Old 11-24-2021, 04:58 PM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Steering issue under load with track tires
Guys, I've been searching to see if I can find something consistent but I haven't so far.
So I was driving on Little Switzerland today in Boone, NC and something odd is happening in high g load right hand corners. In corners that are similar to ones like gravity cavity on the tail of the dragon, essentially what is happening is in mid corner, the steering is locking me out and dangerously not letting me to continue steering and I have to back out. I'm not getting a warning light for the electric power steering.
Car has TRD springs, alignment is around -1-5F/-2R, Carbotech XP8s and 235/40R18 Hankook RS4's.
2013 Scion FR-S 10 Series MT #182 of 2500/1994 Suzuki Cappuccino/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @nickel_reed
Nickel is offline   Reply With Quote
Old 11-24-2021, 05:05 PM   #2
alphasaur
friendly
Drives: 17' 86
this sounds terrifying
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-24-2021, 06:13 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Most likely the EPS is overloaded, overheating and shutting off. This means you're left without assist for the steering which makes it significantly more difficult to turn the steering wheel (and keep it turned).
This might happen with a stock setup, and happens more often with wider tires, stickier tires and more caster. It also happens much more frequently on the track where steering loads are higher.
Hankook RS4 at 235 width will certainly cause this.
Plenty of threads around this issue and how to work around it.
Ohio Enthusiast is online now   Reply With Quote
Old 11-24-2021, 07:42 PM   #4
Nickel
Nick
I've seen quite a few but sometimes without the right key words, I'm running into unrelated threads. Do you happen to know of a thread you could link me where someone has worked around this?
Old 11-24-2021, 07:49 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
Here's one - https://www.ft86club.com/forums/showthread.php?t=90718
Old 11-24-2021, 07:56 PM   #6
Nickel
Nick
Yeah that's one I've been eye balling for a little while. I'm on lowering springs so I couldn't raise it. Spoke to a local from the dragon, he actually ended up giving up on the chassis because of this. I'll have to take up to the dragon and see what happens there and then go from there.
Old 11-24-2021, 08:17 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
As far as I understand this has been improved in later years, perhaps 2015 or 2017. I think I saw some mention of people upgrading to a later year EPS unit but I'm not sure.
This recent thread mentions it happening on a 2014 but not on a 2017 (but another poster says it's still present in 2022...).
Looks like there're no fixes for this, though, other than reducing caster.
Old 11-29-2021, 11:27 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check to make sure it isn't rubbing anywhere. I have issues with rub and EPS cutout.
Old 11-29-2021, 01:42 PM   #9
Nickel
Nick
I've checked clearance in all areas and nothing is rubbing anywhere. I've spent the last several days finding any information I can on this. It doesn't really seem like there is a real fix. I'm going to get my caster checked and see if I can lower it and maybe that will take some stress off of the EPS and lighten the issue a bit.
Old 11-29-2021, 02:10 PM   #10
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I get it on my 2019 fairly frequently, it still will steer, just need to use some force. I had rubbing issues from my coil perches and end links rubbing the chassis, but no rub issues with my coilovers now. Still getting EPS shut off.
TunaNoCrust is offline   Reply With Quote
Old 11-29-2021, 02:16 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by TunaNoCrust View Post
I get it on my 2019 fairly frequently, it still will steer, just need to use some force. I had rubbing issues from my coil perches and tie rods rubbing the chassis, but no rub issues with my coilovers now. Still getting EPS shut off.
I am assuming you meant endlinks and not tie rods. Which one's are you running? I had a lot of issues until I went with the whitelines. I notice the thickness of the rod end was much narrower than others I had tried and they no longer hit. This is with -3.6 front camber though I have maxed camber at the knuckle before adjusting the top hats. I am probably going to -4 next year so that could change.
Old 11-29-2021, 06:30 PM   #12
TunaNoCrust
Hahaha yes, thank you. Completely stock suspension SACH dampers, TRD Springs, TRD sway bars. I too was looking for slimmer end links, but ended up getting coilovers and that solved all my rubbing problems. I am at -4 up front with a single camber bolt and 95% maxed out camber plates.
The Following User Says Thank You to TunaNoCrust For This Useful Post:
NoHaveMSG (11-29-2021)
Old 11-29-2021, 09:21 PM   #13
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I've also experienced this on occasion with my 2013 running Hoosiers in autocross. Never found a fix.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 12-02-2021, 08:14 PM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Three of us have done several full race season on Hoosier A7s without the EPS ever being an issue. I find it odd that so many people on street tires or even autox cars have this issue, so odd in fact, that I think it's not EPS.
A lot of aftermarket stuff poorly accounts for other aftermarket stuff and stuff can bind. Remember the joke "Interchangeable parts don't."
End Links are a great example - some folks have put steering rack limiters so that they can't turn too sharply in the paddocks because it would break their end links. I'm thankful that my strut+end link choice didn't create that scenario for me.
I suspect the OPs issue is not EPS related and instead something is rubbing or something is binding.
SCCA T4 - FRS
Adjusting AFR with Engine Load Compensation (instead of Load Limits) Tor Software Tuning 33 08-17-2021 08:58 AM
ISSUE: 1900-2000 RPM Shutter/Shaking (Free load) Neurytic Issues | Warranty | Recalls / TSB 29 11-22-2020 10:19 PM
Steering issue? edrokone BRZ First-Gen (2012+) -- General Topics 6 05-16-2020 02:58 AM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
