive stress injury.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
01-20-2023, 11:40 AM | #218 |
Drives: 2017 Subaru BRZ
Opie, you make any progress securing the shortblock?
The Following User Says Thank You to raspec For This Useful Post: | jflogerzi (01-20-2023) |
02-15-2023, 07:38 AM | #219 |
I have also been watching this very closely. I understand there is now a U.S. based version of this but I can not seem to find the info on it. Anyone else made any progress. I do have access to all the parts required and am very much just considering doing this on my own and figuring it out. I will actually video and document all the changes required so as to make this available to the public. I think this is the future for the first gen platform. Also worth mentioning that I thought the FA24 has a 13.5:1 CR so machining the heads should put the CR somewhere in the 12-13 range.
02-15-2023, 08:00 AM | #220 | |
Drives: 22 BRZ limited
The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | c.klingner (02-15-2023), Irace86.2.0 (02-18-2023) |
02-15-2023, 01:29 PM | #221 |
**Heavy Breathing** Watching very closely :P
2013 Series 10 FRS #553
02-15-2023, 04:46 PM | #222 |
I never reorderd one after my last two orders were cancelled. Definitly on the back burner now...
02-15-2023, 08:40 PM | #223 |
Drives: JRSC BRZ SOLD
From Revolution Garage in Japan.
FA24 in MY12-13 TA LW86 http://revo-tune.jp/feature-areitcle.../02/14/id17999 2023-02-14 After successfully starting the late model engine in the first half of the ZN6, the second FA24 engine change & start confirmation, current car setting completed @ 264 horsepower (5th gear measurement, tcf1.15) This project started a few weeks ago, and if we can put a late model engine on the early ZN6 and start it, we should be able to teach the FA24 as well. ? This question has been resolved today. Since the start of the late model the other day, I replaced the wiring of the crank angle sensor and some harnesses and redid it and succeeded in starting the FA24. The starting data was a normal ECU in the latter half of ZN6, but it ran normally, but it felt different. The bottom two lines of the graph are ZN6 late genuine data, and although it started at around 220 horsepower, it was a "poor" start. It's a set measurement, but the graph is completely different from ZN6, and the measured value is about 235 horsepower, well, I hit it well. . Then, while searching for the optimum value of ignition timing in the entire range, I set it to about 245 horsepower, but somehow the knock point was low, and the ignition did not enter at all compared to the FA24 data of GR86LW. Suddenly, I came up with the FA24 surge tank, and when I looked at it seriously, the capacity was completely different. ? ? I immediately installed the FA24 surge tank together with the throttle, and although some processing such as the auxiliary parts stay was necessary, I installed it. As soon as it was turned, 15 horsepower increased to 260 horsepower, and the ignition became easier, and the ignition map was corrected to 264 horsepower. The two FA24s, FT86LW and GR86LW, will run at Attack Tsukuba on Sunday and 18th. |
The Following 5 Users Say Thank You to PulsarBeeerz For This Useful Post: | blsfrs (02-15-2023), captain awesome (02-16-2023), JBezugs (02-17-2023), Tatsu333 (02-17-2023), timurrrr (02-20-2023) |
02-17-2023, 11:44 AM | #224 | |
So from reading the article alongside the other photos there, it looks like a full FA24 motor swap using the 17-20 ECU and a number of wiring / sensor changes in the engine compartment to make that work. Also seems that the FA24 intake manifold (translated as "surge tank") is necessary for the best power output with the bigger block. From the side-by-side shot of the two manifolds (linked below), it appears the FA24 manifold has both longer and larger runners (longer because of the "M" shape or "W" looked at upside down like in the photo, and larger because of the thinner walls of the plastic manifold vs. aluminum despite them looking comparably bulky), which explains the latter. (Begs the question could a 2nd gen manifold make power on a 1st gen without losing a lot of bottom end? Anyone want to spend $363.28 USD to find out?) Link to article photo of intake manifolds (I tried to just insert the image, but for some reason it doesn't appear) Gives us some more specific direction for how best to approach the swap down the road, anyway, which is great! The bad (sort of) news is that it seems like the best route will be to pick up a complete FA24 engine including manifold, rather than just a short block, so cost will obviously be more. Good in that you won't have to monkey around with mating the FA20 heads to the FA24 block though. A complete motor was logically going to be the best route all along if the ECU was compatible, so no big surprise there.
Last edited by Tatsu333; 02-17-2023 at 11:47 AM. Reason: Added link and pricing info for 2nd gen intake manifold |
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
