GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
10-21-2021, 09:15 PM | #15 |
Drives: 2013 frs red
I see some 4.3 conversations being tried
10-22-2021, 02:36 AM | #16 | |
Drives: Halo 86, '19
The nicest transmission I've managed to get some street time with is whatever aisin 8spd is in the RX350. It's smooth, likes to downshift readily and extremely quickly, compared to the AT modes of most other Zf8hp BMWs which are very reluctant and practically demand you to be lugging the engine before they start to downshift. Driving it manually didn't feel any different than the ZF8HP at cruising speeds, but like the 960E and ZF at higher RPM, you can't avoid the jarringness and delay as the transfluid does its magic working whatever the hell's inside an AT trans. The gradience in difference felt consummerate to the difference in gear lengths. That is to say the ZF isn't a miracle AT transmission and the 960E isn't some piece of shit either, and that in conjunction with my experiences, most good quality transmissions feel and function almost identically, with only small practice(per the aisin 8spd anecdote.) Ultimately they are all the same technology and in practice are similar to each other, and that in my experience, the only major differences in feel come from the length in gearing - the 960Es stupid long gearing 6spd, vs any 8spd. And that's something you can't tune out, even if I think the 6spd could be improved. Anyways with regards to quoted shift times, I'm 90% sure I read or heard in a video somewhere the 960E on the 86 was quoted for 250MS shift times. Which I guarantee is only for upshifts. I guarantee the ZF8HP is using the quoted 200MS shift time for their upshifts too lol. Those numbers don't really mean anything to me in practice and I think most would agree if you've driven those transmissions for any amount of time. |
10-22-2021, 04:48 AM | #17 | ||
Drives: '15 BRZ RA
Check here as a reminder example how a HUGE improvement the '17 BRZ was considered in comparison to the '13-'16. Afterwards things were settled down and people recognized that it wasn't that much of a difference. Not trying to convince either way. I hope people to buy the new ones and for sure the day to day driveability will be better with the bigger engine. After all this is what some people were asking? Let's hope that the same people will now buy and not complain about the price ... |
10-22-2021, 10:35 AM | #18 | |
Drives: 2022 MT Neptune GR86 Prem.
In any event, it's not about performance for most manual drivers. You either love to drive a manual or you don't. You either need to have a manual car as your daily driver or you don't. There are certainly exceptions to this rule, but obviously you and I are in this group. BTW, this is why the new Corvette is SOOOO disappointing - to go from a car that not too long ago was only offered in manual to one that you can't even get in a manual is bizarre. It's bad enough we are going to lose manuals as internal combustion heads out the door - no reason to speed it up in a car that clearly should have it. It's like after they styled it and realized they were going to lose half of their hardcore fans (I personally love the styling - not a fan of most newer Corvettes), they said "Let's see if we can raise that to 75%." I don't get it. |
The Following User Says Thank You to CincyJohn For This Useful Post: | Yoshoobaroo (10-22-2021) |
10-22-2021, 11:43 AM | #19 | |
10-22-2021, 12:09 PM | #20 |
TRACKBREAD
I’ll take a manual over a PDK any day of the week. And Porsche’s manuals aren’t anywhere as good as the BRZ’s.
I’m not the only one when it comes to sports cars. 55% of twin owners buy manuals. In this segment the business case for the manual makes absolute sense. |
10-22-2021, 12:27 PM | #21 | |
All I am saying is if you are an auto exec and you see that in a sports car segment only 55% are MT and the sports car segment is a couple percent compared to SUVs, crossovers and sedans. It’s an easy decision if you need to cut costs to cut the MT. I personally don’t see Subaru and Toyota doing it but things are changing and simplifying your supply chain goes a long way. I also feel future EVs will have outstanding performance for a very cheap price. Although I think the engagement and fun will be diminished for sure. |
10-22-2021, 08:30 PM | #22 | |
Drives: Civic Sport; seeking weekend car
The cutting of manuals happens in cars that have/had take rates in the single digits. |
The Following User Says Thank You to kaputt For This Useful Post: | Yoshoobaroo (10-22-2021) |
10-22-2021, 08:54 PM | #23 |
Drives: 2022 GR86
10-23-2021, 02:07 AM | #24 |
Drives: '15 BRZ RA
10-23-2021, 02:26 AM | #25 | |
Drives: ‘22 CWP
All these people are smoking crack in my opinion. |
10-23-2021, 03:28 AM | #26 |
TRACKBREAD
The 981 is still a cable shift mechanism like the 987 and 986. While improved over the sloppier 986/7 shifter, It still doesn’t feel quite as good as the direct linkage style on the BRZ. Combine that with the long travel and high pickup point of the clutch, in typical German fashion, and it’s not as good to drive as the manual on a BRZ/Miata/S2000.
The only way to make a cable shifter feel as good as a direct linkage is to use spherical bearings at the end of the cables. It can be done with aftermarket kits but OEM will always use bushings. |
10-23-2021, 03:33 AM | #27 | |
Drives: ‘22 CWP
The Following 2 Users Say Thank You to Kona61 For This Useful Post: | timurrrr (10-25-2021), Yoshoobaroo (10-23-2021) |
10-23-2021, 04:18 AM | #28 | |
TRACKBREAD
Haven’t driven that one but I’m sure the mechanism is quite a bit cheaper than on the BRZ or WRX STI. It’s all subjective in the end but the consensus is that the clutch pedal and shifter in this car is fantastic. Keep in mind some people actually like the sloppy 986/996 shifter, so YMMV based on what you’re used to. To some people a really tight mechanism will feel too notchy. |
Similar Threads | ||||
Canadian 2022 Brz/Gr86 build and price websites/dealer availability?? | prod | CANADA | 15 | 01-27-2022 08:14 PM |
2022 GR86 at Gridlife Alpine Horizon Festival this weekend in CO | mav1178 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 2 | 07-26-2021 09:20 AM |
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
