Old 07-19-2022, 01:33 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
How to remove Rain-X?
How does one remove the Rain-X film from a windscreen? I've tried glass cleaner, metho, white spirit, nail polish remover, laundry detergent, cloudy ammonia. Each time I get the cloudy streaks of Rain-X that I can dry wipe so the windscreen is clear but the film is still there.
Old 07-19-2022, 02:13 AM   #2
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
rubbing alcohol, dishwasher soap, or straight vinegar.
It does wear off over time.
2020BRZtS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
soundman98 (07-19-2022), spcmafia (07-19-2022)
Old 07-19-2022, 06:51 AM   #3
Sapphireho
helmholtz resonator
Sapphireho's Avatar
Drives: '15 ultramarine
Every time I've ever used it it is gone in about 10 minutes of rain. Guess I need some Aussie rain-x.
Cleaning vinegar?
Dadhawk (07-19-2022), soundman98 (07-19-2022)
Old 07-19-2022, 06:51 AM   #4
spcmafia
Drives: 2018 Subaru BRZ
Dawn soap, clay bar, and then follow up with Griots Glass Polish. You gotta replace the wiper blades because they carry residue.
Also, make sure that your windshield fluid is not the Rain-X one by some reason because then you're back to step 1.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Old 07-19-2022, 07:00 AM   #5
Captain Snooze
Drives: Red Herring
I forgot to mention in my first post that I tried a clay bar.
Griots Glass Polish doesn't seem to be available locally. I will look for an alternative.
F*ck this has turned into a waste of money.
Old 07-19-2022, 07:04 AM   #6
spcmafia
Kind of odd that it is still there. Dawn should do the trick. Mix it in a spray bottle, 1 part of dawn, rubbing alcohol, and some water. See if that works.
Yours must be really caked in.
Old 07-19-2022, 07:04 AM   #7
Captain Snooze
Drives: Red Herring
Metho seems to be almost identical to rubbing alcohol. As mentioned metho didn't seem to work. I shall try some vinegar.
Old 07-19-2022, 07:10 AM   #8
spcmafia
Any dish-soap that has a heavy de-greaser property would do. Hell, if you want me to send you some, let me know. Im about to go to Costco tomorrow so I'll hook you up with the biggest bottle I can find.
Old 07-19-2022, 07:27 AM   #9
Sapphireho
helmholtz resonator
Sapphireho's Avatar
Cleaning vinegar is more acidic than regular vinegar.
Edit: this is what came up on Google..
Rain-X is a commercial formula used to repel water, rain, and snow from glass. To remove Rain-X, first mix equal parts water and white vinegar in a spray bottle. Then, spray the solution onto your glass and rub it in with a cloth. Once you've gotten rid of the Rain-X, use a new dry cloth to wipe away any residue.
Old 07-19-2022, 11:51 AM   #10
I have attempted to remove RainX off a couple of cars.
Alcohol helps (if you drink it since it doesn't do a bloody thing the that film)
Clay barring just gives it a nice slick surface.
Glasscleaners run off just like the water.
Changing wiper blades is fine once you get rid of the stuff.
There was only one thing that I found that completely got rid of that devils brew of chemicals and waxes...
jcw99 (07-27-2022), soundman98 (07-19-2022)
Old 07-19-2022, 11:56 AM   #11
Old 07-19-2022, 12:25 PM   #12
1st86 Driver!
OK, gotta ask, what's the issue with RainX that you would go to all this trouble to get rid of it? I used it for decades off and on with no issue.
Old 07-19-2022, 01:31 PM   #13
MX-5RACER
Drives: 1999 Miata
I had an old bottle of RainX that would last forever. I got a replacement from Walmart and that crap would barely make it through one rain storm before it was gone. This is when I found out that Walmart has their own "special" products that are not always the same as the higher priced versions carried at other stores.
I bought my last bottle of RainX at an autoparts store and it seems to last at least a month here in rainy S. FL.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 07-19-2022, 02:32 PM   #14
I had it on two cars. All it ever did was smear and distort the vision. Hated it!
Desertnate (07-25-2022), sato (07-23-2022)
Rain rain rain! Phantobe Southern California 9 12-15-2015 01:28 AM
FI Hood insulation: To remove or not to remove bryan767 Forced Induction 8 08-15-2015 04:51 AM
Rain! cycleboy Southern California 34 03-04-2014 03:31 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Rain, rain go away! Partial Stall New England 26 06-05-2012 06:55 PM
