Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-19-2021, 10:29 AM | #1 |
BRZilla
Drives: '13 WRB BRZ Limited MT
Upgrading my rear suspension questions
After my 100,000 mile inspection my mechanic informed me that I need a new right rear strut & mount (Yay PA Roads), & a new lower left ball joint/control arm. I figured it's probably best to just re-do both back struts at this point, replace everything in pairs & everything.
For the rear suspension I'm planning on upgrading to the Bilstein B6s, but was curious what new mounts to get with them. This is a daily driver & I'm not too familair with suspension parts. I was looking at the KYB Strut Mount, but figured it might be worth it to upgrade to a Raceseng or Vorshlag Spherical Mounts. I just don't know why the Raceseng has 1" and 2" options & what perch I'd need. (Again, no idea what I'm looking for). I also noticed people recommended installing whiteline rear subframe inserts. Would that be worth it since I'm replacing the struts? I'm currently planning on sticking with the OEM shocks. Unless there's a reason or cheap upgrade I should be doing. For the left lower ball joint arm, it's apparently bent. (Again, Yay PA Roads - Specifically looking at you Boulevard Overpass Contruction Crew) is this something I'm fine just replacing the left one of? Any aftermarket upgrades that aren't too expensive?
11-19-2021, 10:46 AM | #2 |
Drives: 17 Asphalt 86
B6s are an upgrade. I'd recommend doing all 4 together.
For strut mounts, stick with OEM. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Racecomp Engineering (11-19-2021), wparsons (11-26-2021) |
11-19-2021, 05:21 PM | #3 |
Drives: Subaru BRZ
Consider adjustable LCAs in case you want to lower it later. Not much price difference.
Sent from my SM-G973F using Tapatalk |
11-19-2021, 07:44 PM | #4 |
Drives: 2020 Toyota GT86
Other than a defective new one, struts should basically always be done in pairs (both front or both rear).
But frankly as suggested I would just bite the bullet and do all four at once. Especially if you are upgrading.
This post sent using 100% recycled electrons.
The Following User Says Thank You to bucketfoot For This Useful Post: | x808drifter (11-19-2021) |
11-25-2021, 07:57 PM | #5 |
Seņor Member
Huh??
1974 TA22 Celica
2013 86 GT |
11-30-2021, 03:01 PM | #6 |
BRZilla
12-08-2021, 02:33 PM | #7 |
I would do all 4. It might be worth it to do RCE yellow coils, only lowers 20mm and many people like them with B6.
12-22-2021, 12:36 PM | #8 |
BRZilla
Alright, leaning toward doing all 4. My shop recommended replacing all the strut mounts as well because if I'm replacing the struts & the one mount is already degrading, it's probably best to just do all of them & be all new rather than potentially have to wait for another part after things get taken apart.
So, Looking at -B6 Front & Back -Assuming I should include new Strut Boots -Stick with OEM Springs or the RCE Yellows -Strut Mounts - OEM However, the OEM Front Strut Mounts say they're not available & the "replacement" product says it doesn't fit with the 2013.... Any other mounts people recommend? I found a few threads mentioning Pedders, but they're currently sold out on front mounts.
12-22-2021, 01:39 PM | #9 | |
Drives: 2013 WRB BRZ
See below
The Following User Says Thank You to BigTuna For This Useful Post: | mjh712 (12-22-2021) |
12-22-2021, 02:31 PM | #10 |
I agree with BigTuna, but I would replace the strut mounts. Anything OEM 2013-2020 will fit your car. I posted some part numbers in this thread:
https://www.ft86club.com/forums/showthread.php?t=142230 - Andrew |
12-22-2021, 02:36 PM | #11 |
OEM front mounts are the same across the board for FRS/BRZ.
If you find something that fits a 2017 it fits the 2013 too. Edit I was beat too it. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | mjh712 (12-22-2021), Racecomp Engineering (12-22-2021) |
12-22-2021, 04:15 PM | #12 | |
BRZilla
12-23-2021, 08:30 AM | #13 |
BRZilla
Okay, now the parts websites are saying it does fit...
12-23-2021, 08:45 AM | #14 |
I made a call and Subaru fixed it.
Jk I have no idea what happened. Sometimes the parts websites are clunky. - Andrew |
Tags |
bilstein, control arm, top hats |
Similar Threads | ||||
Upgrading 2013 suspension to 2017. Parts needed? | armstrom | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-14-2021 12:52 PM |
"Upgrading" BRZ suspension without lowering | holeeray | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 12-03-2020 09:43 PM |
Upgrading from RCE Yellow AutoX setup to coilovers... questions | Keenercarguy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 07-10-2017 09:47 PM |
looking into upgrading suspension | Mattygt86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-09-2015 11:46 AM |
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 | Astroboy | Forced Induction | 4 | 03-01-2014 07:29 PM |
