Old 03-23-2022, 07:03 AM   #1
oBradyG
Drives: 2020 Subaru BRZ AT
Spacer size?
I’m going wide body soon, and I know this is probrably basic math and all but I don’t understand lol.. so this is the perfect setup for me for daily driving, and he’s running 18 x 10.5 +22 all around but I’m sure he’s running spacer, but does anyone know how big of spacers I need to acquire this fitment?
https://ibb.co/gtPvH54
oBradyG is offline   Reply With Quote
Old 03-23-2022, 08:58 AM   #2
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
You're right about it being basic math:
Picture the flat face of your hub where the wheel mounts. Now picture the 'barrel' of your wheel (inside lip to outside lip). If the barrel is centered on the flat plane of your hub then you have 0 offset.
Now move the barrel inward, towards the center of the car. Now you have a positive offset. The distance of the offset is measured in millimeters. In your example of 18X10.5X +22 the center of the wheels is 22mm inward from the flat plane of the hub.
Spacers move the wheel outward, so you subtract the thickness of the spacer from the wheel offset to get your new effective offset.
To figure out what wheel width and offset you need you have to measure the distance from the hub out to the fender lip (perpendicular to the hub face, don't just touch a tape measure to the hub and measure up to the fender). Get that measurement in millimeters. Now you can assume a wheel width; divide that by 2 and convert to millimeters. Subtract your measurement from the 1/2 wheel width and you have your 'target' offset (depending on how you measured and how close you want your wheel to be to the fender of course).
You probably won't find wheels with exactly the offset you want so you'll need to buy ones with a slightly higher offset and then add spacers to decrease it.
The same principles apply for determining how much clearance you need to components inboard of the fender.
CrowsFeast is offline   Reply With Quote
Old 03-23-2022, 09:48 AM   #3
oBradyG
Gotcha! Thanks! These were the wheels I am planning on getting https://ibb.co/kDXPgf8
They have the +22 offset and in this picture he has them on, https://ibb.co/F3RjDNS (same wheel and tire setup that I’m getting)
But he doesn’t specify the spacers he uses to get that fitment..that’s why I was wondering if u can find out the spacer size before I buy them because this is the perfect fitment for me to daily drive, thanks!
Old 03-24-2022, 10:02 AM   #4
CrowsFeast
CrowsFeast's Avatar
I gave you the knowledge, you need to do the further research and calculations yourself. First thing would be finding out how much the fenders and proper installation will cost.
The Following User Says Thank You to CrowsFeast For This Useful Post:
x808drifter (03-24-2022)
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Wheel spacer size for RBV1 Widebody Fenders? 403 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-18-2017 07:08 PM
Help me decide on wheel spacer size! Nickel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-15-2017 03:41 AM
Stoptech Front 328x28 - Minimum spacer size with OEM wheels ? asnatlas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-13-2017 11:38 PM
size of spacer recommanded? benlaz88 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-10-2014 12:54 AM
