08-14-2022, 12:02 PM | #645 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
08-14-2022, 02:06 PM | #646 |
Drives: 2015 FR-S
Most likely we're seeing Subaru switch to multicolor RTV in the middle of production to "debug" a sealant issue. They probably found out something, switched to multicolor to find out which sealant affected the oil passage/pickup blockage the most. Maybe like red for blockhalf, green for upper oil pan etc. looks like not everyone sees the multicolor yet.
@Petah78 if you look around your valve cover / timing cover do you see any different coloring of RTV? |
The Following User Says Thank You to FrickingReallySlow For This Useful Post: | Dake (08-14-2022) |
08-14-2022, 03:08 PM | #647 | |
08-15-2022, 03:19 AM | #648 | ||
Grey Man
Drives: 22 MT BRZ
A screen is not meant to stay obstructed/clogged permanantly with debris. Even IF removing an oil pan could be considered "altering or tampering with the engine," which I challenge as BS, the faulty manufacturing process causing the oil pickup screen to be clogged prematurely and frequently makes null and void that line item in the warranty pertaining to access and remedy of said problem. Also, it seems farfetched to say that reapplying RTV sealant that was put on wrong at the factory in the first place is "altering or tampering with the engine." With all the pictures and video of sloppy application of RTV, and RTV found in pickup screen and oil filter, they have little to no legs to stand on there. A warranty is not a writ of a dictator. If something about it isn't fair or just, it would not hold up under scrutiny of law. Further, I highly doubt either Subaru or Toyota would want or expect anyone to not try to remedy a known issue that could lead to catastrophic engine failure. On the flip side, there could be tremendous liability issues if someone were to get hurt trying to access and unclog a screen known to be caused by faulty manufacturing process that potentially leads to catastrophic engine failure. This is a very serious issue. So tell me, has there been instance of anyone on social media or anywhere else, that removed the oil pan and found no RTV debris in the oil pickup screen? I don't recall seeing any. If everyone looking is finding it, this indicates the problem is very wide spread. No, I am not a lawyer or an automotive engineer. I'm not giving advice, just calling out BS. Last edited by *Axel; 08-15-2022 at 06:24 AM. |
08-15-2022, 06:55 AM | #649 | |
1st86 Driver!
If you pull the oil pan, document that there is no issue (or even if you don't) and later you have an engine failure due to oil starvation, how are you going to prove you didn't cause the problem? Now, the dealership/Toyota/Subaru may not know you dropped the pan and reapplied the sealant, in which case sure you may get away with it. I suppose you could also use a different color sealant, which may or may not prove your point (it also could disprove your point by being self-incriminating). No one is saying you don't have the right to do this, or any other service on your vehicle but I don't believe you can say with any more certainty that it won't impact warranty. If say, you did your own oil change, and inadvertently left a gasket on the oil filter, or forgot to replace the drain plug, and this caused engine damage I doubt it would be covered by warranty. This is the same thing.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 08-15-2022 at 03:29 PM. |
The Following 4 Users Say Thank You to Dadhawk For This Useful Post: |
08-15-2022, 07:50 AM | #650 | |
The discussion about warranty denial, specifically for removing, the pan is relevant and necessary. We have already seen denial of warranty for "tampering" many. many times in the past. Hell, there were warranty denials on engines where Subaru techs were the ones that reapplied sealant! To ignore the subject because your opinion is different would be irresponsible. All I have said was that the LAW on the subject gives them the ability to deny warranty if the engine has been altered by an unauthorized person. This is a fact not an opinion. That does not mean that all dealers WILL deny warranty but it does mean they CAN. Of course you can can argue it but as you said you are not an engineer nor a lawyer whereas Toyota/Subaru has thousands of both. If they want to play hardball on the subject they are going to win no matter what your thoughts on what is "fair". This is not "fear mongering" but simple risk assessment. If you open up your engine you RISK warranty denial. Plain and simple. The even worse part is that removing the blockage on it's own is no guarantee that you have resolved the whole issue. Not sure how the people that say just drive it and if it blows seek warranty (I have never said that) all of sudden turns into as "an agenda to influence people to let their engines be ruined". It is a valid option even if it is the worst case one.
The Following 7 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (08-15-2022), FRSBRZGT86FAN (08-17-2022), OkieSnuffBox (08-15-2022), Opie (08-16-2022), Petah78 (08-15-2022), soundman98 (08-15-2022), Sport-Tech (08-16-2022) |
08-15-2022, 07:54 AM | #651 | |
Keep in mind that the whole engine is sealed with this stuff not just the oil pan and timing cover.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (08-15-2022) |
08-15-2022, 07:57 AM | #652 | ||
Grey Man
Drives: 22 MT BRZ
Because the current issue at hand necessitates an urgency to check for problems that can and have caused catastrophic engine failure. There is plenty of evidence to counter that argument, that the customer/owner caused the failure simply by inspecting for that very problem of improperly applied sealant at the factory clogging the oil pickup screen. Quote:
08-15-2022, 08:00 AM | #653 | |
Although a sample size of one this is a data point that has been missing. Your finings show exactly what I was afraid of in my earlier essay! In all probability you had run the engine long enough to catch all the particles so none showed up during your oil change. Of course some would have made it through the whole system but eventually got caught. To make a wild guess I would say that if your engine is still good now you are probably out of the woods.
08-15-2022, 08:07 AM | #654 | |
How the hell does discussion on a subject turn into people wanting to "get off on gen 2 engine failures"? There is an issue. It has many faucets. Those thing are discussed. Get off your high horse and come to reality.
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (08-15-2022) |
08-15-2022, 08:23 AM | #655 | |
I need a stake it it to discuss it? Discussing all the aspects of an issue means I am a shit disturber? If you have any clue at all you will see that I am one of the most active commenters on many things. I find it interesting and being in the industry informative. I repeat I have never once told anybody not to check because they will "void" their warranty. I have said to be aware that they may have problems with the dealerships if they have a failure and do need warranty. At what point have I given any indication of "gloating" ? That is your own vivid imagination and paranoia at work. So far you have contributed nothing to this conversation other than to attack me personally. I don't give a rat's ass about your opinions. Let's deal with some facts. Your post is the sort of crap that gives Boomers a bad name!
The Following 8 Users Say Thank You to Tcoat For This Useful Post: | CincyJohn (08-15-2022), Dadhawk (08-15-2022), dawsonj87 (08-15-2022), endless_pain (08-15-2022), FRSBRZGT86FAN (08-17-2022), Opie (08-16-2022), Shrapnel (08-18-2022), soundman98 (08-15-2022) |
08-15-2022, 09:03 AM | #656 | ||
1st86 Driver!
I said nothing about "social media". You could be troglodyte living in a cave somewhere, if you pull the pan and reseal it yourself you are causing potential warranty issues.
As @Tcoat said, I'm not saying not to do it, I'm saying weigh the risks. Might be worth the money to have the dealer do it, might not be. That's up to the individual to decide. Quote:
BTW, I don't have a stake in this either, other than an interested party. I did live through the valve spring issue, which was very similar (basically the same issue). Fortunately for me I had a competent mechanic who did the repair correctly, but I do feel for those that have failures then and now.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | soundman98 (08-15-2022), Tcoat (08-15-2022) |
08-15-2022, 09:07 AM | #657 |
1st86 Driver!
In fact, it's the very option a lot of owners chose on the valve spring recall.
08-15-2022, 09:30 AM | #658 | |
Drives: 2018 Subaru BRZ
JFC dude, show me on the doll where the tcoat touched you. Everything okay back at home? |
The Following 11 Users Say Thank You to spcmafia For This Useful Post: | Dadhawk (08-15-2022), flippy (09-13-2022), FRSBRZGT86FAN (08-17-2022), Ghost of Akina (08-15-2022), Lantanafrs2 (08-15-2022), mycrors7 (08-15-2022), NoHaveMSG (08-15-2022), OkieSnuffBox (08-15-2022), soundman98 (08-15-2022), Sport-Tech (08-16-2022), Tcoat (08-15-2022) |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
