Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-06-2022, 03:33 PM | #1 |
Drives: 2017 Toyota 86 (Raven)
Suspension advice before I spend my money
I’m running stock suspension but plan to get BC Racing coils (Extreme Low) with the swift spring upgrade and Rays Gram Lights 57DR 17x9 38+ with 245/240 Falken Azenis FK510. For the coils is 8k spring rate good or should I go higher/lower? I already know I might need extended lugs and spacers for the rear. Would dropping the car 1.5-2” be overkill and cause rubbing? What else would be needed for perfect fitment? I’ve checked FI gallery to see comparisons but it seems it varies with fitment.
01-06-2022, 03:39 PM | #2 |
Drives: Crapcan
Standard questions. What are you doing with the car? Tracking? Street car? Why BC? What other supporting mods?
8k is pretty stiff. Even on track most people run 6-7kg w/200tw tire.
01-06-2022, 04:05 PM | #3 |
Well I’m using the car as my daily so for purpose I’d say it’d be a street car I have no intentions for tacking my car..as of now at least. My first choice for coils were Tein Flex Z but with BC u have more adjustability, they’re rebuildable and a lifetime warranty knocks it out the park for me plus I like the black colorway vs the green :P. And with the ride quality I’d want something close or better than factory ride quality. What needs to be done?
01-06-2022, 04:32 PM | #4 | |
Drives: Crapcan
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
01-06-2022, 06:13 PM | #5 |
01-06-2022, 06:26 PM | #6 | |
Drives: Crapcan
Yes, they will limit fit a bit. If you think coils are the way to go you can look at the ST's, they are made by KW. Ride is pretty good. Another options would be CSG spec Flex A or the RCE SS1 and both are track/autoX capable.
01-06-2022, 06:34 PM | #7 | |
Drives: '13 Whiteout
01-06-2022, 06:46 PM | #8 |
Drives: Subaru BRZ
What I wish I'd known before changing my suspension:
Lowering will change rear camber and toe and wear out tyres. Changes in the geometry will also change bump steer characteristics, and straight line stability. I don't have the skill level to make meaningful adjustments to my dampers. The BRZ is one of the best handling cars ever built (handling, not grip). It is highly unlikely that you will end up with a better set up by opting for a 'race' package, unless of course you go racing... My advice would be to find a package with as close to OEM springs and dampers, but lowered, and to budget for adjustable LCAs and toe links and set up your car as close to OEM alignment as possible. My daughter's 2001 Corolla is more fun on back roads than my track oriented BRZ on street tyres. Think about that... Sent from my SM-G973F using Tapatalk |
The Following User Says Thank You to Purist For This Useful Post: | blakkoutdarko (01-06-2022) |
01-06-2022, 06:58 PM | #9 | |
Drives: Crapcan
My BRZ is pretty ruined for street driving too lol.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Purist (01-06-2022) |
01-06-2022, 08:54 PM | #10 | |
01-06-2022, 08:58 PM | #11 |
To clear up what my goals are these are what’s most important for my build.
1. Perfect or damn near flush fitment with a 17x9 38 245/240 setup with no rubbing/scraping. I still wanna clear speed bumps and driveways at an incline 2. Smoother or close to stock ride comfortably |
01-06-2022, 09:02 PM | #12 | |
Drives: Crapcan
17X9 +38 57DR's will be tight with a 245 tire and I can't guarantee it would fit. With this same setup with H&R springs on stock struts I had around a 1/4 inch of clearance between the tire and spring perch. You could always run a 5mm spacer to get more clearance. Here is a thread comparing Yellows + B6/B8's with Flex A's. https://www.ft86club.com/forums/show....php?p=3412277
01-06-2022, 09:07 PM | #13 |
Drives: Subaru BRZ
I'd consider lowering springs, keeping the 225 tyres and increasing the offset of the wheels to get your flush fit. A flush 225 looks good on these cars, filling out the guard makes it look much fatter.
Plus you retain the powerslidability that makes these cars so much fun. If spacers are legal where you are then I'm sure you could get custom ones machined to get the exact offset and get longer studs. In Australia, spacers are illegal so I got my wheels machined to the exact offset I want (to the mm) Wait and see what the rest of the community say but I'd highly recommend investigating this path a bit more. You could end up with a great looking car that handles great for less than you planned. Sent from my SM-G973F using Tapatalk |
The Following User Says Thank You to Purist For This Useful Post: | NoHaveMSG (01-06-2022) |
01-06-2022, 09:22 PM | #14 |
AutoX-10/10ths every run
RCE Yellows on stock struts were pretty good for me.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | NoHaveMSG (01-06-2022) |
Similar Threads | ||||
Manual vs. Electronic controller for air ride suspension. Should I spend the money? | wise345 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-06-2016 08:44 PM |
time to spend some money. Help me out so i only buy once... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-03-2015 12:10 PM |
Please Help? Don't want to spend any more unnecessary money! | Khwang89 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-10-2014 10:22 PM |
What should I spend my money on | sf86 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 11-28-2012 04:34 PM |
Please be aware where you spend your money | KronosPerformance | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-28-2012 08:28 AM |
