Northern California NorCal
Old 05-19-2022, 07:48 PM   #1
sftateofmind
Evening Primrose
sftateofmind's Avatar
OEM Clutch Kit From Subaru dealer
Serramonte Subaru quoted me $1100 in just parts for me 2013 BRZ. Seems like a lot. Am I trippin or?
sftateofmind is offline   Reply With Quote
Old 05-20-2022, 12:46 AM   #2
mou
mou's Avatar
Drives: 99 impreza,13 brz, 22 maverick
I was quoted about 800 from numerous non-dealer shops for it a few years back
mou is offline   Reply With Quote
The Following User Says Thank You to mou For This Useful Post:
sftateofmind (05-20-2022)
Old 05-20-2022, 09:46 AM   #3
I see about $800 if you have to replace the flywheel. Almost half that if just the main clutch parts.
https://parts.subaru.com/p/Subaru__B...0100AA870.html
Old 05-20-2022, 11:21 AM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
My dealer did the clutch and flywheel swap for $1200 out the door. Parts were ~$800 IIRC.
Old 05-20-2022, 03:51 PM   #5
sftateofmind
Evening Primrose
I’m being told my entire clutch kit + service will be $2800
Old 05-20-2022, 03:53 PM   #6
sftateofmind
Evening Primrose
Which dealer is this if you don’t mind me asking. More than half what I was just quoted by a shop.
Old 05-20-2022, 05:25 PM   #7
Yoshoobaroo
TRACKBREAD
Sorry this is in Florida, just wanted to give another datapoint for parts costs.
Old 05-20-2022, 06:15 PM   #8
alphasaur
friendly
Drives: 17' 86
Why go to a dealer? Find a small speed shop familiar with working on the car. Should be 1-1.5k including labor depending on what clutch you want
Seek comfort in discomfort.
alphasaur is online now   Reply With Quote
Old 05-20-2022, 07:39 PM   #9
TheFugitiveMind
The OEM clutch is made by Exedy
Exedy Part FJK1005 Clutch Kit - If you search online you can pick it up for around 300
Exedy Part TYF001 Flywheel - 160 bucks
Rockauto.com is highly reputable to source OEM parts. You just need to have a little bit of knowledge of the OEM part numbers. Prices are some of the best out there.
If you are doing the clutch, I would highly recommend doing the Verus Clutch Fork and Pivot Ball along with a new OEM throw out Bearing. (You can get the TOB at the dealer for under 35 bucks)
TheFugitiveMind is offline   Reply With Quote
The Following 2 Users Say Thank You to TheFugitiveMind For This Useful Post:
dpfarr (05-21-2022), soundman98 (05-23-2022)
Old 05-22-2022, 07:14 PM   #10
clio
Drives: 2013 Subaru BRZ
Are you sure they are the same? I've found Exedy 'oem replacement' clutches are not the same as oem. Take the Exedy part you mention FJK1005 and compare it to the oem clutch:
Exedy
https://www.ftspeed.com/part/2013-20...t#.YorCSuxBxGE
OEM
https://partsouq.com/es/search/all?q...870#30100AA870
clio is offline   Reply With Quote
Dealer or shop for TOB and clutch replacement? FRSFather Issues | Warranty | Recalls / TSB 32 10-05-2018 11:10 AM
Windows, Tranny/clutch, dealer issues. Help! Chalk Issues | Warranty | Recalls / TSB 9 02-15-2015 03:11 PM
Clutch Issue with Dealer and HPDE yzarc0g Issues | Warranty | Recalls / TSB 52 06-28-2014 06:24 PM
Dealer installed new clutch assembly -- is there a break-in period? Meanderchap Engine, Exhaust, Transmission 22 04-03-2014 08:41 PM
Servicing my FR-S at Subaru dealer rather than Scion dealer dnL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 08-28-2012 07:25 AM
