04-10-2022, 08:40 PM | #85 |
Drives: 2017 Toyota 86
I believe they are the B6. The photo is from an earlier post from RCE.
Sent from my SM-G781U using Tapatalk |
04-11-2022, 12:48 AM | #86 |
Professional wrench
Drives: 2020 BRZ ST RS
I noticed this as well(in the picture) and I don't care for that. Thats changing the spring preload.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
04-11-2022, 04:58 AM | #87 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Does that change once the car is sitting on its own weight and the springs are compressed holding the vehicle up
Wait until my Flex capacitor hits 88
04-11-2022, 07:07 AM | #88 |
Drives: '23 BRZ
Hmm, going from stock PP/Sachs to B8s didn't change ride height on Swift springs for me at all. 12 7/8" all around before and after.
04-11-2022, 09:21 AM | #89 |
It's not a good picture y'all, I wouldn't read too much into it. I'll take a better one of the rears vs stock later this week.
- Andrew |
04-11-2022, 09:25 AM | #90 |
Can we compare the B8s also?
04-11-2022, 09:37 AM | #91 |
04-15-2022, 02:32 PM | #92 |
Drives: BRZ 2018
Waiting Andrew, as I understand B6 with lowering springs is better choice than the B8 as they have more suspension travel
The Following User Says Thank You to JIM THEO For This Useful Post: | Thefalls (04-20-2022) |
05-16-2022, 01:51 AM | #93 |
05-16-2022, 03:01 PM | #94 |
Hey Andrew, I’ve had my B6s for 80k miles and a shop told me that the front struts have play, as in the shaft can move relative to its housing. They told me Bilstein’s have bushings that support the shaft and mine are worn. Is it true these bushings exist? I also went to inspect the struts and they both have huge 4”x4” burn marks on the shafts themselves. Luckily the marks don’t have any depth like scoring would leave.
Reason I ask is because the struts aren’t making any noise but do feel “soft”. Both struts are bone dry. |
The Following User Says Thank You to norcalpb For This Useful Post: | bhmax (05-16-2022) |
05-18-2022, 03:18 AM | #95 | |
Drives: '14
I think this part number might work, but really I'd just have someone refresh everything. Probably not easy for normal people to get. P/N: E4-LB1-Z008A09 BUSHING: 36MM UMS INTERNAL HSG I attached a pic from Bilstein's website with a cutaway, it seems relevant to this thread.
Always learning.
The Following 2 Users Say Thank You to itschris For This Useful Post: | norcalpb (05-18-2022), Racecomp Engineering (05-18-2022) |
05-18-2022, 09:36 AM | #96 | ||
https://www.instagram.com/p/CbumUe_r...d=YmMyMTA2M2Y= Either way, yes there are bushings/bearings and the rod guide that can wear out and cause some of the marks your seeing. No noise is a good sign, but 80k miles is a very solid run and I would start planning on sending them in for a rebuild. - Andrew |
05-18-2022, 04:17 PM | #97 | |
Yes by shaft I mean the part that you can actually see. I guess since it's inverted, the actual shaft is inside the body duh! I'm thinking about just replacing them as I've stripped the upper allen shaped holes bad enough that I'm forced to imperial sized allen wrenches to loosen/tighten the nut without spinning the shaft and I don't think a rebuild will be able to fix that right? Sucks they are $250/side now...but at least my rear B6s are holding up well. |
The Following User Says Thank You to norcalpb For This Useful Post: | Racecomp Engineering (05-19-2022) |
05-19-2022, 09:22 AM | #98 | |
Should also think about the B6s going in and out of stock and the occasional long wait though. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | norcalpb (05-19-2022) |
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
