10-11-2020, 09:29 PM | #225 |
Anti stance.
54mm should be the minimum.
10-11-2020, 09:41 PM | #226 |
Seņor Member
Based on what? That sounds way too big to me. If you can make 270hp on 50mm ITBs on a 3SGE beams revving over 9k rpm what would make you think the FA20 (that cant even safely sustain revs to 8k) would need TBs that big?
Edit: After some googling I am guessing you are used to Hondas. FA20 =/= K20. FA20 is lower revving and doesn't have the Vtec big cam to deal with.
1974 TA22 Celica
2013 86 GT Last edited by Turdinator; 10-11-2020 at 10:21 PM. Reason: vtec yo |
10-12-2020, 11:15 AM | #227 |
Anti stance.
Based on wanting make any real gains.
10-12-2020, 01:54 PM | #228 | |
Drives: JRSC BRZ SOLD
The first dyno used the Greddy 48mm ITBs and supplied plenum. The second dyno used the Sard ITBs and no plenum. SUR Fab a NZ company that makes some very nice CNC 50mm ITBs for the 3SGE as well. But IDk at least with the plenum installed you could get the same affect or better from the RacerX IM for >$900. Swapping out ITs easily doubles the cost.. |
10-12-2020, 02:38 PM | #229 |
LMGTFY
Drives: 13 FRS, 91 Miata
Stock head flows 265cfm.
With the butterfly's so close to the actual valves honestly the sizes on both the kits are way too big. Read: https://racehead.com.au/designing-pe...-should-i-use/ Source of head flow https://dsportmag.com/the-tech/educa...ylinder-heads/ |
The Following User Says Thank You to x808drifter For This Useful Post: | Turdinator (10-12-2020) |
10-12-2020, 10:18 PM | #230 |
Anti stance.
Lol.
06-25-2022, 04:12 PM | #231 |
Drives: 18 BRZ tS, 27 GRMN 86
06-28-2022, 03:36 AM | #232 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
The Following User Says Thank You to cyde01 For This Useful Post: | Drifter X (06-28-2022) |
06-28-2022, 08:47 AM | #234 |
Drives: 2013 frs base
I'd be curious to know how the ecu monitors intake air volume without a MAF or MAP. If not monitored it's almost like having multiple carburetors.
06-28-2022, 10:21 AM | #235 |
Drives: 2014 GT86
Just install 4 sensors
06-28-2022, 12:47 PM | #236 |
06-28-2022, 11:32 PM | #237 |
Drives: 2014 GT86
Obviously. Kind of trolled a bit
06-28-2022, 11:40 PM | #238 |
Drives: frs
Then you are at the territory of FI price wise
Similar Threads | ||||
In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 683 | 06-07-2020 06:26 PM |
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 04:24 AM |
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 12:17 PM |
RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 01:12 PM |
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
