Old 11-09-2021, 03:31 AM   #43
boy_racer
Drives: s13 200sx
boy_racer is offline   Reply With Quote
Old 11-09-2021, 03:32 AM   #44
boy_racer
Drives: s13 200sx
Saw it on another forum ,Essen Germany 02/12/2021
Old 11-12-2021, 01:34 AM   #45
boy_racer
Drives: s13 200sx
European reviews coming soon,embargo until Monday 15 November, European specs unveil at December and something about deliveries May 2022.
https://www.instagram.com/p/CWEOiTgo...dium=copy_link
https://www.instagram.com/p/CWDxcDZN...dium=copy_link
Old 11-15-2021, 03:18 AM   #46
Jianlun
Drives: GR86 RC
Jianlun is offline   Reply With Quote
The Following User Says Thank You to Jianlun For This Useful Post:
boy_racer (11-15-2021)
Old 11-15-2021, 09:22 AM   #47
boy_racer
Drives: s13 200sx
From the German website,translated
Old 11-15-2021, 09:46 AM   #48
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Old 11-15-2021, 11:16 AM   #49
Jianlun
Drives: GR86 RC
Nothing we haven't heard before but nice to hear more good things about the platform as embargo is lifted in Europe.
https://www.evo.co.uk/toyota/204343/...ches-cayman-20
https://www.topgear.com/car-reviews/...st-drive?amp=1
https://www.autoexpress.co.uk/toyota...ype-review?amp
Old 11-16-2021, 07:47 PM   #50
Jianlun
Drives: GR86 RC
From https://www.carmagazine.co.uk/car-re...ta/gr86-coupe/
I am confused. Did they get the info packet from BRZ or does Europe GR86 really have BRZ's rear? Hmmm what about the front knuckles....
Old 11-16-2021, 11:34 PM   #51
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I think its always been connected to the subframe..? The subframe is redesigned in both cars though.
The BRZ has it connected directly to the body, and so I believe its welded, not through a bushing - very direct.
I think Toyota has spent considerably more time suspension tuning than Subaru though, I think it might be considered a further evolution even though its on a slightly less direct chassis.
Blighty is offline   Reply With Quote
Old 11-17-2021, 12:19 AM   #52
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I had some time to check the European's reviews. Overall, there was much more technical information and some of it was quite interesting. First of all, the cylinder liners are thinner so it will be a question how much power the engine can handle going FI. First generation "issue" was the offset connecting rods and now with a back to normal rod design new "issue" will be the thinner liners? Another odd thing is the top speed which remains the same with the previous model. Is it electronically limited (really?) or is the new engine a bit weak top end? Finally, it was mentioned that it'll be offered as a single spec option meaning that we won't get anymore the 86 RC or BRZ RA Japan specs. The first generation BRZ RA spec was available in Europe and you could have a 35 kg lighter car (1202 kg). Compared to the new car weight difference is even bigger in the range of ~70 kg. Torque in new car definitely helps, but it would be better if weight was the same.
The Following User Says Thank You to nikitopo For This Useful Post:
Blighty (11-17-2021)
Old 11-17-2021, 12:34 AM   #53
Blighty
Originally Posted by nikitopo View Post
I had some time to check the European's reviews. Overall, there was much more technical information and some of it was quite interesting. First of all, the cylinder liners are thinner so it will be a question how much power the engine can handle going FI. First generation "issue" was the offset connecting rods and now with a back to normal rod design new "issue" will be the thinner liners? Another odd thing is the top speed which remains the same with the previous model. Is it electronically limited (really?) or is the new engine a bit weak top end? Finally, it was mentioned that it'll be offered as a single spec option meaning that we won't get anymore the 86 RC or BRZ RA Japan specs. The BRZ RA spec was available in the first generation car and you could get a 35 kg lighter spec. Compared to the new car weight difference is even bigger in the range of 70 kg.
You do wonder about what issues there will be, how thick was the cyl walls on the old EJ25s?
Weak at the top end compared to the original? Eh?
Old 11-17-2021, 01:08 AM   #54
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Not weak at the top end compared to the original, but I would expect a higher top speed. The gearing is the same, so what is the root cause? The additional weight it doesn't matter for top speed. Maybe more downforce with the improved aero?
Old 11-17-2021, 02:35 AM   #55
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
[...] The additional weight it doesn't matter for top speed. Maybe more downforce with the improved aero?
Downforce also doesn't matter for top speed, drag is what matters.
In theory, a ~15–20% increase in power/torque should provide ~5% more top speed assuming it's reached at the same rpm. The 4.1 FD in the 2022's is in fact ~5% taller than the 4.3 FD on the 2017–2020s, at least on the US market.
Curious what we find out later.
However, I couldn't care less whether the top speed is 140 or 150.
Except for autobahns and maybe Monza, you can't really reach those speeds anywhere.
Old 11-17-2021, 02:36 AM   #56
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Also you know how journalists work: whatever someone said during the presentation is what they're going to write.
Maybe the presentation didn't even mention the top speed, then someone asked, and someone replied with the wrong number...
The Following User Says Thank You to timurrrr For This Useful Post:
boy_racer (11-17-2021)
Toyota Europe's non-announcment announcement about EVs Dadhawk Other Vehicles & General Automotive Discussions 45 12-20-2020 03:38 PM
The new Volkswagen ID.4 – World premiere of the fully electrically driven SUV vh_supra26 Other Vehicles & General Automotive Discussions 5 09-27-2020 02:40 AM
MY REVIEW: Toyota GT86 in Europe Kgroschi FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 06-06-2016 08:02 AM
STI NBR CHALLENGE 2014 World Premiere Movie JPxM0Dz Other Vehicles & General Automotive Discussions 0 02-03-2014 05:04 PM
FT-86 II Wallpapers from Toyota Europe Bang Uchiha FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 09-14-2011 04:53 PM
