#113 | |
Drives: 2022 MT Neptune GR86 Prem.
I made an L-shaped insert out of black packing foam so that the connector sits well above the ledge (bottom of the L) and tighter against the holder slot wall and haven't had any problems since. Of course, given the different design of the Gen2 armrest, this might not be the problem or solution. |
The Following 2 Users Say Thank You to CincyJohn For This Useful Post: | groovymoonbear (01-11-2022), Midnightsky (01-11-2022) |
#114 | |
Drives: 2022 BRZ
https://www.amazon.com/Satechi-USB-L.../dp/B08SY9WG9V |
#115 |
Drives: 22 BRZ Limited
For people having issues with CarPlay - I made sure I had the latest software update and then did a factory reset on my head unit. After about an hour of driving CarPlay hasn't done the reboot thing on me. Note, I also reset my ECU when I did this but I can't imagine that would have any impact.
#116 |
Drives: 2022 WRB Limited 6 Speed
I wouldn't really say this is a problem but it's definitely annoying..
When stuff falls between the cup holder and seats oh my god is it so hard to get out, there's literally no room. I occasionally drop my e-cig in there along with some change and random stuff, I always scratch the hell out of my hand trying to get it out. Took me so long to find a proper seating position for me so I do my best to not move the driver seat unless it's a last resort and I really can't get the item out |
#117 |
Drives: '22 WRB BRZ
The rear driver-side indicator works intermittently (has happened maybe 50% of the time during my first two weeks of ownership). Normally occurs first thing in the morning, where it won't work for the first 10 min then it will start working.
Took it in this morning, of course when I brought it to the shop it was working, although it wasn't working 5 min prior. The techs looked at it and said they ensured the connections were tight but ultimately it was working now so nothing they could do. As I was leaving and in the parking lot of the dealership, it stopped working again, I went back in to get the tech to prove I'm not crazy. In the 5 min of getting the tech, it started working again (the vehicle wasn't moved during this period). So they are going to order a new rear light assembly, but of course, they are on backorder. Not the end of the world by any means, just adding this to the thread. |
The Following User Says Thank You to GSX-R1000 For This Useful Post: | Midnightsky (01-12-2022) |
#118 | |
Drives: IS300, WRX, STI, Bicycle
I think there are cheaper generics on Amazon as well. |
The Following User Says Thank You to MisterGoober For This Useful Post: | Midnightsky (01-12-2022) |
#119 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Went to a local car club meet sponsored by a toyota dealer a couple years ago when you could still do that. One of the freebie giveaways for showing up were a pair of fabric covered foam shims to shove between the seat and center console. There's a slot for the seatbelt button to shove through the middle. Keep EVERYTHING from sliding under the seat. I'd miss them if they were gone. I've seen them for sale somewhere or other. Recommended.
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | soundman98 (01-12-2022) |
#120 |
Drives: 22 BRZ
I've been having some weird issues with traction control. When I press and release the traction control switch, the TRAC OFF light shows for about 5 seconds and then disappears.
The only way it will stay disabled is if I hold it for more than 3 seconds (disable TRAC and VCS), but that changes to the track display which I don't like. I thought that bar rpm display was only for track mode. |
The Following User Says Thank You to C R For This Useful Post: | Midnightsky (01-13-2022) |
#121 | |
TRACKBREAD
Single press traction control off turns back on over 30 mph iirc |
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#122 |
Drives: 22 BRZ
#123 |
Drives: 22 BRZ limited
The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | C R (01-14-2022), Midnightsky (01-13-2022) |
#124 |
Drives: 2022 BRZ
Anyone ran into issues with the gear indicator? Just noticed it on my drive yesterday that it stopped displaying which gear I'm on.
#125 |
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
#126 | |
Drives: 2022 BRZ
Mine had it on when I got it and it just randomly disappeared. I wonder if this has something to do with the occasional restart of the carplay. |
Anyone not buying to avoid early issues like 1st gen FRS? | stocktc1 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 203 | 09-23-2021 09:11 PM |
Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) -- General Topics | 34 | 02-27-2019 08:56 PM |
New 2014s still have early issues? Prospective buyer | Lord09 | Issues | Warranty | Recalls / TSB | 25 | 06-14-2014 04:42 AM |
Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 10:21 PM |
