Software Tuning Discuss all software tuning topics. |
Drives: ZA1JA03N
Look for the ZA1JA03N complete RomRaider Editor Definition definition file.
I found ZA1JA03N my RomRaider Editor Definition is incomplete. Searched the forum and there is no, only ZA1JA01g. thanks. |
#2 |
Drives: FT86
#3 | |
Drives: ZA1JA03N
#4 | |
Drives: ZA1JA03N
#6 |
Drives: FT86
Are you using romraider and oft roms or ecutek ?
oft A03N will be based on a substitute rom and that will confuse ecutek if ecutek use ecuteks editor if you want to edit genuine A03N roms |
#7 | |
Drives: FT86
post up tje rom your trying to edit here ill jave a look |
#8 |
Drives: ZA1JA03N
ecutek is missing some table definitions, such as overrun, I use romraider to edit the missing table in the stock ROM, and then use ecutek to edit it.
#9 |
Drives: ZA1JA03N
#10 | |
Drives: ZA1JA03N
genuine A03N roms,and RR_ZA1JA03N.xml,Incomplete definition, like my first post. 03n.zip |
#11 |
Drives: ZA1JA03N
After modifying RR_ZA1JA01G.xml, an error is displayed.
#12 | |
Drives: FT86
OK my trick with definitions only works with OFT roms as their A03N tunes are actually based on A01G roms you could just use A01G in your car as a substitute for the A03N rom. There are no romraider definitions for genuine A03N roms however easier to just use ecutek if you have it Ecutek has all the tables you need in the A03N they are just called different names The idle overun tables you want are called "Ignition Timing Idle" there is about 6 tables defined more than romraider in A01G they are under Ignition timing folder in ecutek they are fully defined so just edit your A03N rom in ecutek |
#13 | |
Drives: ZA1JA03N
ecutek prevents me from flashing the A01G. If I flash the A01G with ecuflash, I will lose the ecutek license. Is there a way to transplant the rr definition of A01G to 03N? |
#14 |
Drives: FT86
sent you private message
The Following User Says Thank You to steve99 For This Useful Post: | nerve86 (06-07-2022) |
2019 86 ZA1JN01A Definition file | Whit_grf | Software Tuning | 3 | 03-19-2022 12:27 AM |
ecuflash definition file help | Plumpkibbles | Software Tuning | 1 | 10-13-2018 05:19 AM |
Romraider cannot read definition (OFT FlexFuel) | yelsew | Software Tuning | 2 | 05-24-2018 06:32 PM |
RomRaider help? ECU definition cannot be found even when present? | Xaftos | Software Tuning | 9 | 09-27-2017 06:13 PM |
Edit OFT Definition for RomRaider | blackspike | Software Tuning | 7 | 02-13-2016 03:18 AM |
